Question about KitchenAid KSB560 5 Speed Blender
My kitchen aid blender model ksb560mco is leaking when any liquid is put in the pitcher for blending. There are no visible leaks in the plastic pitcher and so I think the problem is the outside screw is loose. Please help.
  • 16 Answers
SOURCE: 40 yr. old Waring blender
plz cont -- 23051554 \ 23095757
Posted on Aug 05, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Replace the glass pitcher for the Margaritaville blender
Replacement pitchers here:
http://www.margaritavillecargo.com/Accessories.aspx
-Tha Mp3 Doctor
Posted on Mar 31, 2009
  • 145 Answers
SOURCE: I need a coupling for
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Posted on Jul 07, 2009
  • 145 Answers
SOURCE: the coupling of my kitchen
Visit MENDINGSHED.COM.
On the left, click KITCHENAID. On the next page, click KITCHENAID BLENDER PARTS. On the next page, you will see a listing for a drive coupling. You want to choose on the left, which is retailing for $5.95.
You may order the part if you need it. If not, click onto the parts order page and scroll down. There will be a two-step instructional guide on how to properly replace the coupler.
Posted on Aug 08, 2009
SOURCE: Dear Sir/Madam: We've had our KitchenAid Blender
Hi, exactly the same thing happended to me. Apparently the repair shop can replace the rubbery bit for $20 (NZ)
Jules
Posted on Jan 24, 2010
Oven will not heat up
Kitchen Aid blenders are used for chopping/blending not heating.
Apr 03, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Leaking kitchen aid blender
Make sure that the big black nut under the jar is tight. It holds the blade and bearing assembly into the beaker. The odd one can leave the factory not properly tightened up and vibration loosens it off. Nobody is telling you it will be easy to tighten that nut up because it isn't.
Mar 09, 2014 | KitchenAid Kitchen Aid KSB580 5 Speed...
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
Ksb 560 mco 5 speed blender lights flicker a as soon as switched
My Blender Model number KSB560MCO does not run. When try to blend all of red lights come one and they blink and move around. Any suggestions what could be wrong? Appreciate any help.
Thanks
Jul 30, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
My blender is leakin from the blade and coupling.can you help?I DONT WANT TO HAVE TO TAKE IT BACK IF I DONT HAVE TO. kitchen aid ksb560wh 5 speed.
I have the same blender and it's had a slow leak all the way up until today... when all of the fluid ran out of the bottom of the pitcher and all the lights on my blender started flashing. I've tried tightening the blade, but it doesn't seem to tighten... I think I'm going to have to call KitchenAid
Mar 28, 2010 | KitchenAid KSB560WH 5-Speed Blender
Seems like motor has lost power
This sounds like the black rubber coupler has broken. The teeth often get knocked off. Have a look at the part shown in hte pictures here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
Jan 22, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Leaking Blender
yes you have a defective rubber seal on the pitcher base
Apr 16, 2009 | Back to Basics Blender Solution 5500...
Osterizer Blender
You can replace the Osterizer "Standard Blade Assembly" (which includes a new rubber gasket) without buying a new and expensive glass jar. See http://www.householdappliance.com/blenderparts.html or one of the other appliance repair parts websites. After 20 years of use, it's time for a new blade and bearing.
Feb 27, 2008 | Blenders
KitchenAid KSB560 5 Speed Blender Logo
908 people viewed this question
Top KitchenAid Blenders Experts
eyecam
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
