Question about Electrical Supplies
I bought dimmable energy saver bulbs and when I put the dimmer about half way down they flicker or go off. Why do they do that?
    Scholar:
  • 142 Answers
If the saver bulbs are of Fluorescent lamps type, they can not go to 0 even to 30% (depending on mains voltage: for 240V mains the range is bigger), because they need minimal voltage of about 80-100 V in order to keep the electrical arc. They vary the light level, but if by a normal dimmer give them less than about 80-100 V (max value), they will go out.
You have about 80% iconomy(compared to normal incadescent lamps) at rated voltage and it can be rased to 90 - 92% at minimum light, but not more.
You should use a special diimer if you wish to use the whole range for dimming.
Posted on Aug 07, 2010
Can I use a dimmer switch with light bulbs whose packaging makes no mention of whether or not the bulb is "dimmable"? (be they incandescent, CFL or LED)
Most old dimmer switches do not work with energy saving/led bulbs, they will work fine with the old style filament bulbs, the newer dimmer switches will be compatible with energy saving bulbs and will indicate on the packaging!
Dec 27, 2014 | Electrical Supplies
Are led bulbs dimmable
Dimmable led gu10 bulbs are an increasingly common sight in many homes and businesses. Touting numerous benefits, these bulbs are recommended for their lower energy use when compared to traditional incandescent bulbs, leading to a healthier environment and a healthier wallet.
CFLs, however, are not a one-size-fits-all product. In some cases, consumers have to be sure to buy the appropriate bulb for the use they have in mind. Fortunately, as CFLs have risen in popularity, bulbs designed for use with dimmer switches have been introduced to the market.
Nov 29, 2013 | Electrical Supplies
Ceiling fan lights flicker in bedroom with 23watt cfl bulbs
Sounds like an older unit that has either a dimmer or electronic switch. You need to use dimmable CFL lamps.
Nov 07, 2013 | Hunter Dryers
How to do energy saver dimming ?
Most modern dimmers provide normal energy savings. They reduce the total amount of watts consumed on the circuit. Many years ago, dimmers only reduced the watts consumed as light - making up the difference as heat in the dimmer switch. A 100W light turned down to 1/2 wattage at a dimmer switch resulted in 50 watts of light at the bulb, but 50 watts of heat was created in the switch. That was zero energy savings. The newer electronic dimmers will still let 50 watts be used as light, but only a few watts as heat in the switch.
To maximized energy savings, use of new cold cathode technology lights such as CFL (compact fluorescent lamp), LED (Light Emitting Diode), etc. types are suggested. You can use these lamps on a dimmer to furrther reduce the amount of energy used - but only if the lamp indicates that it is dimmable.
If the lamp or fixture does not specifically state it can be used on a dimmer, don't. This includes powering a light through a dimmer that is set to maximum brightness. Use a standard non-dimming switch instead.
I hope this helps & good luck!
Apr 14, 2012 | Electrical Supplies
Installed 6696 When turned of the lights flicker light bulbs are energy saver not incadescat
This switch is made for incandescent load only up to 300 watts.You will need to find another type of switch or change your light bulbs to incandescent bulbs.
http://sbeelectricandhvac.com/
May 23, 2011 | Leviton Anywhere Switch - 6696-W - White
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
