Question about Hotpoint Ovens
I have a hotpoint ew 52 cooker and the grill does not work. it is part of the top oven.
I've an EW 71 with exactly the same problem! Thought it was the element but then noticed that there were two elements to the top oven - so very unlikely that both would go at once.<br />Tested to see if the switch was the guilty party by turning it on using the upper oven switch and indeed both elements heated!<br />If yours is doing the same then it's the switch....<br />... So how does one replace the switch?<br /> <!-- from fixya rte -->
Posted on Aug 15, 2010
  • Hotpoint Master
  • 3,463 Answers
You need to establish if it is the element that has failed or the control switch, usually it is the element(s)
Posted on Aug 07, 2010
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
How do you replace main oven temperature indication light for hotpoint double oven cooker model ew 74
In doing a general google with the brand/model, there are many things that come up about issues. You need to contact http://www.geappliances.com/service_and_support/contact/form_email.htm. They state their product is backed by GE. Many places sell this, but look for one with GE products. You might have an appliance store close by with that information.
Mar 06, 2014 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
I HAVE A HOTPOINT DOUBLE OVEN COOKER EW71. THE GRILL SWITCH IS PLAYING UP AND I NEED A NEW ONE. CAN YOU ADVISE ON THE PART NUMBER PLEASE
The part number you require is----------6204036.
Should you require the knob as well, the number is---------6201888.
These can be ordered directly from Hotpoint.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Ovens
Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 | Ovens
Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Timer clock is not illuminated and oven will not work
This does have an internal fuse and there are probably 2 or 3 of them. They should be located right behind the timer or thermostat.
Feb 03, 2009 | Blodgett Ovens
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
Ovens Logo
262 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Colin Stickland
Colin Stickland
Charles T Nevin
Charles T Nevin
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
