Question about Ryobi Garden
Need gas line schematic for ryobi 990r. routing to and from carbuertor, priming bulb and gas tank.
5 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: 17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Posted on Sep 19, 2011
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
SOURCE: where do I connect the fuel lines on my ryobi weedeater?
I have Ryobi775r string trimmer with walbro WT526 carb. The fuel lines connect 3 parts eg. gas tank, bulb (mine is a separate bulb not part of carb.) and the carb. The bulb has 2 fittings- a short and a long one. The carb also has 2 fittings- one on top (vertcle) and one on the bottom (L shape). The gas tank has two holes in the bottom one for over flow line and the other for fuel inlet to the carb. This has a filter in the gas tank. Now the connections- connect the long fitting on bulb to the tank. this is the overflow. Connect the short fittin on bulb to the carb top (verticle) fitting. Connect the fuel line (with filter - it is in the tank) streight to the L fitting on the bottom of the carb. Make sure the fuel lines are of right diameter. Too big-and you will have leaks. You are done connecting the fuel lines. just for info. the bulb is there just to pull a vavcume in carb so that the fuel is sucked into the carb and is present there when you start the engine. Hope it helps. Good luck.
Posted on May 10, 2010
  • 5 Answers
SOURCE: how to route the gas lines on 775r ryobi weed
Ryobi 775r Fuel Line Diagram..
Posted on Apr 27, 2012
Priming echo BP251 liaf blower
Hi Norman:
I'd check the routing of the fuel lines.
Tank to carb (this is the line with the filter on it)
carb to bulb (suction side)
bulb to tank (return line)
If the connections appear correct but it does not pull gas, check the filter to make sure it is clean, and you can try reversing the connections on the bulb.
Hope this helps.
Mar 11, 2016 | Echo Garden
Why won't my chainsaw prime?
if no gas will enter priming bulb at all I see only a few possible things for this
(1) gas line broken/melted
(2) filter looks good but has internal plug
(3) primer bulb has a small crack in it (most common )
Apr 30, 2015 | Ryobi RCS3535CA Petrol Chainsaw 35cc...
Has Ryobi RCS 3535A chainsaw a fuel bulb priming
The numbers you supply don't cross to an operators manual but that is typical of Homelite/Ryobi. I'm going to make an educated guess that it does not have a primer system. Other Ryobi saws with primer systems include it in the specification. The 3535A does not. Close scrutiny reveals no primer.
IMO fuel primers on chainsaws are one more source of problems. In the USA ethanol additives attack fuel hoses. Without a primer routing is from the fuel tank directly to the carburetor and much simpler to replace. Primers on chainsaws operate differently than 4 cycle engines too. No fuel is injected into the carburetor or engine, its only purpose is to ensure the carburetor is full of fuel,
Typical Fuel hose routing:
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
Nov 14, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a ryoby 31cc weed eater I need a diagrm on the corect posision of fuel lines
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Fuel lines rotted, unsure of routing new ones
Bottom of the tank one is an overflow, 2 in the top are connected to the bulb
. The bulb pumps gas from the gas tank to the bowl of the carb then back to the fueltank in a loop to prime things up, prime too much and the overflow comes out the bottom tube.
Sep 23, 2009 | McCulloch 26cc Gas Blower Mcb3208
Replaced gas lines on ryobi 31ccweedeater. my have lines crossed. will not crank.
One fuel line (the one with the fuel filter in the end of it), comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to the top fitting on carburator. That should be the correct fuel line routing. Hope this helped and best wishes.
Aug 28, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The fuel line leaks coming out of the plastic fuel tank on my Ryobi Brush Trimmer (990R I think). I am replacing the old plastic fuel lines into the tank but noticed that they are a little loose too. Any...
There is a little white ring that goes over the line and into the opening on the tank. This is what seals the line so the gas won't leak out. They are about $1.00 at any small engine service shop.
May 15, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
798 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
