Question about Boating
What are the torque specs for a 1995 evinrude 25 hp outboard engine?
3 Suggested Answers
captainjeffq
  • 52 Answers
SOURCE: 1977 115 hp evinrude outboard water pump problem
Depending on the year motor, make sure the throttle is in the neutral position, drop the lower unit and the motor foot should come off, will probably take some wiggling and with the age of the motor, possibly a few light taps around the cavitation plate with a mallet would be helpful.
Posted on Apr 14, 2009
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
I need to know the specs on an evinrude outboard motor serial # 3030-07926
Everything in marine outboard engines is tied to MAKE and Horsepower. From that, you can find the year using the serial number. Once you have those, you can Google
year make model specs
or
year make model manual
Evinrude Outboard Motor Model Numbers
Jul 30, 2017 | Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
How do i fit a rectifier to a 2013 25hp evinrude 2 stroke???? Rectifier-4wires-2go battery & 2 go AC lighting coil system. Need to identify were to connect my 2 coloured wires from rectifier????
This is what Johnson say;
Technical Contact Information
We Take Your Boating Pleasure Seriously!
Your selling dealer has a special interest in your satisfaction and should be consulted first if you have any concerns about your Johnson power product. Your authorized Evinrude dealer is your primary contact for service, product information, and Evinrude and Johnson® Genuine Parts.
Protect your investment. Please read your owners manual for all operation and maintenance information for your engine. It lists all the adjustments and routine maintenance procedures for your motor, including off-season storage and pre-season service. We encourage you to work with your authorized Evinrude dealer for all the services you require.
If you have a concern with your engine that your dealer is unable to resolve, please have your engine model number and serial number available, and contact us.
Ta
Take a look at these videos though.
https://www.google.ca/search?q=25+hp+evinrude+2+stroke+rectifier&rls=com.microsoft:en-US:IE-ContextMenu&source=lnms&tbm=vid&sa=X&ved=0ahUKEwjVu_XQ2ZnLAhVMQCYKHbMwBnoQ_AUICCgC&biw=1600&bih=729
25 hp evinrude 2 stroke rectifier Google Search
Feb 28, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
I need information on an evinrude outboard unsure of year or HP serial number is 4416-03315
Sounds like it could be an Evinrude Sportsman model 4416. Here's the info I found online:
  • Model: Sportsman - 4416
  • Make: Evinrude Motor Co.
  • Inboard/Outboard: Outboard
  • Engine Type: Gasoline
  • Production Date: 1947
  • Engine Design: Two-Stroke
  • Horsepower: 2.0
Check google search for pictures and more info on it!
4416 evinrude Google Search
Jun 16, 2015 | Boating
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
25 hp evinrude outboard engine model number e25reda serial number g04126134 what year is this
check here http://shop.evinrude.com/media/document/ModelNumberReference.pdf
Jul 26, 2014 | Boating
Boating Logo
169 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
