Question about Western Digital 250GB ELEMENTS EXTERNAL USB 2.0 250 GB Hard Drive
Sending file to external drive was always very quick. now it has slowed down so much, it's gone from 2 seconds to 3 minutes.
  • Western Digital Master
  • 27,725 Answers
Make sure that all leads that attach to your external drive are secure and are not faulty and there is enough room on your drive or add them to a zip file before transfering them
hope this helps
Posted on Aug 07, 2010
It has been only 3 months since i bought my transcend portable 500 GB.up until now everything was fine.but now i'm facing some problems with coping files.when i copy files from external to internal...
Try to defrag you external hard drive, cek your hard drive wether there a bad ?
sometimes bad cluster can running slow for copying your data or else.sorry my english is poor.thank anyway
Jun 25, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Tip
MICRO SD CARD WILL NOT FORMAT
If you cannot format an SD card on your PC or external device, retry choosing the exFAT format from the drop down menu (File system box) on windows, then format your SD card using this choice, then format again using fat32 format, this just worked for me and saved my SD card from the bin
1. Double-click My Computer, or Computer (for Vista and Win7)
2. Right-click the drive letter associated with your memory device, then select Format.
3.Select File system format drop down menu to be exfat.
4. Select quick format.
5. Select start.
6. When formatted, repeat steps 3 to 6, but this time select Fat32.
What is exFAT format?
exFat is short for Extended File Allocation Table. exFAT is a file system designed and used by flash drives.
exFAT is not used and was not designed for formatting hard drives. It is only recommended in flash memory storage and other external devices only.
on Nov 02, 2017 | Miscellaneous
External WD 1TB. I cannot retrieve my files it says Parameter is incorrect when that is gone It shows there are no files on my HD and there are plenty of files all psd files as well
I'm sorry to say that this may be due to a corrupt HDD. WD Hard drives tend to die far too fast (I know too well unfortunately).
If this is under warranty, I would call up WD support service for a free replacement.
If you want to take more invasive steps, I will be happy to help you try and recover your files.
Feb 23, 2011 | Western Digital My Book Essential 1TB...
I have a wd my pasport 320 gig. just about 2 months old. suddenly, it slowed down copying files. real slow. like about 1-2 mb/sec. i dont kno wat hapened. everytime i copy a file, it stops halfway then i...
First thing you should check is: is it full? Having an almost full hard drive can slow it down drastically.
You could also try adding files to it from a different USB port as some might not be powerful enough for your hard drive.
Jul 30, 2017 | Western Digital My Passport Essential...
Would like to erase 150gb maxtor external drive and start over
Connect the drive.
Open "My Computer".
Right-mouse click on the icon for the Maxtor.
Click FORMAT.
Choose Quick-Format.
When it completes (in a few seconds), all the files on the disk will be "gone",
because a "blank" Table-Of-Contents has replaced the previous Table-Of-Contents.
Dec 20, 2010 | Maxtor OneTouch II external hard drive...
Please tell me how to retreive files from a broken external hard drive. It spins up, and sometimes a computer will recognize it but not often. Is there a way to jump-start it?
your best bet way true and tested, is to disassemble the "CAGE" take it out it will be a sata hard drive if your computer supports sata continue. Anyways put it in 2 ziplock bags 1 inside another. Freeze it for about 3 days or so in the freezer take it out quickly plug it in and turn on the computer. you will have about 10-15 minutes to get any files you want off of it. before it starts to act up again.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
ASUS P4S533-MX hang up and not available second IDE
Turn the computer off unplug your second IDE device reboot your computer and see if it fixes they hang up and slow run if it does fix it then it is most likely your hard drive is toast
Nov 22, 2017 | ASUS P4S533-MX Motherboard
External HDD not recognized after a time of inactivity
you are guessing right... this is caused due to system going in standby suspend mode which powers down the HDD ... and when the system comes back from suspend mode... the win vista thinks no external HDD is attached to the system ... thereby removing it from the devices list.
right click desktop select properties and select screensaver tab and then power options. select turn off the hard disks and select never. this is for winxp .. but it will be similar to this procedure in vista.
Aug 06, 2009 | Iomega 1.5TB Desktop USB Hard Drive
I have a Dell 5200series(Ithink) w/Windows XP -is 5 yrs old - 28GB on hard drive w/approx. 18 GB available.I recently added 512KRAM to go along w/existing 256K RAM - I am on dial up - Ihave used Reg Cure...
Hi 1MLucke51,
Thanks for the posting in FIXYA.
Please can you tell me the Dial up connection speed.
Please delete all Prefetch files, Temporary Internet files, Temp files , and then empty recyle bin.
How to Do:
Step 1: Delete the prefetch files from time to time.
Click on start ..run .. type .. prefetch
ok
Select All and delete
Step 2: Delete temp files
1. Quit Internet Explorer and quit any instances of Windows Explorer.
2. Click Start, click Control Panel, and then double-click Internet Options.
3. On the General tab, click Delete Files under Temporary Internet Files.
4. In the Delete Files dialog box, click to select the Delete all offline content check box , and then click OK.
5. Click OK.
Step 3: Temp Files
Click on start .. run .. type
%temp%
ok
Press Ctrl + A key and delete all files
Note: Skip if some of files not delete and warn by computer.
Then Empty recycle Bin
Regards
Ellin
Sep 12, 2008 | Computers & Internet
Western Digital 250GB ELEMENTS EXTERNAL USB 2.0 250 GB Hard Drive Logo
141 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
