Question about Reliance WATER HTR/STATE 9001954045ELECTRIC WATER HEATER THERMOSTAT
Thermos stat - Reliance WATER HTR/STATE 9001954045ELECTRIC WATER HEATER THERMOSTAT
    Scholar:
  • 122 Answers
Thermostat?
what are you trying to do, replace, reset?
most hardware stores have these, but I would replace both unpper and lower, not just the one.
make sure you set both to the same temp, the heater will work better.
just follow the instructions in the package. make sure you turn off the power before you start.
Posted on Aug 15, 2010
What is telephone number for ariston water heater in manila?
NO MANILA
Ariston address headquarters
Viale Aristide Merloni, 45
60044 Fabriano (AN), Italy
T. +39 0732 6011
F. +39 0732 602331
  • Central and Southern Africa
    Ariston Thermo SpA Middle East Branch
    Dubai Airport Freezone
    Office No. 5EA 414
    P.O. Box 54643 Dubai - UAE
    T: (+971) 4 2364969
    F: (+971) 4 2364839
    E: info.me@aristonthermo.com
    Web: www.ariston.com/me
  • Ariston Thermo SpA - Podru?nica Zagreb
    Kovinska 4a, Zagreb
    Tel: +385 (1) 7899 100
    Fax:+385 (1) 7899 105
  • France
  • Greece (Sales Agent)
    Tata Hellas Ltd
    Doiranis St.69
    176 72 Kallithea - Atene
    Tel: +30 210 9512922/23
    Fax: +30 210 9512080
    Email: tatagr@otenet.gr
    www.ariston.com/gr/
  • India
    Ariston Thermo India Ltd
    Chakan - Talegoan Road
    Chakan, 410101 Pune - India
    Tel: +91 2135 286228
    Fax: +91 2135 286229
  • Irland
    Professional Team Limited
    Suite 9&10 Plaza 256,
    Blanchardstown Corporate Park 2, Ballycoolin, Dublin 15
    Tel.: +353 01 899 1500
    Fax: +353 01 899 1501
    Web: www.aristonthermo.ie
  • Kazakistan
    Ariston Thermo spa (rep. Office)
    Office 235, bldg. 23 "A" Expo-City, Timiryazev str., 42
    050040 Almaty
    Tel: +7 3272 664853/54/56
    Fax: +7 3272 663867
    e-mail: info.kz@aristonthermo.com
  • Middle East
    Office No. 5EA 414
    T: (+971) 4 2364969
    F: (+971) 4 2364839
    Web: www.ariston.com/me/
    • Morocco (Ariston Thermo Distributor)
      Porcelanor
      N°35, Zone industrielle
      Route de T?touan
      Tanger
      Tel: 039 350 048
      fax: 039 350 077
      email: porcelanor@iam.net.ma
    • Singapore
      Ariston Thermo Pte Ltd
      100, cecil Street
      the Globe, #04-02
      069532 Singapore
      Tel: +65 62260292
      Fax: +65 62260361
      Email: info.sg@aristonthermo.com
Apr 07, 2016 | Water Water Heaters
Hot water heater water is just warm am wandering if its something that i can fix. its a reliance 501 electric heater
did you turn up the thermo stat?? it is right under the top and bottom cover. Turn off the power remove the top and bottom plates remove the insulation ( its just a patch)you then should see the adjustment screw witht eh little pointer. Turn it to the right as far as you chose the more you turn it the hotter it should get.
I would split where it is now to all the way right and give it an hour to see it that is hot enough for you. If not move the pointer the rest of the way.
Now if that does not work I would replace both top and bottom elements. If the heater is 10 yeer old or older I would replace them both now anyway. they are covered with lime.
You will need a heater element to remove it. they do mot cost much you can get all that you need at home depot or lowes or advanced hardware
Thanks Tom
Sep 16, 2011 | RELIANCE ELECTRIC WATER HEATER
Replaced both elements and tstats now there is 240 at both elements at once and only the top one is heating the bottom is coldreplaced bottom sgain thinking maybe bad from factory but still cold will i...
Electric water heaters never power BOTH the upper and lower elements at the same time.
If the water in the tank is cold, either the top OR bottom element will be powered through the upper thermostat (t-stat), never both at the same time. The upper t-stat will send power to the upper element until the temperature of the water in the top of the tank reaches the set point of the t-stat say 140 degrees. When the water temperature in the top of the tank reaches 140 degrees, the t-stat is "satisfied" and disconnects the power from the top element and sends it to the lower t-stat.
