Question about Refrigerators
We have a DM2652 Dometic refrigerator/freezer in our RV. The freezer is working, but the refrigerator will not cool. What is the skinny white tube near the back of the inside of the refrigerator, and what is the plastic slide thing that is on the metal cooling panels at the rear of the refigerator. It says that cooler is 'up' and warmer is down?
  • debracweber Aug 07, 2010
    Thanks Daniel...your info was helpful. Amazing that the thirmistor info was not mentioned in their operation manual!
  • 4,323 Answers
Hi
Check for the temperature controller inside the refrigerator. look for a white plastic piece on the far right side inside the refrigerator. This plastic piece slides up & down and from this you can control the temperature inside the fridge. If this doesn’t work then the thermistor is failing. Also check the electrical cut off (eco) switch which is at the back of the unit, it has 2 red wires coming from the control board to the heater on the right hand side. And the 2 wires plug into connecters at the heater and the eco switch is between the two wire connectors. To locate it remove cover from the rear of the icebox and reset this eco switch.
Also check if your Dometic is under recall List, check this link---
Dometic Recall Information
or contact them at -- Dometic Customer service, to find if your fridge is under recall.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 07, 2010
Refrigerator not cooling on electricty or gas
You will first want to ensure the RV is level.
If the RV is level, then open the rear access vent door on the side of the RV to access the rear of the refrigerator. Feel the coils just above the tank on the cooling system. These coils should be warm to the touch. If they are warm and the refrigerator is not cooling then you will require a replacement cooling unit. Also, the most common area for the Dometic 2652 to leak is just above the propane burner area. If it has leaked, you should see a yellow residue in that area. The cooling unit can be changed in approximately 2-3 hours with no specialized tools needed (Arcticold offers 7 day a week free tech support). The old cooling unit will simply unbolt and the new one bolts in. Check out ArctiCold Refrigeration We keep it cold (the highest quality product available) Arcticold New Cooling units come standard with a Lifetime Warranty. Install instructions are also provided with the cooling unit. Arcticold has locations across North America to provide fast delivery. Arcticold cooling units may be purchased over the phone (1-888-782-6665) or through Ebay- Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
#1 Help Diagnose Video
#2 Install a Arcticold RM2652 Cooling Unit Video
Mar 15, 2014 | Dometic DM2652 Americana Fridge...
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
May 26, 2012 | Dometic RM2652 Refrigerator
My dm2652 turns on but doesn't cool
Check the thermostat setting and check you have power from it to the heater if it is an absorption fridge or compressor if not.
Apr 21, 2012 | Dometic RM2652 Refrigerator
I have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Jun 06, 2010 | Dometic RM2652 Refrigerator
RM2652 Refrigerator: I have a DM2652 model Dometic RV refer. It is leak...
Dometic Voluntarily Expands Refrigerator Recall
Dometic recently expanded its recall on a population of two-door refrigerators. The original recall included some two-door refrigerators manufactured between April 1997 and May 2003. The new recall focuses on models manufactured between June 2003 and September 2006.
To see if your unit is on the recall list & what to do, try the link below.
If your unit is on the list, DO NOT run your refrigerator on propane until the kit is installed
http://www2.dometicusa.com/recall.php
May 18, 2010 | Dometic RM2652 Refrigerator
Refrigerators Logo
338 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
