Question about Samsung Computers & Internet
DC power cable for newly purchased samsung P277OH monitor will not "hold" keeps being forced out by something inside the port i assume.
enuro12
  • 116 Answers
SOURCE: AC-DC power converter for Samsung SyncMaster 191T Flat Panel Monitor
According to all the specifications on the web that has built in power. You should just need a standard PC power cable.
Maybe the SN on the monitor would help to locate what you need.
Posted on Oct 10, 2007
SOURCE: SyncMaster 920n Power Cable (?) Issues
I think my monitor power connector broke too
Posted on Feb 23, 2008
RescueTechLA
  • 2653 Answers
SOURCE: broken power port (dc jack)
Whenever I replace dc jacks, MAJORITY of the time the entire computer needs to be taken apart down to the motherboard.
Usually I just remove every screw that I see and then carefully start to pry pieces off the laptop. Don't force anything though, everything should come apart with minimal effort, as long as the screws are out.
If you're going to attempt this repair yourself you're gonna need to set aside about two hours to complete it.
You'll need:
a soldering gun
solder
solder wick
Make sure you have a big, flat, clean workspace to work on.
If you have a camera it might help to take pictures along the way. At the very least keep track of where the screws go.
I usually separate them into two categories: outside the laptop and inside the laptop.
It's not the easiest thing to repair for the home user but you can do it if you've got the patience.
Hope this helps.
Best of luck!
Hope this info helps.
Posted on Mar 04, 2009
seanpwright
  • 2030 Answers
SOURCE: My screen keeps flicking.. There is a slight
Thast is exactly what you may need
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Nov 13, 2009
eagle338
  • 4889 Answers
SOURCE: LCD monitor runs on 220V
Your question: "LCD monitor runs on 220V 50 Hz power line. Inside the box is the power converted to 12/5V DC?"
Only in a few that have an adapater . If there is no adapter between the mains and monitor then no.
"LCD monitor has vga port. Inside the box is there a vga to LVDS converter?"
Please explain what is this box that you are talking about.
"LCD monitor has vga port. Inside the box is there a vga to LVDS converter?How an lcd monitor (easily available in the market having vga port) can be use with LVDS out of the mother board? "
Well most motherboards have a DVI or VGA port for output. LVDS cable is the one they use in laptops to connect the GPU(graphics processing unit) or graphics card to the LCD. Unless you are using a laptop monitor as a screen I don't think you need an LVDS cable. Desktop motherboards do not have an LVDS port as far as I know.
Posted on Nov 01, 2010
DVI no signal keeps saying check video cable i have
If it worked before and suddenly doesn't work now it could be a bad cable. kinks in the able can be a problem but also when you plug-in the cable be careful because damaging the cable end or the the cable port is easier than you may think.. first replace the cable with one that you know works on another unit ..if that doesn't work examine the ends carefully for anything out of the ordinary.. get a technician to take a look if something seems strange with the cable end or the port..DVI cables come in several flavors make sure your using the right one and don't force the cable in that could make matters worst and more expensive....good luck..!
Sep 24, 2011 | HP w1907 LCD Monitor
Samsung nc10 screen goes black. its power on i can see only a dark screen and a little image on the screen
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | Samsung NC10-14GW Notebook
Good Morning, My monitor keeps blinking and on the display you can see it keeps switching from analog to digital, i am using a dvi cable, and it is set to digital via the monitor, the weird thing is it...
My samsung monitor model 2233SW PLUS keeps flashing on and off and if i press the side button a menu type magic bright comes and shows whether to change in cinema ,custom ,text,internet mode etc,and when this option comes it doesn't flash and after 10sec this option goes off then again it keeps flashing in 5 sec. and the menu option doesn't come if by chance it comes than again for 2 to 3 min it stops flashing sometimes for 5 min .please help good-morning-monitor-keeps-blinking-orr1pjn3khwbyjvnsjgmppfg-5-0.jpg
Sep 03, 2010 | Samsung SyncMaster 213T 21.3" LCD Monitor
Set up pv505 monitor to computor do i use both power dc in and display in put ports
Yes you do, connect the mains power to the monitor and the video cable from the monitor to the video port on the computer.
Sep 02, 2010 | CTX Value VL 510 15" CRT Monitor
Turned my pc on and the monitor cums up with sayin no connection please help
Take your Monitor and cable (both of them VGA and power) to a friends house. Same problem?, It's your VGA cable or a slight possibility of it actually being the monitor. If it works borrow your friend's monitor. If it doesn't work you have a bad setting in your computer or you have fried your video card.
Feb 21, 2010 | Relisys RLT1720 17" LCD Monitor
Flickers until all monitor area turns gray - just like tv without signal
Sounds to me like bad caps on the power board or main board.
The monitor is faulty for sure. Bring it back to the shop and tell them the problem is still happening and ask them to leave it on connected to a computer overnight since it takes a while to happen. They should see it happen and then troubleshoot it further.
May 26, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Broken power port (dc jack)
You'll need:
a soldering gun
solder
solder wick
Hope this helps.
Best of luck!
Mar 04, 2009 | Acer Aspire 9410 Notebook
Oct 10, 2007 | Samsung SyncMaster 940BE 19" LCD Monitor
Sep 29, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Computers & Internet Logo
195 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
