Question about Weber Gas Go-Anywhere Grill
How do you hook up the bbq to gas line - Weber Gas Go-Anywhere Grill
  • Anonymous Jul 17, 2008
    instructions for a sq in kenmore gasr grill lp model#
  • 36 Answers
Are you LP gas or Nat. Gas?
What kind of Grill?
Posted on Apr 28, 2008
I have a ducane bbq and am having problems reattaching the gas line to the house
If it is push pull, on the house side pull back the gas pipe ring about 1/4 inch insert gas hose and release ring. If it is threaded, turn gas hose, bbq side, ring counter clock wise and it will attach.
Apr 24, 2014 | Ducane 30400042 (LP)
Hooked up bbq propane tank and smell gas?
I would turn the gas on and spray soapy water at the fittings if bubbles appear that is where your leak is. if it is leaking in the lines. turn gas off un screw fittings and wrap them with teflon or what some call plumbers tape they are both the same thing and very inexpensive. if it is at the valve on the tank I would get a different tank
Jul 26, 2012 | Grilling
Looking for a conversion kit from Natural Gas line to a Propane line to the house (no tank on BBQ) Thanks! Tracy
you will need to change all the burner injectors and the inlet hose with a reg for tank use , I would try calgary bbq center they may have the parts you need , they are on line .
Sep 14, 2011 | Royal Sovereign Broil King Sovereign 90
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Want to convert my Capt N Cook barbeque from propane to gas. Have the gas line already to hook up to barbeque but need to know what parts I need to replace and add to accomplish this Thanks
You need Natural Gas Burner orifices and perhaps, a new manifold.Also, a 12' long rubber quick disconnect hose (that's a Code Requirement) and all the necessary fittings. Contact your local BBQ Galore for the parts you need.
May 15, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Weber Genesis Gas Grill won't heat up very high
yes the control knobs are what controls the heat, its a saftey thing on the bbq so turn off tank undo gas from tank open knobs release gas from line , turn off control knobs , reconnect gas line to tank ,turn on slowly , turn control knobs to on and light,
Jul 05, 2010 | Weber Genesis Silver B Grill
BBQ was working great last time I used. Next time
yes turn off bbq at inlet valve , open control knobs let out gas pressure or undo line after control tap reconnnect then turn on slow should work
May 30, 2010 | Napoleon Gas Grill
I require a warming rack for a Blue Ember BBQ FG50069 the part number is SP163-3
canadain tire of canadain super store , if not google make and model on line or bbq centre calgary
May 04, 2010 | Fiesta Blue Ember Gas Grill
How to connect a N.G. bbq to gas supply line?
It is probably legal for you to perform work, check local codes or call local gas company first. If you've never worked on a gasline before, I'd recommend a professional to either assist you or hire. You don't want to chance a potentially dangerous or costly mistake. And when I say pro, I don't mean the guy in the plumbing dept. of the hardware store. I'm recommending a fireplace/ grill shop or asking your gas company if they provide this service. Good Luck, but play it safe on this one.
Apr 10, 2009 | Weber Genesis Silver B Grill
Weber gas bbq
Hello stevie66, disconnect the gas tank, carefully remove the burner element (the thing with the small holes) and soak it in a bowl of vinegar overnight. Remove and shack the excess out, remount and connect the gas. Open the gas line about 1/4 turn and CAREFULLY LIGHT. Please E-Mail the results. Thank you.
Oct 26, 2008 | Grilling
Weber Gas Go-Anywhere Grill Logo
110 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
