Question about Amana ARS2464B Side by Side Refrigerator
I have an Amana side by side model ARS2664BW. The unit is about 8 years old. The water dispenser on the freezer door quit working and the cooling units inside the freezer and frig are not working proper. There appears to be two cooling units in the freezer and two in the frig. The two bottom cooling units appear to be working but the top two cooling units are not working. Can anyone me with some guidance. Don't know if this is a DIY job or if I need to call the pros. Thank you.
  • 6,826 Answers
I did a search on Amana.com's knowledge base and didn't find anything useful regarding your two top cooling units not working.
At amana.com, I tried to download the manual, but the service was unavailable until 8/9/2010 after 8:00AM due to system upgrades.
http://www.servicebench.com/servlet/WebSideServlet?Request_Id=APPWhirlpoolDealerLocateBrandedGoto&Request_Server=servicebenchpublic&Request_Brand=L1&Request_ReadUrl=Y
The above is a service locator for your refrigerator. Since their site doesn't seem to have a solution for this, I would call in the pros if you want to have it fixed more quickly than trying to do it yourself.
Posted on Aug 07, 2010
My Amana 26 cu ft side by side quit cooling entirely in the freezer and the refrigerator. Is it worth it to get a repairman or should we just get a new frig. This one is 6 years old
I suggest get help with repairman.6 year old is not very old.Refrigerators have life more then 8 to 10 years.The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Oct 24, 2011 | Amana 26 cu. ft. Side-By-Side...
Have an Amana fridge, 22.6 cu ft, 12 years old, side-by-side, water/ice on door. Freezer quit working over a 3 day period. All the food thawed. Not sure if the fridge part is getting warmer also -- not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 20, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Amana side by side with ice/water in the door freezer stops freezing about 8 yrs old
First of all the worst thing you can do is set your fridge on the highest setting even though it has it. That's live reving your car to the red line just because it has it. As far as your challenge is concerned, it sounds like a breach in the seal of the fridge or dispenser. Check to see if the ice despenser is closing properly after use and check the door seal to make sure it's closing tight when the door is closed. To do this, simply inspect it for any bad wrinkles, cracks, folds, etc. if none are visible close the door on a dollar bill and make sure it holds securly all the way around the door. I f it doesn't, the seal may need to be replaced and/or the door is warped. If you continue to have issues, post again, we will work this out.
Jan 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser not working
Ice auger in freezer compartment not working. Common problem with GE side by sides I know of at least 3
Jan 21, 2008 | Amana ACD2232HR Side by Side Refrigerator
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Amana ARS2464B Side by Side Refrigerator Logo
306 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
