Question about Maxtor Hard Drive
I put the pc plug into the hard drive and it burned it out what do I do?
  • 724 Answers
WHAt?
Posted on Aug 19, 2010
I have just bought 2.5 inch toshiba external hard drive for my lap top and it is not working
you've probably popped it smell the connections for the smell of burning,check the fuse in the plug should be 5Amp,
there easy to blow, if you don't get the USB plugged in the right way first time it sparks & shorts the ports out on the computer & if you've got the hard drive plugged in & switched on before you plug the USB in then it shorts the drive out as well.
take it back to the shop & tell them two replace it.if they won't then open the unit & take out the drive because that will still work & sell it on e-bay or put it in a desktop pc.
Sep 27, 2010 | Toshiba 120GB USB 2.0 Portable External...
Just a single question, I have no problems at the moment. Question: What is 'autoplay' doing or for?
The autoplay function sets a default action everytime you wish to do something with a media file.
So if you put a blank cd in then you can set your cd burning software to launch, or if you plug a memory card or portable hard drive you can set the pc to open the drive,or open your image viewer to view pictures.
If you have not set your autoplay functions, a box will usually just pop up asking what would you like to do
Aug 14, 2010 | Western Digital (WDXB1200BBRNN) 120 GB...
Child has plugged in laptop extension by mistake and now it won`t turn on,is it repairable as 120 photo files are on it
You could try removing the drive from its housing then plug it into a working pc's secondary hard disk slot, it may be just the casings's power supply which burned out. Alternatilvely buy a usb to ide or sata lead and plug the drive into an old pc power supply. then plug into a working pc via usb.
Mar 25, 2010 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
Hard drive stopped working after plugging wrong adaptor.HELP PLS!
i think that the usb interfacing corrupted so you have to open the cage and take the hard out and connect it to new usb interfacing cage
Jan 03, 2010 | HP (EK423AA) 300 GB Hard Drive
Hard drive will not burn but will play
Check that on the side of the drive that it has a "compact disk rewritable" logo on it.
Oct 17, 2009 | Toshiba Satellite A205-S4617 Notebook
Cd burner makes blank cds
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Jul 07, 2009 | Dell Dimension 4600 PC Desktop
Power Supply possibly bleuw up due to overload
Bring it to a PC repair centre, the disk inside the case may be okay and may be able to be read if its removed and put into a PC. Worth a shot.
May 17, 2009 | Western Digital My Book Essential Edition...
I purchased a Dazzle DVDRecorder to convert our home 8mm tapes to DVD's. It seems simple enough. I plug the sound cables & video cable into our video camera and then into the Dazzle. I put the...
your pc may be struggling memory and processor wise especially if you have under 1GB ram fitted, as other applications will be taking u your ram also.
So instead of burning direct to dvd drive burn the dvd image to your hard drive first,(remember about 1 hour of video takes about 10GB of hard drive space) then burn it to dvd, so as your pc is only doing one task at a time
Aug 21, 2008 | Computers & Internet
How to install a second DVD writer in an m8300f
for first dvd drive you have to put master jumper and for second you out slave then both drives work
Mar 21, 2008 | HP RT917UTABA - HP Promo dx2300 micro...
Wanting to change Hard Drive
if you take the case off you will see where the hd is on the ribbon their should be a spare conector like the one that goes into the one already installed and you will also need a power lead there should be a spare one any way plug the other hard drive in aswell as the one you are using then switch on with both hard drives in then when you goto my computer it should let you pick other hard drive alternatively take your hd out and put the old one in on its own boot your comp up and then save what ever you need to then take it back out and put yours back in this is ok todo and wont affect anything on your computer hope this is some help to you
Nov 19, 2007 | Dell Dimension 3100 PC Desktop
Maxtor Hard Drive Logo
23 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
