Question about Linksys Wireless-G WRT54G Router
Why isn't my router turning on? None of the lights come on when I press the center button.
    Scholar:
  • 104 Answers
IF THE ROUTER HAS NO LIGHTS UP AT ALL,CHECK THE MAINS PLUG FUSE AND FUSE RESET IN THE FUSE BOX IN YOUR CUPBOARD,IT MAY HAVE TRIPPED.IF IT ISN'T THAT SEND THE ROUTER BACK TO WHERE YOU BOUGHT IT.THEY HAVE AT LEAST A YEARS WARRANTY.
Posted on Aug 07, 2010
No power light on, when plugged in
It sounds like you may have a faulty router. If possible, contact Best Buy for a warranty replacement (you can do that here). All routers should have a visible indication that a power source is connected. Almost none require you to press a button in order to turn on. This means to me that there is a disconnection somewhere within.
Sep 12, 2011 | Dynex Wireless-G Broadband Router
SYSTEM DOESN'T RECOGNIZE CONTROLS HOW DO I FIX
I'm guessing the issue is that the PS3 isn't responding to your controller input.
Ensure that the PS3 controller is actually on. You can turn on the controller by pressing the Playstation button in the center of the controller. There will be a red light on top of the controller indicating that it is on.
If no light shows up, it's possible that the controller simply has dead batteries. Grab your controller charge cable (should have been included with controller, looks like this) and connect the controller to the PS3 while the console is on. Give it a few minutes, then press the center Playstation button again and see if it responds.
It's also possible that the controller just isn't synced to your PS3. Again, grab the charge cable and connect it to your PS3 while it's on. Then press the Playstation button while the controller is connected. It should sync it to the PS3.
If none of that is working for you, there may be an issue with the controller itself. The easiest fix it to reset the controller. There should be a tiny button in a hole on the back of the controller. Just press it (you'll need a paperclip or something to do it) and the controller will reset. I believe you'll have to re-sync the controller (using the cable again).
You should also try syncing other controllers to your PS3 to make sure that the issue isn't with the PS3 itself (which would be awful; I've never heard a PS3 breaking like that but I suppose there is always a first). If other controllers work then either your controller's battery is dead or the controller is actually broken. I don't think Sony repairs/replaces controllers so you may have to buy a new one.
It may be worthwhile to checkout their support page first, to see if anything helps before shelling out 50$ for a controller:
Sony Support
Sony Repair
Amazon - PS3 Controllers (I recommend Silver; it's ****).
Hope it all works out!
Sep 01, 2011 | Sony Playstation 3 (PS3) Console
My wireless isn't working but mywired conection is it has been a problem for over 3 days.
make sure that the wireless button has not been pressed by mistake turning off the wireless! If thats not the issue try rebooting the router, if that dont do it, try reseting it to factory specs!
Jul 16, 2011 | Belkin F5D8236-4 Router
My Linksys-G power light is blinking and will not recognize connections. the power light is the only one on (blinking) and none of the others light up at all.
A blinking power light indicates it is/has failed the self test and needs repair. Before you replace it, you can try and do a factory reset (you'll have to go back in and reset all of your settings after you do this - if it works). To do a factory reset, press and hold the reset button on the back (with power applied) for 20 seconds. If this does not get your router working, you'll need to replace the router as a new router will probably cost less than repairing this one (unless it is still under warranty).
Mar 17, 2011 | Linksys Wireless-G Broadband Router
How do i reset
The first method involves using the reset button that is located at the back of the router. It isn’t hard to reset the router this way, but does require physically being in the same location as the router.
To reset the router using the reset button, use these steps:
  1. Look for the red reset button at the back of the router.
  2. Press and hold the reset button for approximately 5 seconds.
Aug 31, 2010 | Linksys WRT160N Wireless Router
I lost the passwork for my Toshiba router Model No. PA3227u-1etc
You can reset the factory defaults, then login using the original username and password.
To reset the Wireless Routing Center to factory defaults, insert a straightened paper clip into the Load Default hole on the back of the router to press the button. Keep pressing and turn the Wireless Routing Center off and on. Wait for at least five seconds before you release the button. Then wait for the Wireless Routing Center to finish booting.
By default, the user name is admin and the password is password.
Jun 06, 2010 | Toshiba WRC-1000 Router (PA3227C1ETC)
How to use the AOSS?what button will I press?
I believe it asks you to hold down the PS button. That is the button on the center of your controller with the Playstation logo.
All you do is go to network settings .....Internet connnection settings, select easy, Wireless, Scan, It will find your router and its settings....After you get through the router stuff it will come to WLAN security settings.....just click none, press x to save your settings then test. everything should hook up then.
May 02, 2010 | Sony PSP (Piano Black)
Ethernet the only light working
Reset your router .
Press reset button for 15 seconds then all settings are reset to factory defaults.
Then check let me know.
Jul 27, 2009 | Zyxel P660HW-D1 Router
Problem in setup wireless router,need default security key/phrase
If there reset the router to the factory settings:
Default Username: admin (lowercase)
Default Password: none (none, leave blank)
If this doesn't work, try pressing the reset button for 10 seconds with it powered ON. Then try it off. I can't remember which one will work.
After this is complete, username: admin and password: (nothing, blank, nada) will work.
Good Luck!
Apr 07, 2009 | Hawking 54M WIRELESS G ROUTER AP 4PORT...
Linksys Wireless-G WRT54G Router Logo
59 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
