Question about Brother HL-2040 Laser Printer
All error lights blinking and fan running but won't print...
We recently had a power outage while the printer was on and now when I try to turn on the printer it won't "work". All of the error lights blink including the ready light and the fan runs but it won't print...
  • Anonymous May 08, 2008
    same here
    fuser ?
    Problem Solver:
  • 7 Answers
Yes Mr. Guest and Mr SwT,
Replace the fuser assembly unit.
Definitely the fuser got problem. This can be confirm by pressing the Go button and only the Toner LED will light up.
What had happen was right after the power blackout the fuser has fused together both rollers (heating drum and rubber roller) where the paper pass through in between the rollers. Since there was a power blackout, the printer fan has stop functioning and the heat was unable to disperse out from the printer. Suggest to improve on design to disperse heat using aluminium cage in case of power blackout.
Who ever has a Brother HL-2040 should definitely use together with a UPS.
chekamal
Posted on May 12, 2008
Same thing happened to all printers in our office. They are all Brother HL-5240 and others. We turned them all on, let them sit. When they went into Sleep Mode, it cleared. Ran a test print, and they all work fine now.
Posted on Dec 21, 2010
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
HP Photosmart 7400 once switched on goes to printer busy but will not print
HI,
Please reinstall your drivers.You can go to control panel,add/remove programs and uninstall your printer driver.
Sep 04, 2008 | HP Office Equipment & Supplies
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
I have error light on. Computer won't print. I just bought the printer and it printed just fine twice. Then I turned off the power when I did not use it. When I tried to print again. the error light is...
The error light that is blinking is actually blinking out a error code. In the back of your manual under troubleshooting there should be a list.
On a printer this new about the only error you should see is a paper jam. IF anything else is wrong I'd just put it in the box and take it back. Rarely do you see something fail this new these days. It happens but not that much.
Once you look up the error code you will know what the problem is. It could be a cable unplugged or a paper jam etc. I can;t see it being serious.
Sep 11, 2011 | Brother HL-2040 Laser Printer
I have an HP c7180 all in one inkjet printer and recently we had a power outage. Ever since that time the colors are all mixed up. After the power outage, I was getting this error message: ""Ink System has...
If your product is in warranty then I recommend you to contact HP support to service or replace the unit. Otherwise perform the steps given below and verify the results.
  1. Turn on the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 7 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Oct 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Power went out and back on; now printer won't print
I had the same problem after a resent power outage. Here's what fixed mine.
Turn the power switch off.
Wait a 15-20 seconds
While holding the button on the front panel down turn the power switch on.
After the drum light comes on release the button wait then press the button again.
Turn the machine off then back on again and you should be back in business.
To prevent the problem in the future if you are not using the printer turn it off and if the power goes off while printing get the printer turned off before the power comes back.
Oct 14, 2008 | Brother HL 1440 Laser Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
May 09, 2007 | Xerox Phaser 7300DN Laser Printer
Brother HL-2040 Laser Printer Logo
612 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
