Question about Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12
6 yr old Xantrex Freedom 30. Outputting 140 volts from house bank of batteries. Is there an adjustment to get the out put down to the 15-120 range?
  • 787 Answers
No, not on your model.
Posted on Aug 07, 2010
Why does my Freedom 100 Watt Inverter/Charger remains in bulk
It sounds like a bad battery mine did the same but it was a much larger unit changed the house AGM Batteries and works perfectly
Jun 09, 2014 | Xantrex Technology Xantrex 458 10 12...
Loosing power
You need to add up all of the loads connected to the inverter. A 120watt load at 120 volts equals a load of 10 amps at 12 volts.
Watts= VoltsXAmps.
Add to that any other load on the battery - radio, lights, etc. and the standard vehicle battery will be dead in a short time. You need to either have a bank of large batteries, such as two or three group 27 batteries in parallel, or you need to keep the van running so the alternator can keep the battery charged.
Dec 07, 2013 | Xantrex Technology Xantrex 458 10 12...
My freedom 20 charger/inverter does not seem to drop down to a float charge and continues to charge batteries at a rate which makes it necessary to add water continually to my house batteries which consist...
The charger has four distinct charging stages - 1) Bulk, 2) Acceptance, 3) Float, and 4) Equalization. If your batteries are old and therefore won't reach full charge, the charger may not be able to get them up to the voltage where float charging kicks in. If you ever allowed the water in the batteries to get down to where the plates were exposed, one or more of your batteries may be contaminated with excessive sulfate buildup on the plates. The equalization process (Stage 4,which must be entered manually) will help to return any excessive sulfate builup back into solution, so you might try that and see if the performance improves.
Sep 26, 2010 | Xantrex Technology Heart Freedom 20 12...
I am trying to fix my xantrex freedom 10 inverter/charger but I need the internal wiring diagram. Is there I way that I can get it?
Unfortunately, to protect their proprietary designs, Xantrex does not provide parts or schematics except to their factory authorized service network. Assuming it is not still under warranty that would be voided by removing the cover, you might be able to see any obvious damage and procure the necessary repair parts from a third party, but that might be a lot of trouble to track down without any guarantee that it would actually fix the problem. If the unit cannot be uninstalled and/or brought to a service center, some reps do make "house calls", albeit for a fee.
Jun 10, 2010 | Xantrex Technology Xantrex 458 10 12...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
There is no ac output coming from the Freedom 25 inverter.
Assuming it was working correctly at some time in the recent past (i.e. not a new installation and/or changed wiring), the "Invert" light is off on the panel and will not come on when you press the button, battery voltage is between 10V and 15V and you don't have a bad battery/cell that pulls the entire bank down the instant the charging voltage is removed, and the unit is well-ventilated and not in thermal overload, the problem is most likely an internal failure which will necessitate taking the unit to a factory authorized service center, since Xantrex does not sell parts or schematics to the general public.
Jan 13, 2010 | Xantrex Technology Heart Freedom 30...
Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Jul 15, 2009 | Xantrex Technology Heart Freedom 30...
Inverter won't charge
check if the inverter has a fuse for the charger, if it does test it if it is still ok if not change it
Mar 09, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12 Logo
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
