Question about Polaroid FLM-3732 Television
My polaroid flatscreen tv randomly turns off and on. It will usually stay on for about 10 minutes then turn off for a while. What could be causing this problem. model# 3700 product #FLM3732 manufacture date - March 2006
  • 155 Answers
SOURCE: polaroid lcdtv flm-373b
its the problem in the power supply board of your tv. any of the capacitors or ic are loose on the board.check it out and make it proper,
Posted on Oct 26, 2008
rylee_smith
  • 8619 Answers
SOURCE: Polaroid 4641-TLXB LCD TV won't turn on
Hi!
First of all please unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino affect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem and for proper repair all the electronics must be diagnosed with the correct electronic test equipment and the correct skills to use the test equipment.
If you want to repair it yourself then you must be having an oscilloscope and has a knowledge to operate it.
If you decide this is not something that you can do it yourself then this repair will be about $100 to $300. If the problem is a bad circuit board, and if the board can be repaired or has to be replaced. A small TV repair shop will often charge less for the repair than a large electronics repair facility.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 24, 2009
techman007
  • 1112 Answers
SOURCE: Polaroid 3700 lcd (2006): Every time it is turned
Hello: This is a problem with the power supply unit, There are two capacitors that need to be replaced in this unit. They are the two 1000uf 10V Capacitors that is failing on the power supply, If you take off the back there is a metal module in the center of the unit, lf you open it the power supply is located towards the upper part of the system. Look at the capacitors for puffy and swollen tops, just in case you don't know what capacitors look like they look like tall batteries mounted vertically on the board with metal type tops. If you run your hand across the top of them they should all be flat. Look for the two swollen ones and replace. The Value on the Capaictors should say around 1000uf at 10V. Replace with 1000uf at 16V. The reason you television is malfunctioning is that these caps are leaky.
Posted on Nov 08, 2009
Testimonial: "Your solution was exactly right . The only thing that was confusing was the part about the capacitors being mounted vertically . It is fixed. Thank U "
Raider2845
  • 11 Answers
SOURCE: I have a Polaroid 37" LCD TV (FLM3732)
I had posted some vids on youtube a long time ago about how to fix this. You can search flm3732 repair or go right ot my channel to watch the 5 short vids. www.youtube.com/raider2845 Hope it all works out for you. Good luck
Posted on Dec 25, 2009
  • 192 Answers
SOURCE: I turn the TV and nothing. A black screen. The
I suspect you may have 2 capacitors in your control module that need to be replaced. When these caps start to go bad it will often show up as a problem with the sound. However, when they get really bad they can prevent the TV from turning on. Please see the link below, posted by stiv0. It gives detailed instructions on how to replace these caps and to tell if they're getting bad. If you follow these instructions you can take the back off the TV and check out the caps. If the tops of the caps are bulging they need to be replaced. Just be sure to replace them with the correct value (1000uf) and use caps that are rated at a higher voltage than the originals. I replace the 10v caps in my FLM 373B with 30V caps just to be on the safe side. If you know how to solder this is an easy and inexpensive fix. If you don't know how to solder find a friend who does. These caps have positive and negative terminals. It's important you solder the new caps in with the correct polarity. Stiv0 gives instructions on this. Even if the caps aren't bulging this fix is so inexpensive, less than 10$, that you may want to try it anyway. I hope this helps you out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Feb 09, 2010
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Tv screen flickers then turns black. has sound but is very faint.
The power supply may be failing, leading to video instability.
Nov 01, 2017 | Polaroid Televison & Video
Tv has sound but no picture
I had similar problem with my Polaroid 42 inch. The screen would be fine for 10 minutes or so then go black. I found a work around that solved my problem and maybe you can to. What I did was remove the back panel of the TV. Make sure it is unplugged first. You should be able to see the electical board. Somewhere on the board may be a switch that says "Burn" or something with "Burn" in it. I set the switch to the "Burn" setting and the TV has worked fine ever since. Good Luck.
Sep 29, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid flatscreen picture does not stay. When the tv is turned on, the picture will last a few seconds to a few minutes.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 13, 2009 | Polaroid TDX-02610B LCD TV
Fixes for a Polaroid TV thats not turning on
Hello:
37 inchs have a television of the problem is that it works like 10 minutes and turns off the image, has sound but no image, turn off and on again returns to normal work and 5 minutes the picture goes but still sound, can you help?
Oct 20, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Buzzing TV- Polaroid 37" FLM-3732
i fixed one by put 2 new caps in c112 and c113 1000uf 10v
Jun 13, 2009 | Polaroid FLM-3732 Television
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Polaroid TLU 03711C - HD LCD flatscreen TV 37
I wrote a guide on how to fix this problem. It's really easy to do and only costs £1 (about $1!). You can view, download and print the guide here - http://www.scribd.com/doc/13515584/Polaroid-TLU03711C-Replace-Capacitors-Guide
Oct 16, 2008 | Televison & Video
Televison & Video Logo
117 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
