Question about Troy Bilt 5.5hp Self Propelled Mower
Keeps coking out won't stay started.let cool off tried cleaning cab. used fuel sab nothing works
    President:
  • Troy Master
  • 1,545 Answers
Try cleaning the main fuel jet in the carburetor. It is the brass bolt that holds the float bowl onto the main carb body and has some very fine holes in it that are easily clogged...esp. if no inline fuel filter is used.
Clean this bolt carefully as the holes are very small.
Posted on Aug 08, 2010
Monday morning my car would not start. Got a jump, still nothing. Banged on the starter box, started right up. Ran around the block died shortly after and would not start again. Took the starter,...
Cheque for disconnected vacuum hoses. sometimes this happen after working around the engine, if everything looks good, start the engine press down the accelerator pedal keep the engine running about 2500 rpm for 3 minutes then let the engine idle, if the engine idle this means you need a new idle speed control motor, if the engine still dies most probable the fuel pump it's going out if you have a code reader it's possible you have some codes and this can give a good direction
Dec 19, 2013 | 2002 Toyota Camry
Tip
How to clean a car battery with coke
We all value our transportation. We all like to keep our vehicles looking good.
What about under the hood? The battery is a vital part of the car. Its the heart.
Replacing one is rather pricey, so why not make sure the one we have stays in good shape? You're battery is under the hood of your vehicle, having access
to water,oil,and other fluids you my put in your vehicle. The battery terminals also called posts, and the cables (if your battery has cables) can get rusty. Rust, corrosion, and any other dirty build ups that may occur. This can potentially cause problems with the battery, such as: lack of full power, loose terminal cables. The terminal cables are the cables attached to the terminal posts. So your battery should be cleaned sometimes so these issues don't occur. You can buy many different cleaning solutions at any auto shop store, but they can be pricey, and everyone likes saving money. I have a cheap trick that will save you money and may work better than those other cleaning solutions. And that cheap trick is coca COLA.
THIS IS WHAT YOU WILL NEED
  • A can/bottle of coca cola.
  • A small copper wire brush.
  • A damp rag
  • A pair of safety gloves
  • And a screw driver
THIS IS HOW YOU DO IT
  • First locate your battery, you can choose to leave it in the vehicle, or you can take it out. If you leave it in make sure the vehicle stays off for this time. And make sure the battery is cool before you clean it.
  • Next, put on your gloves and get your brush. Start dry brushing the top of the battery which means brush the battery before using the coke. Scrub the terminals, and remove the terminal cables and scrub them too!
  • Now, open your coke and slowly pour it on the top of the battery. As you are pouring start brushing, same as before. Make sure you get the terminals and cables. Scrub till all of its gone or until you are satisfied.
  • Now take you damp rag and wipe every thing down so it don't get sticky.
  • Do not pour water on the battery!
Now you are threw you can re assemble your battery. If you took the battery out of the car you can put it back in your vehicle.
Its fast ,effective, and its so easy even girls can do it!!!
here are a few extra tips.
rc cola and Pepsi work the same
you can use coke to remove rust
and corrosion of other things like,
rusted pots and pans, other rusted car parts
and rusty tools.
on Jun 07, 2015 | 2006 Hyundai Sonata
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
I have a 97 dodge stratus. It won't start. Tried
Make sure it's getting fuel. Try using some ether or starting fluid. If it rumbles to life but doesn't stay running then there's a problem with the fuel delivery system. i.e.... Fuel pump, clogged filter, pressure regulator.... If the ether doesn't change the results you are getting now then it's a fire or sensor problem. Ignition coil, relays, sensors not signaling, PCM... I wish you luck. Let us know how it turns out
Nov 05, 2012 | Cars & Trucks
How do you clear codes for 2004 saturn ion
Clear the codes AFTER a repair was made & the light
stayed on ?
I would purchase an inexpensive $60.00 code reader &
use that.
If you start disconnecting batteries on every vehicle you
do or will own,then bad things happen.
The radio won't work,the car won't start,etc
If you have service manuals to learn your vehicles systems,
then you can eventually know what the results will be
Again,if you fixed nothing,then the light is going to stay on
or come back
Sep 18, 2012 | 2002 Dodge Dakota Club Cab
My jeep won't start unless I give it gas. It used
Did you clean the throttle body and plate of any carbon ?
Aug 27, 2017 | 1998 Jeep Grand Cherokee
Hi, I have a Craftsman Eager-1 5.3 3-in-0ne solid state enigine lawn mower..got it used but in almost new condition. worked great cutting 1 1/2 ft of very wet grass for a few hours (couldn't get to it...
Drain the fuel or when you remove the float bowl bolt (also the main jet), then hold up on the float to keep the needle on the seat so gas won't go everywhere. When you have that brass bowl bolt off, clean it! Use nothing metal on it. Pay close attention to the small hole in the bottom and along the smooth unthreaded part at the other end. Use carb/choke cleaner to blast gum and dirt out of those very small fuel orifices. I recommend installing an inline fuel filter also. A shut off valve is recommended too, that way if the needle in the carb sticks open, the crankcase won't be polluted with gas. Usual symptoms on a clogged lawn mower main jet though, are after pushing primer bulb, engine runs about 3 seconds. Try the brass bolt cleaning and post back if needed.
Jun 14, 2011 | Garden
1997 f150 truck starts but doesnt stay running, only if you
sounds like either fuel pump weak or fuel filter plugged
Dec 06, 2009 | 1997 Ford F150 Regular Cab
After putting gas in my car the car will start but will not idle
Try leaving the gas cap off after the next time you fill her up. A car's gas tank has to vent when gas vapors expand in the tank. Usually there's a valve in the gas cap.
Conversely once you fill your car up, and then burns fuel, if it isn't able to **** a little air in, then it'll VACUUM LOCK. Kinda like when you have a straw in a Coke, then you put you finger over it, and lift it out? The Coke stays in the straw until you release your finger off it. In this analogy the Coke is the gasoline and the cup is your engine.
If the gas tank can't draw any air in, then it won't allow the fuel to flow.
This is the simplest thing I can think of to check. Other than that, it could be a problem with any of the fuel/air electronics.
Feb 10, 2009 | 1999 Mazda 626
Troy Bilt 5.5hp Self Propelled Mower Logo
88 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
