Question about Video Game Consoles & Games
I have a Gigaware component cable for my Wii with 5 plugs at one end. Which plugs need to be used, and which ports do they go in to?
    President:
  • 1,139 Answers
Ok if you have a TV with a component connection you will find the same plugs in a row of 5 on it. The plugs on the end of the cable corrospond to the coloured jack on the back of the telly. This is the connection sequence looking at the cable plugs :-
Red plug - Audio R
White plug - Audio L
Plug with red tip and red base - Pr
Blue Plug - Pb
Green Plug - Y
I hope this helps
Posted on Aug 07, 2010
My Wii U wont work on my RCA TV!
U will need to get another av ..connecter...the color cords you said..there rca jacks..then it will work
Jul 29, 2014 | Nintendo Wii Video Game Consoles & Games
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
I need detailed instructions on how to connect a wii console to an asus vw266h monitor
You need to get another cable for that WII that is for HD. It has 5 connnectors on it. The red and white are the sound, the other three are for the video.
http://www.amazon.com/s?ie=UTF8&keywords=wii%20hd%20cable&page=1&rh=i%3Aaps%2Ck%3Awii%20hd%20cable
Dec 02, 2012 | ASUS VW266H - VW266H 25.5 LCD Monitor -...
How can I connect a WII console to my Champion Plasma CV 142 TV set? Can I connect it with RCA cables?
The 42CVI has both composite and component video in the standard configuration. Either of these should connect to your Wii console. You will get better results if you use component video (3 RCA plugs on each end of the wire for video (Y,Pb,Pr); use a second cable with two RCA plugs on each end for audio.) The Component video is Input-4. The component video cable is usually not provided with the game console. There are 2 composite video inputs on the TV (these use one wire with 3 RCA plugs on each end of the cable for video (yellow) and audio (red and white)).
I hope this helps.
Apr 09, 2011 | Champion 42CVI 42 in. HDTV-Ready Plasma...
How to hook a Wii to a 42" sharp aquos hd tv?
Easy.
You got one cable which plugs into the back of the Wii, plug the other end into the power bar or power outlet.
You have another cable which plugs into the back of the Wii. The other end of it has three colored cables. Plug the matching cable colors into the back of your TV that says AVI or Component, depending on which cables you have.
Put batteries into the controller.
Turn on the Power and switch the input to AVI or Component.
Dec 26, 2010 | Video Game Consoles & Games
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
Can i use an over the counter HDMI cable or do i need a "special" nintendo cord?
Hi, there is no true HDMI cable for the Wii but a "Component" cable which is as near to HDMI as possible. The cable has 5 plugs on it (make sure your TV has the same 5 plugs). They are available off of ebay for around £5
Hope this helps
Dec 06, 2010 | Nintendo Wii Console
Can the wii be connected with hdmi cable
As was said, there is no HDMI cable for the Wii. An HDMI cable would be a waste on the Wii, considering the Wii can't ouput 5.1 sound, and can't output 1080P (those are the main benefits with an HDMI cable).
The highest qaulity cable for the Wii is a component cable, which will allow you to output the Wii in 480p (progressive scan) vs 480i (integrated scan). All HDTV's have component inputs, so this is a non issue. Component cables actually can output 720p/1080i, but the Wii can only output 480p max.
Here is a link to the cable I am taking about. You should be able to get it from somewhere for the $20 range.
Nov 13, 2009 | Nintendo Wii Console
No Sound from TV when using Component Cables
what you do is plug in the HD cables as you previously stated and then place the red and white cords where you would normally put then like when you plug in a dvd player or the place you normally would plug in the red and white cables.
Apr 16, 2009 | Nintendo Wii Console
Video Game Consoles & Games Logo
158 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
