Question about Dryers
Does thermostat internal bias have orientation? Which terminal does red/white wire connect to on thermostat internal bias?
  • 347 Answers
No it does not will work both ways
Posted on Aug 08, 2010
I have 4 wires from my old analog thermostat. Red, blue, white, and green
Look closely at the wire terminal screws on the thermostat. There are raised letters telling you what color wire to connect to it. be careful not to touch the red wire to the others. You can blow the internal fuse on the 24 VAC transformer that supplies the voltage to the thermostat.
Mar 07, 2016 | Honeywell RTH221B 1 Week Programmable...
I have 4 wires green blue red and white my red is connected to the rh rc with jumper green connect to g blue to y1 and white is connected to w1 my new thermostat has no rc rh or a jumper
Paulette, if your new thermostat has no Rc and Rh thats fine. The Red wire should simply go to the R terminal. The Rc and Rh terminals on the old one was for the old 'two transformer' systems. The vast majority of systems now have no need for the Rc Rh terminal and jumper. The rest of your wires connect as on the old stat also.
Jul 31, 2015 | Heating & Cooling
Where do thermostat wires connect to outdoor a/c unit nordyne s3qa series
I cant see your cable or terminals, I don't know who made the A/C or thermostat - so it's hard to know for sure.
You could look at the other end to see which terminals the red and white wires are connected and connect them to the same terminals at the other end.
Otherwise, they are wired to follow a color code. Red wire to the "R" terminal and White wire to the "W" terminal.
Jul 20, 2015 | Heating & Cooling
How do I wire a Honeywell thermostat
Can I start by saying I am not in anyway saying to do this alone it is dangerous but if u must follow each step start by being safe shut off the breakers good luck here to help
Step 1
Turn the air conditioning and heating unit off by flipping the appropriate circuit breaker. Test the unit to make sure it's off by turning your existing thermostat to the "On" position and seeing if it turns on. Wiring a Honeywell thermostat when the circuit breaker is on could cause you to blow the transformer that powers the HVAC unit Step 2
Connect the red wires to the thermostat RH, thermostat RC or thermostat R terminal. The thermostat RC terminal has a jumper wire between thermostat RH and thermostat RC. The thermostat R terminal operates both the heating and cooling units, and contains an internal jumper wire. Basically, your red wire on a Honeywell thermostat is the hot wire that run. Step 3
Run the green wire to the thermostat G terminal. The green wire controls the relay that operates the blower, and it controls the fan. Step 4
Control your air conditioning when you connect the yellow wire. It connects to the thermostat Y terminal Step 5
Hook the white wire to the thermostat W terminal to control the heating unit
Nov 20, 2014 | Heating & Cooling
Hi Proper way on wiring furnace.
I can give you a start, For heat only, R terminal on furnace to Red wire to R or RH terminal on thermostat. W terminal to White wire to W terminal on thermostat. G terminal to Green wire to G terminal on thermostat. This will get you heat but not air conditioning.
Jan 06, 2010 | Goodman Heating & Cooling
Two wires for thermostat (honeywell ct31) red and white, for heater only. where do they connect on thermostat?
The red wire goes to the R or Rc terminal on the back of the thermostat. The white wire goes to the W terminal on the thermostat.
Dec 31, 2009 | Heating & Cooling
Trying to reconnect an old thermostat. The wires on the thermostat are yellow, white and there is a jumper wire between two points. There is a G which I presume is ground. The wires coming in are white,...
G (green) = fan
w (White) = heat
y (yellow) = a/c
r (red) = power
Connect white to w terminal and red to r terminal on t-stat since we know they are right, then touch one green to red r terminal if fan starts that is G or (green). If a/c Outside unit starts then that one goes to y terminal on t-stat.
Nov 03, 2009 | Heating & Cooling
A duo therm thermostat (p/n 3105058) was removed because it would not operate the air conditioner/heater in a firan fireside camper. it was knocked loose from the wall damaging it.the thermostat is for use...
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
The dryer will not start
thermostat would not cause it not to run if the white thermal fuse has continuity ck the door switch to be sure lever is not broke also ck breaker after switch timer most logical but unless you know to ck best not just guess could be expensive
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
What coloured wires go where on the main oven thermostat
If you are speaking of the 240v connection to hook up the oven to the electrical source, then white is the neutral(white to white), black is one of the 240v hot wires(black to black), and red is the other 240v hot wire(red to red).
Finally there is a bare or green color ground wire that goes to the bare or green wire form your source.
normally, the two outside wires on a terminal strip are the hot wires and the middle onif the neutral(white). It does not matter which wire(red or black) goes to what hot terminal at the appliance.
If you are talking about the internal wiring, I can get you a schematic of that.
Mar 13, 2008 | Ovens
Dryers Logo
63 people viewed this question
Top Dryers Experts
Marvin
Marvin
