Question about Whirlpool Duet GHW9150P Front Load Washer
I have standing water inside the washer. What causes it and is there a fix for the problem? fullstringer41@yahoo.com
  • 712 Answers
If you can see a **** in the outlet pipe when you give the command to pump off the water, then most probably your outlet pipe is blocked. Try to remove the block and check again.
Posted on Aug 07, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Water standing about 2inches dep after cycle
Under your washer, you have a drain. See if the piece under the washer is broke and causing it to back up.
Mar 03, 2011 | Bosch Dishwashers
Water runs into drum after wash is done
You have a bad water valve inside the washer. Turn off your hot and cold water valves. Your water valve inside the washer has gone bad. What happens is the valves open and close there is suppose to be a filter screen on both hot and cold inlets where you connect the water hoses to. If not the de brie from the water line gets in there and clogs it up leaving the valve open which is causing your problem. Also seen it where people on well water have this problem a lot because the water might be hard. You can have a qualified technician come fix it wont be to expensive don't call sears they will rip you off or you can do it yourself if so here is my email address and I will tell you how to change it out steen24@yahoo.com good luck and I hope this helps.
Jan 06, 2011 | Maytag Atlantis MAV6000 Top Load Washer
LSR8233JQ0Washer won't fill
The water is syphoning out the drain hose.
Many times when the stand pipe is backing up someone will seal the washer drain hose to the pipe to avoid overflow of the stand pipe.
This causes the water to syphon from the washer.
Or the opening for the stand pipe is just big enough to put the drain hose in and is to tight causing the syphon.
Putting the drain hose to far down the pipe can cause a syphon also.
Jan 20, 2010 | Washing Machines
Smells like sewer when washing clothes
Washing machine mold / mildew odor is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned. After the washer has been cleaned your washing habits must change to eliminate what is causing the smell. Go to www.smellywasher.com and fill out the "washing machine help" questionaire to get sent advice on what to change to remove the odor and to keep it away.
Oct 05, 2009 | GE WSXH208A Front Load Washer
My Jenn-air side-by-side refrigerator is leaking water from the freezer side (left as you stand facing it. When I open the freezer door, the ice is half an inch thick on the bottom of the freezer and has...
I am going to assume you have a defrost condensate blockage in the rear of the freezer and behind the rear panel where the evaporator dreains condensate after each defros. Please correct me if I am wrong.
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 26, 2009 | Refrigerators
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Top wand does not spin
You may have a water volume problem.
The water fill sequence on most washers is timed. Insufficient water at the bottom of the washer will cause the pump to cavitate.
Ensure water is filling to just under the heating element.
You can fix this by isolating the water and electricity then remove the fill solenoid. Inside the solenoid is a top hat filter screen. This screen captures sedement.
Once the sedement was removed on my washer the wands turned
My machine also had a check valve on the bottom near the back of the machine that was blocked.The valve needs to work freely in order for the pump to build pressure. The check valve can be removed from the top by turning the assembly counter clock wise.
Feb 01, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Jan 27, 2009 | Neptune MLE2000A Front Load Stacked Washer...
Whirlpool Duet GHW9150P Front Load Washer Logo
180 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
