Hello, I have a Maytag Bravo Top Washer. Lately I have been getting a F1 code when I start the washer. What does that mean?
  • 347 Answers
Control board issue
Posted on Aug 07, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Ol code cabrio
    "oL" error code, even when unloaded - Fixitnow.com
    fixitnow.com/.../whirlpoolkenmore-cabrio-and-maytag-bravo-washers-th...
    Sep 18, 2010 - The "oL" error code in the Cabrio and Bravo washers means the ... is almost always caused by using non-HE detergent in this washer- see this ...
    Aug 17, 2015 | Washing Machines
    F1 off balance how do I balance my bravo washer, to get it back on balance?
    Their could be objects between the tubs, remove the inner tub nut under the agitation device and lift out the tub. look for objects in there. Also the inner basket has a balance ring in it.
    Service manual and failure codes
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Jun 20, 2011 | Maytag Bravos MTW6600T Top Load Washer
    F1 flashes on my maytag bravo washer
    This is an inherent problem with this Whirlpool-made top load washer and at first it is believed to be a machine/motor control fault. But it was found later that it can be due issues associated with the pressure transducer/switch system. Air leaks and moisture in the pressure hose including lints or flashing in the air dome can lead to signal error being sent to the machine/motor control assembly and it is interpreted as a machine/motor control fault. You may also observe that the fault code F1 appears usually during water filling at the start of the wash cycle and/or at the start of the rinse cycles.
    Check the pressure hose for air leaks and moisture including the air dome. Replace the machine/motor control assembly if no issue is found with the pressure hose and the air dome. Click on the link below for the troubleshooting and repair instruction details.
    Troubleshooting Fault Code F1 on Whirlpool Cabrio, Kenmore Elite Oasis, and Maytag Bravos Top Load Washers
    Jun 17, 2011 | Washing Machines
    My Maytag Bravo washer starts, then stops and displays a F1 code. I turn it off and restart it several times before getting beyond this. What's the solution?
    The solution is easy. Remove the screws in the back and find the pressure tubing from tub to the control. Remove it and blow through that tubing to get the sand and sediment out of their. Re attach the tubing and retry. I have more:
    F-1 Error Solution
    Bravos Washer Error Codes
    Feb 03, 2011 | Maytag Washing Machines
    Yes i did thank you but what if i did a rent to own my bravo and i have the f1 code
    The F1 error code indicates that the water level pressure transducer signal is out of range on the machine control board. A pinched or kinked air pressure hose between the bottom of the washer tub and the connection on the machine control board can cause this. A failed control board (the pressure transducer is integrated into the machine control board) can also cause it.
    Jan 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
    Continiously have to hit the pause and start buttons to make it w
    Hello there"
    This could be a fairly simple fix or a kind of expensive fix but here is somthing to check out first
    Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
    Jul 06, 2010 | Maytag Bravos MTW6600T Top Load Washer
    My maytag bravo top loader washer is displaying a code of LF and
    it meant "low flow" check water connecting lines. mine has the same problem.
    Dec 02, 2008 | Primera Technology Bravo (Refurbished)...
    Washing Machines Logo
    60 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
