Question about Matrix Okidata Microline 320 Printer
I have a brother m 1409. It will do a test print, but I can't se try em to get it to work using m 1309 driver. Is there another compatible driver I should try on windows xp thanks, Lindsay lindsay.foster@gmail.com
  • 10,421 Answers
Have two Brother DCP-145C printers and use compatible inks. Now the yellow won't print in either machine. Despite trying cleaning cycles and replacing the yellow cartridges, the test print will not show...
100% you need to replace the print head,in the future use only original cartrige brother not refill or compatible cartridge.If you want to replace the print head you need to take care is difficult to change the print head,you must to unzip the all printer.If a have been useful please give me a vote.
Mar 22, 2011 | Brother DCP 130C All-In-One InkJet Printer
MFC_5840CN Will not print, not showing
Typically, a Brother machine stops printing, because the connection between the computer and the Brother machine is lost. There are multiple reasons for a lost connection.
  1. The Brother print driver is Offline.
  2. The Brother printer driver is not set as the default printer driver.
  3. The computer, not the monitor, connected to the Brother machine is set to go into sleep or standby mode. When the computer goes into sleep or standby mode, the connection between the computer and the Brother machine is lost and needs to be re-established.
Follow the steps below in order to re-establish the connection between the Brother machine and the computer:
  1. Verify that the Brother machine is connected with a USB cable and is not on a network.
  2. Verify the power cord and USB cable are securely connected. If the USB cable is loose on either end, disconnect and reconnect the cable securely. Test the machine by trying to print. If the machine does not print, go to STEP3.
  3. Cycle the power of the Brother machine by unplugging the power cord from power outlet, wait approximately one minute and plug back in. Once the Brother machine displays the date and time after plugging it back in, test the machine by trying to print. If the machine does not print, to Step 4.
  4. Reboot the computer connect to the Brother machine and then try to print again.
Apr 01, 2008 | Office Equipment & Supplies
EM-530 - suddenly the "j"
First, be sure you are using a Brother compatible daisywheel. Some other manufactures' daisywheels "look" the same but the charters are in different order, so they will not function properly.
If you have not changed the daisywheel, the next thing to check is that the wheel is correctly installed. The easiest way to check it is to remove and reinstall it. To do that;
1. Open the top cover.
2. On the right side of the hammer (the metal piece that strikes the daisywheel) there is a small lever (see attached figure). Pull that locking lever towards you to release it.
3. Remove the cassette that holds the daisywheel.
4. Reinstall it, making sure that you lock the lever towards the paper roller.
5. When you close the top cover the carriage (otherwise known as the print head) will move to one side and do a procedure known as "Homing."
6. Test the machine. If it is still mistyping, continue with the next part. Continued in part 2
Dec 19, 2010 | Brother EM-530 Typewriter
Have new PC running Windows 7. Old DCP110 printer is working but print is very faint, can't read. Top bar with computer info prints normally . . . can I print a test page with old software?
Hi vt_mail.
As i can see Brother don't have a Win7 driver for the DCP-110C, but anyway it should run without any problems on Win7.
(se this link: http://www.brother-usa.com/lp/windows7compatibility.aspx#WinUpdate)
Maybe you should to take all toners out, and put them back again, or replaced them.
Sep 30, 2010 | Brother DCP-110C All-In-One InkJet Printer
Need driver compatible with Brother 1440
I tried HP Laserjet IIP and it works. Thanks for the help!
Jul 28, 2009 | Brother HL 1440 Laser Printer
I need manual for brother EM-530 typewriter
Go to http://www.brother-usa.com/typewriters/. Click on "Manuals." Select "Typewriters", then select your model number in the drop down boxes. Click on "View download." Click on the "Users Manual - English" and the manual will open in Adobe as a PDF file. Print it or save it to your computer for future use.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 17, 2009 | Brother EM-530 Typewriter
MY OS IS WINDOWS NT, AND MY PRINTER IS MFC240C, CAN I MAKE THE PRINTER WORK ON WINDOWS NT ... PL ADVISE...
read the package box of your printer. If it has windows NT printed on it then you can, because it needs compatibility driver to run your printer. But if it is a desk-jet or inkjet you can install whether you are in NT or other os.
Dec 14, 2008 | Office Equipment & Supplies
MFC Applicaton stopped working
If your operating system is Windows 7, please try this tutorial (it's in an easy spanish): http://autorneto.com/tecnologia/gadgets/brother-en-windows-7/
Else, if you don't have this operating system, please specify which one do you have.
Hope my tutorial helps; write comments on the tutorial's page and here also. Make it known if it worked for you (only if you have Windows 7).
Good luck
Sep 26, 2008 | Brother SE-270D Computerized Sewing...
Won't print from usb or parrallel cable
check the usb sucket on the printer board and see if the legs are firm if ok check the board
Jul 19, 2008 | Brother HL 5140 Laser Printer
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
57 people viewed this question
Top Matrix Office Equipment & Supplies Experts
Dimitar Todorov
ray gallant
Tom Chichester
Are you a Matrix Office Equipment and Supply Expert? Answer questions, earn points and help others
