Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Our Krystal clear saltwater system says Low salt and then goes into sleep mode and stops working?
  • Intex Master
  • 8,404 Answers
Add salt to the 3200 PPM level
Posted on Aug 20, 2010
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
My Krystal clear saltwater system keeps saying low flow and shutting off the motor. What is going on?
It sounds like there might be an obstruction in the inlet (suction) line.
Try seeing if you can back-flush the line with a garden hose to unblock it.
Jul 26, 2014 | Intex Krystal Clear Saltwater System Pool...
Help with low flow on intext krystal clear saltwater system.
You can check the inlet line where it comes from the pool... Their is a little sreening/filtering system in the the parts that screw together and connect the valve to the pool... When I unscrewed mine, it was jammed with bugs, leaves, green algea... That did the trick for me... I am sure you already changed/cleaned the filter in the filter/pump that comes before the Salt water system... That will cause low flow as well...
Jun 04, 2014 | Intex Automatic Salt Water System for ...
Intex krystal pump systems how do i set the timers to set the interinterv
Nancy... This is how I have mine set up... I have a cheap Home Depot Timer that I use for the Filter/Pump the comes on at 6:00am in the morning and goes off at 12:00 pm... This Timer is very simple to use... For the Salt water System, For the first time I turned it on was at 6:30 AM (before work) and set it for 5 hours... Once is has completed the 5 hours, it will go into Sleep Mode and automatically start 24 hours later, so in my case, it will start the next day at 6:30 am... So i have have my Filter/pump come on 1/2 hour before the salt system comes on and it goes off 1/2 hour after the salt system goes off...
Hope that helps.
Dan
May 19, 2013 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
May 30, 2010 | Intex Automatic Salt Water System for ...
Low water flow
Low water flow is generally and indication that the filter is dirty / clogged. Remove the filter cartridge and see if the light goes out. Replace the filter if required.
Apr 22, 2010 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
729 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
