Question about KitchenAid Food Mixers
I replaced the center bevel gear on my kitchenaid mixer, and now the long worm-gear on the side is skipping. Is there a technique to putting this wormgear back in. The bushing on one end has a raised area on the inboard side, and when it's oriented a certain way the housing does not sit down flush, but the worm gear is tighter this way. When I rotate both ends it sits down further, and the housing screws down nicely....but then the gear skips.
SOURCE: I have a Kitchenaid Professional
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
Posted on Aug 25, 2008
ricardok45
  • 135 Answers
SOURCE: repairing a kitchenaid 6qt mixer
Hi. Go to the whirlpool.com website, for some insane reason they don't list their mixers, enter a search for mixers, then find your model #. Look for a parts catalog. Look at the "exploded" drawings for the transmission area. There you'll notice that there are Front and Rear bearing locations. This drawing also shows the correct place for the "washer". Also, the front and back bearings may look alike, but the're not. Every part needs to be in it's correct place or damage will occur when you start it up, or when you place the machine under load. Let me guess...The original PLASTIC transmission housing broke causing damage to the worm gear assembly. If this is the case, your replacement transmission housing should be made out of metal. If it isn't, call customer service and demand that they send one. The plastic housing has no place in a Premium priced mixer, especially when they advertise that the mixer can handle heavy bread dough. Finally, check the bearing seats, when the worm gear failed it may have also damaged these seats. It happened on my Kitchenaid. Good Luck!
ricardok45
Posted on Dec 31, 2008
SOURCE: KitchenAid Mixer stopped working after
The brushes must be insert in a particular manner in order for it to work correctly. If you remove the brushes and shine a flashlight into the hole, you should see a small detent or "stop" in one corner of the hole. Its a square hole. Match this corner with the corner of the brush which is shaved off. The brush is not square; it has one corner shaved or smoothed down. This allows the brush to fully extend into the hole. If the brush is inserted any other way, it will not contact the motor and will not run.
Posted on May 07, 2009
hslincoln
  • 235 Answers
SOURCE: KitchenAid K5sswh mixer after replacing plastic gear-no power
Hi COVINIO. Yes, the "large black spring loaded magnetic screws on the sides of the mixer" are your mixer's brushes, which supplies electricity to the electric motor. (The black cap is the brush cover). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them, when you replaced your plastic worm gear?
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 47, Brush holder assembly that includes #28, 32, 33, 34 & 46 which is the brush holder insert, and Illus. No. 29, brush & Spring assembly respectively. The illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Posted on Jan 29, 2010
Testimonial: "Dear hslincoln,Thank you for your very helpful link to diagram that showed exactly what to. It was fixed within 3 minutes"
hslincoln
  • 235 Answers
SOURCE: do th gears in a kitchenaid mixer need oil
Hi SHIRLAFINK, you do not need to 'oil' the transmission gears on a KA mixer. Your KA mixer comes with enough grease to 'last a lifetime' - whatever that means?
Depending on the age of your mixer and how heavily you use it, there may be a time when you might want to replace the grease, but that period is usually measured in years of useage.
Of course if one of the gears strips or breaks, you will need to replace all the grease when you replace the broken gear. Attempting to use salvaged grease jeopardized the remaining gears if pieces of metal or plastic debris are suspended in the old grease.
I hope this helps - hslincoln, Burke, VA
If this solution has been helpful, please rate it, thanks! hslincoln
Posted on Mar 15, 2010
Testimonial: "Thanks very much, very helpful."
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Mixer struggling to spin?
Check everything you have done for a mistake, the pin through the planetary, the pin through the fuse gear and the pin in the main shaft that drives the bevel gear. That's the gear that pinion gear on the fuse gear shaft mates with. After that you are left with a fuse gear fault. I am assuming that the motor is turning at normal speeds and not somehow binding up, no reason why it should as motor stays in one piece during gear changing procedure.
Apr 18, 2014 | KitchenAid Food Mixers
Planetary dropped
when you replaced the planetary you forgot to put the retaining spring clip back on,
Jun 10, 2013 | KitchenAid KP26M1X Stand Mixer
Kitchenaid Artisan Stand Mixer has stuck hub bevel gear (KSM150PS)
The bevel gear sits above the worm-follower gear. I think you mean the drive attachment gear.
I think I have the same, or similar problem. I ground a piece of meat that stopped it from working. The drive-attachment-gear turns if I push it in, but then it pops out. I am still trying to figure out what part is causing the issue - the drive attachment gear, or maybe even the worm follower gear.
Feb 24, 2013 | KitchenAid KSM150PSGR - Artisan Series...
Bevel gear and worm follower gear no longer stay together
they should be a tight fit as the clip is just to help retain position
if they are ment to be loose replace the clip and inspect the groove for the clip as the edges may be worn to a taper rather than a sharp edge which will allow it to be moved out under load
May 18, 2017 | KitchenAid KP2671 Professional 6 Series...
Hi, I have a Kitchenaid stand up mixer custom edition 500 watt model #Kd2661xmc that sounds fine when I don't have anything in it, but sounds like its crying when I put just a single cake mix in it. ...
Get A Copy of the Repair Parts List for your model at Kitchenaid.com.
Remove the Gearcase Motor Housing (1) & the Transmission Housing (7)
Remove the 2 screws (23) holding down the Motor (2) and lift off way from
the Worm Gear (17). Test run the motor by itself at different speeds.
If it runs fine then it's time to inspect all the gears in the Transmission
Housing(7). Remove all the brown Grease covering the gears.
Pay attention in particular to the teeth of the Worm Follower Gear (19).
(the Bevel Gear (21) sits on top of this gear)
They should not be worn out or chipped. If they are then this is the source
of the noises you're hearing (the Worm Gear is grinding away the teeth of
the Worm Follower Gear). Once the Follower is replaced, your mixer will
be just as new again.
Please Note that this replacement is not an easy task. You need the right
tools and don't use a hard object like a steel screwdriver to pry out the
Planetary plate (15) from the beater shaft. Before re-assembly, use only
fresh new Food Grade Grease from Kitchenaid (the old grease may contain
metal filings from the worn out gear that will damage your new one)
Jul 22, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have a burning smell when i turn the mixer on and the gears dont change fast enough.
Get a copy of the Repair Part List for your model from Kitchenaid.com
Remove the motor housing, lift the main motor away from the transmission housing and
test run it at different speeds. If it is fully functional, then all your problems are inside
the transmission housing, most likely the Worm Gear Follower ( you may have to remove
all the gear grease to clearly see it). The Bevel Gear sits on top of the Gear Follower.
Inspect the teeth of the Worm Gear Follower (and also all other gears) for signs of damages.
Jul 11, 2011 | KitchenAid ProLine 600 Stand Mixer
Food Mixers Logo
67 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
