Moved desktop plugged back in and says no signal?????
    Problem Solver:
  • 7 Answers
Check the cable on the pc going to the monitor and also
check the power to the pc
if the pc isn't turned on is most of the case with no signal
Posted on Apr 27, 2008
Acer x193 moniter shows no signal
Not to be too simplistic, but have you moved either the desktop computer or the monitor recently. Even if you haven't, check to make sure the video cable is plugged in completely on the back of the monitor and into the computer. It may look plugged in, but is not making a complete connection.
Aug 03, 2015 | Acer Computers & Internet
I have an AOpen monitor with an Intel PC. I moved my computer and when I finished plugging everything back in, the monitor says "No Signal Detected" I checked the plug several times, unplugging...
check to see if you were using a separate video card, you may be plugging monitor cable in the motherboard socket instead of the video card socket.
Feb 17, 2013 | Computers & Internet
I have a HP Pavilion p6110f Desktop with the video signal that goes in and out..
Buy a Graphic Card PCI e x16 compatible. Install, Move the monitor cable to the new card connection and your good to go, with better graphics. If you haven't installed a Graphics Card before, do a little research. Take a look at this for example: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01684404&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3970026
Dec 29, 2012 | HP DT PAVILION P6110f DESKTOP PC
Dell PC Desktops not sending signal to the monitor
hello,
If you dont get a signal to the monitor check these two situations:
1.check if the graphic card is properly inserted(pul it out and then back again)
2.check if the monitor in plug in if yes try to test the monitor maybe it's broken
Nov 05, 2012 | Dell GX745 Refurbished Desktop PC
Have desktop when turn on says something might have changed hardware or software try to do repair and cpu goes off and get no signal monitor
Probably there's a peripheral card moved or removed from your desktop..
the solution is to reinstall your current Operating system or if you still have the moved peripheral try to reinstall it
give me feed back for more help
Sep 04, 2011 | E-Machines eMachines Desktop PC
Shut down my computer aspire e380 then disconnected the monitor from the computer and power to move it. reconnected the monitor turned the computer back on and monitor says no signal.
make sure all the plugs are plugged in snuggly turn off the computer again then turn on the screen. next power on the computer. if that does not solve the problem you may have an issue with the video card.
Jan 06, 2011 | Acer Aspire E380 ASE380-UD500A PC Desktop
My Dell XPS 200 was working fine, I undid all the cables and moved it off the desk and moved the desk to new spot in room. When I set it back up it will not power on now. I did not drop it or do anything...
If you system is not giving any power signal, then I suggest that you try with any other cable to connect it with power. had there been any problem with your system then it should give some signal or sound. The problem might be with the power cable or the power port of your system
Apr 21, 2010 | Dell XPS 200 PC Desktop
I show on monitor "no signal" Check Signal Cable
Check that the "data" cable between your computer and your monitor is tightly connected at each end.
Connect the VGA-output port from a laptop computer to the monitor, to see if the monitor works when connected to a different computer.
Connect a different monitor to the VGA-output port on your computer, to see if that monitor works.
Failing all the above, the video-card on your computer is the problem, and needs to be replaced.
Nov 05, 2009 | E-Machines (T3104) PC Desktop
Last night I moved my living room around and moved in a new computer desk. When I hooked everything up the monitor is now not receiving any signal. I have checked all the cords and have restarted. Other...
Open the side of your computer. The card that your monitor plugs into may have come loose. Carefully pull it from the slot (you may need to unscrew it first or remove a bracket that keeps it stable; plus there may be a lever at the back of the card you may need to pull on) and then plug it back in again. It is not uncommon for this card (called the video or graphics card) to come loose when being moved around.
Jun 07, 2009 | Generic Memory Compaq Presario SR1215CL by...
I am not able to get Monitor to work.
How many VGA conncetors are on the back of the computer? If there's more than one (look carefully) then you need to try plugging into the others. Otherwise look inside the connector that goes from the monitor to the PC. Are any of the pins bent over? Straighten these very carefully.
Mar 23, 2009 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
