Question about RCA TruFlat 27F520T 27" TV
Rca tv turns off on it's own after being on alittle while
Television will turn off after a little while some times you can turn it right back on an then other times it wont come on
  • 71 Answers
If this set has onboard tuner could need resoldering-grounds under baseplate.
Posted on Apr 27, 2008
Tv wont stay on whats broke in it
if it turns off in the same amount of time every time, and can turn right back on, check your sleep settings... it is a feature that turns the tv off for you.
Mar 05, 2014 | RCA F27450 27" TV
My 52 in.rca rear projection hdtv tv . i have a hard time turning it on. i keep pushing the power on the remote and tv it will come on and turn off 3 times. i stuggle with it for about ten minutes. then...
no its most likely failed power caps CP150, CP120 and CP114 capacitors on the deflection board are the usual cause of that symptom. You can get the RCA repair kit by the same name from www.tvrepairworld.com under the RCA repair kits category.
Sep 04, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on
Need alittle more info such as does the power light come on? or Blink? do you hear any sounds such as chirping or beeping?
Jun 15, 2011 | RCA P61960 61" Rear Projection Television
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Jul 16, 2010 | RCA HD52W66 Projection Television
Rca Model number R52Wh73 Tv is not acting right
3 capacitors on your deflection board cp150 2200uf 16v cp114 cp120 220uf 35v
Dec 12, 2009 | RCA R52WH73 Projection Television
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
Rca mm52110 rear projection tv with issues
Will power up, but won't have a picture. What could cause this?
Sep 16, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
RCA P52927 sound is static
Need adjust coil sound ( little metal beside Big IC or between tuner and IC). Turn a little right and left ( be sure leave same position) don't play with this coil too much, will mess up video signal , some times tuner need be re solder. I hope this will help you Thank you!!!
Jun 30, 2008 | RCA P52926 52" Rear Projection Television
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
RCA TruFlat  27F520T 27" TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
