Question about EliteGroup ECS PT880Pro-A (1.0A) Via Socket 775 ATX Motherboard / Audio / AGP 8x/4x / PCI Express Lite / 10/100...
The motherboard ECS PT880PRO-A have a pci-e slot?
    President:
  • 2,571 Answers
Looks like yes, you have both an AGP slot and a PCI Express x16 slot.
Your specs are here
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135210
And your support page is here http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=578&CategoryID=1&MenuID=16&LanID=0
Posted on Aug 07, 2010
What graphics cards is best suited in my ecs 945gct-m2 v. 1.3 motherboard
That really depends on several things.
1. What is your power supply make & model? How many watts does it put out? What size power supply is recommended for the video card I want?
2. How big is your case? Do you have a lot of add-on cards already in the case? Will the ram slots get in the way of your PCI Express x16 slot?
3. How good id your cooling system inside your case? Does it have enough fans?
4. What slots can you use for graphics cards?
In your case you have :
1 x PCI Express x16 slot
1 x PCI Express x1 slot
2 x PCI slots
You can get a great deal on a graphics card from here when you determine what the answers are to those questions:
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=48&name=Desktop-Graphics-Cards&Order=PRICE
Jun 10, 2012 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
A740GM-M- DOES THE SERIAL NUMBER START WITH EA OR WITH V
For motherboard without parallel port: please check the farthest PCI slot from the center of the board, which is also the closest to the edge of the board. A white sticker with motherboard serial number is attached to the PCI slot.
It includes one letter +five numbers + one letter + eight numbers as follows.
http://www.ecs.com.tw/extra/productinfo/MB.htm
Jan 16, 2011 | EliteGroup ECS A740GM-M Value Socket...
Trying to find interal connectors 2-1 pin audio spdif on a emachine 1831-05. motherboard is mcp73vt-pm
It has been stated from my sources, that the ECS GF7050VT-M5 mobo, is the same as the ECS MCP73VT-PM, with a slight difference.
The difference being that the MCP73VT-PM mobo is based on the Micro-ATX form factor, and the GF7050VT-M5 is based on the ATX form factor.
[ Micro-ATX form factor size is 9.6 inches by 9.6 inches. 9.6 inches is approximately 9 and 9/16ths inches. It's also 244mm by 244mm.
ATX form factor is 12 inches by 9.6 inches. 305mm by 244mm ]
ECS MCP73VT-PM,
http://www.e4allupgraders.info/dir1/motherboards/socket775/ecsMCP73VT-PM.shtml
ECS GF7050VT-M5,
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=858&CategoryID=1&DetailName=Manual&MenuID=1&LanID=0
To the right of the subheading - Download, left-click on the server location nearest you.
[Taiwan, USA, Europe, China ]
This is a PDF file download. (Motherboard Manual) May take a few seconds before you see the first page, and additional time for the file to fully download.
Suggest you let the file download all the way, before looking through it.
I'm also looking at an ECS MCP73VT-PM on Ebay, as well as the PDF motherboard manual for the ECS GF7050VT-M5.
Motherboard oriented so that the Processor is to the top, ram memory slots to the right, and the orange PCI Express x16 slot to the bottom, the SP/DIF header on the GF7050VT-M5 is located to the left of the PCI Express slot.
From the poor view on the Ebay link, the MCP73VT-PM also seems to have the SP/DIF header in the same location, but clocked differently.
The header is clocked perpendicular to the orange PCI Express x16 slot, while on the GF7050VT-M5 the SP/DIF header is parallel to the PCI Express x16 slot.
The header is 4 pins long, with 1 pin not installed.
Pin 1 is marked on the motherboard.
Pin 1 is SP/DIF Digital Output
Pin 2 is +5VA ( 5 Volt analog power)
Pin 4 is Ground
There is no Pin 3.
Apr 06, 2010 | Computers & Internet
Problems with EliteGroup ECS A780GM-A (V1.1), a PCI firewire board plugged in a unused slot won't works well. Windows XP recognizes board and installs driver but cannot initialize it and reports error 10....
Hi there.
Error 10 means that the device cannot start.
This can be because the card itself is faulty or you have installed the wrong drivers for it.
Try to locate and install the drivers for it manually and see if it starts then.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Mcp61s pci port x16 or x8?
From ECS : "PCI Express x16 slot (runs in x8 mode)"
Seems like you can only use an x16.
Mar 04, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Computer wont do POST
reseat RAM, CMOS re-boot.If this results ina no boot, your board might be dead.
Dec 20, 2008 | EliteGroup ECS PT880Pro-A (1.0A) Via...
No picture at all
Hi geminip3, you need to make a couple bios changes when using a PCI-E graphics card. Still have your manual? Go to page 36. Advanced Chipset Features. Onboard GPU (Enable If No Ext GPU). By adding a PCI-E card this should be set to Disable. Than go to page 44. Init Display First (PCI Slot), set this to [PCI-E]. Read each page.
Than save your bios & exit. The system will auto restart. If you do not see display, wait about a minute & remove the monitor cable to the second out put slot. Some PCI-E cards need more power than the PCI-E motherboard slot can provide. You may find a power port on the PCI-E card. Some look just like the power cord for a floppy, others look like the power cord for an IDE hard disk drive. The latest ones are black in color & one end connects to an opened 4-pin molex (IDE power cord). Let’s address the onboard video card. (No PCI-E card attached). Back to page 36. Onboard GPU should be set to [Enable]. Page 44. Set Init Display First to [VGA/PCI]. Page 45. PCI/VGA Palette Snoop, set to [Disable]. I was unable to find where in the bios one can set the amount of system memory to run the onboard VGA. ECS manual is not the easiest to work with. Note: Ihave worked on other ECS MB's & though the above information has worked out ok for some, its not worked out for others. If the above suggestions do not work out, suggest you call ECS tech. I have emailed ECS stating their manual is confusing & asked for them to explain bios settings for VGA & PCI-E. Correct bios settings for your MB & user jrl1261's MB GeForce6199PM-M2. If the above settings do not work out. Don't fret. ECS wil get back to me & I'll post their email here.
Mike
Aug 10, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Computers & Internet Logo
291 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