IF the temperature of the water in the lower half of the tank is lower than the set point of the lower t-stat, the t-stat closes to send power to the lower element. The lower element REMAINS powered by the t-stat until EITHER the water in the lower part of the tank reaches the set point temperature of the lower t-stat again, say 140 degrees; OR the temperature of the water in the upper part of the tank drops, at which point the upper t-stat "calls" and switches the power away from the lower t-stat and sends it to the upper heating element instead. When the top t-stat is satisfied, it switches power back to the lower t-stat. The process will continue back and forth for as long as needed to bring the temperature of the water in both halves of the tank to 140 degrees.
You must wait until the top of the tank is heated - before the lower element will be powered to heat the water.
I hope this helps you understand how the switching happens in these water heaters. Good luck! Please rate my reply. Thank you.
Mar 24, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a rheem fury 50gal gas water heater that will not stay on. I have replaced the thermo couple, it did lite but then went out.
I would like to know how old this heater is. This information can be found on either model or serial numbers.It won't appear obvious but last six numbers will tell you. You have already changed thermo-couple so I would check to see that it's properly centered in pilot flame.When you light it hold pilot button down for two-three mins.while watching thermo-couple.It should be a nice cherry red. If it is and pilot goes out after you release button then you either have another bad thermo-couple or gas valve is bad.If it does not get cherry red at least on tip then you need to reposition thermo-couple and try again. If gas valve is bad and heater is less then six years old valve will be covered under warrenty,however labor won't typically be covered unless you have extened service contract.Hope this helps.Thanks.
Nov 03, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Test procedure for elements and thermostat
Remove upper and lower access panels
in upper access, use voltage tester to test voltage of on the uppermost terminals above the red reset button. should be ~220V between terminals (110 to ground)
If not: breaker off or bad,
If 220V proceed:
Test the two terminals immediately below this reset button should be 220V
If not: reset tripped or bad
If 220V present, proceed.
Turn off breaker to heater.
Use ohm meter or continuity tester.
test resistance across upper element terminals -should be 10 to15 ohms
check between each terminal and ground -should be open circuit .
If not replace element
Repeat for lower element.
test across lower element thermostat should be no resistance when stat turned up so it clicks on.
(To test that lower stat turns off, allow tank to heat up completely before conducting this test) Turn sta temp down so it clicks off then test across stat terminals -should be open circuit
The upper thermostat is a 3 way switch
The simplest way to test it is to turn the power back on turn the upper stat all the way up so it clicks on and use voltage tester across the UPPER element terminals, should be ~220V
Now turn the upper stat down so it clicks off- check upper element should be 0 V between upper element terminals -(Caution ! terminals will still be live 110V to ground)
The upper stat has now sent power to lower stat.
Turn lower stat up so it clicks on, check Voltage across lower element -should be ~220V turn lower stat down so clicks off, should be 0 V across lower element terminals.
NOTE If tank is completely cold the upper stat will not switch off and wont send power to lower stat.
If lower tank is cold lower stat may not click off even when turned down.
normal stat setting is 125 to 130
The hotter you you set the stat, the faster your tank corrodes.
Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Rheem 92 gal. no hot water. breaker not tripping. lower thormostat reading no ohms. the upper thermostat is reading about 6 ohms. however when i turn power on the upper thermostat reads no voltage? Do i...
Have you checked to make sure that the elements are good by checking the ohms. Be sure that the power is off and the wires are disconnected from elements and then also be sure to check the ohms across the tank to make sure there is not a dead short in the element reading through the tank. If both elements are good then I suggest replacing both thermos then they will both be new and should work for you . Thermos can be problematic when trying to test them sometimes they won't always give you correct readings. Make sure you have the breaker off whenever you mess with a waterheater, and make sure you install the thermos correctly with the right wires going where they should.
Apr 19, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Hayward C-Spa XI 11 heater non operational
hi not coming from the US but from the UK. have you wired up the elements correctly?
you need to make sure there is power at the elements, you can do this by using a multimeter.
By physically disconnecting the elements & fitting a plug on them & plugging them directly into a power outlet, that way you can definately be sure that the elements are ok, but if you are in the US make sure its all to code?
Check the thermo( I am guessing by this you mean the thermostat?)
You can link this out just to make sure that the thermostat is not at fault. so by doing that you are putting the heater in a permanent demand, if that works then it could be the stat thats giving probs.
So you kinda get where i am coming from process of elimination here? or that if a timer is in an off position?
My hunch sounds as though it could be a pressure switch prob?
if you have wired the elements in right make sure your not getting a back feed & that its not showing you theres power when in esscence there isnt ?
Kindly
Richie
Dec 16, 2008 | Water Heaters
Reliance WATER HTR/STATE 9001954045ELECTRIC WATER HEATER THERMOSTAT Logo
20 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
