Question about Dell Computers & Internet
Have power to mobo , cd rom drive lite stays on solid , no display and no hard disk activity
  • Dell Master
  • 11,800 Answers
Try using another memory stick. If it's the same then the mobo has died, replace it.
Posted on Aug 07, 2010
Computer will power up but hard disks, cd roms, and minitor will not . i do get power to cooling fan and floppy drive
you may have a motherboard issue if you cant get hard drive activity or a display unfortunately there is nothing you can do unless you take it to a repair shop i am sorry!
Dec 19, 2009 | E-Machines T3958 (827103050974) PC Desktop
Ccomponants will not power up
David,
Your hard drive is junk. Replace the hard drive.
May 23, 2009 | Computers & Internet
Hp computer. hard drive light is solid yellow ..non working
Hi 2xcapers
This could be a problem with your IDE or SATA cables that connect your Hard Disk to your Motherboard. Try replacing these before you try the next solution.
The constant yellow light usually indicates a crashed or non-functioning Hard Disk. You can take this to get repaired and only the data where the "Spindal Pin" crashed will be lost, otherwise the Hard Disk should still be fine. The screen does not come on during the event of a crashed or corrupted Hard Disk, so this is another indication that there is a problem with the Hard Disk.
Please remember to give this solution a FixYa! rating.
Happy Easter
BearWeb
Apr 12, 2009 | HP Computers & Internet
My new samsung sm348 is not detected
It sounds like it might have the same buss address as you hard drive, making the hard drive inaccessable to boot. Check the documentation for the sm348 there should be information on changing the address jumper. Some PCs the cable determines the drive address, some you have to set it on the device you are installing.
Mar 24, 2009 | Samsung SM 348 CD-RW/DVD-ROM (Combo)...
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
Sep 26, 2008 | Computers & Internet
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Setup my 500gb my book
Connect your Hard Disk to the PC and insert the CD ROM provided with your Hard Disk into the Drive.
After a Few seconds the Setup Screen is likely to be displayed before you. If it happens so, do as directed; else, Run Setup.exe from the CD ROM and do as directed.
Jun 30, 2008 | Western Digital 500GB My Book World...
Mobo only one ide connection socket for HDD & CD-Rom
yes you can add both your HDD and CD-ROM Drive with the same IDE, get a IDE data interface cable (BUS) atleast three connection point. Add 1 to mobo, second to HDD and top 1 one to CD-ROM drive. Just connect and dun wrry m sure it will work....so............:))
If any problem just Ask me
Thanks
Iqbal
Apr 07, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
