Question about HP DeskJet 340 InkJet Printer
I have a HP340 printer. It hasnot been used for 2 years. I have just put in a new cartridge and all it will print is garbage. WHen I try and print the test page the cardridge light flashes. What do I do?
MUKHTAR
  • 2022 Answers
SOURCE: Test Page Prints Everytime Printer Cuts On
this is happen when you install an new catridge or refill one printer is automatically adjust the catridge by alingment so you do one thing when you switch on printer and it will print something just read the instrction and follow them bcoz you need to setup the alingment thing . when the print is come out just place it in to the scanner and just press the scan button the printer will store the setting and next time not print the extra page bcoz the setup is completed.
bye
Posted on Nov 30, 2007
  • 103 Answers
SOURCE: auto test page on the HP F 380
I don't know this personally, but you should be able to hit the power button and turn it off right after you load the cartridges. then power back on. That might do the trick.
Posted on Feb 03, 2008
SOURCE: Epson CX8400 Blank Pages
i was having the same problem and just got off of the phone with tech support who fixed the problem for me,
go into system preferences
print and fax
there you should see the printer cx8400.
remove the printer by clicking on the - sign.
then re add the printer, by clicking the +
the computer will search for the drivers and install them.
that should have you printing like a champ.
hope this helps.
WW
Posted on Aug 13, 2008
SOURCE: Install cartridge
I did a master reset and now it will print but the ink level for the yellow cartridge still shows "empty" even though it is a new one but at least it prints for now anyway.
Master Reset:
Turn off printer and unplug.
Hold down "OK" button and "Help" button and plug in at the same time.
Turn on printer and wait for reset to finish.
It worked for me. Hope it works for everyone.
Posted on Oct 08, 2008
SOURCE: The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Posted on Jan 13, 2009
Help with HP 950 printer
Are you using original HP garbage? If not, the printer is designed to not work with refills.(there is a work around on the web)
If it is an original cartridge, perform a test print to see what happens. Should work if not, make sure that the printer driver you are using is compatible with OS. If all that checks out and still nothing, you can try to hard reset the printer. If still nothing, get a new printer, not an HP. When they work, they are fine - but their customer service SUCKS big time. They will only render assistance during warranty period. After that they refer you to a forum or suggest you get another unit - an hp of course!
Sep 10, 2017 | HP PSC 950 All-In-One InkJet Printer
The color cartridges have all been replaced in the HP Officejet Pro K850 now all the pages are printing blank?
Try re-seating the ink cartridges and printing a test page. Those were new HP cartridges, right? Not some garbage from a ink cartridge refiller off ebay?
Mar 28, 2011 | HP Officejet Pro K850 InkJet Printer
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
HP B9180 printer thinks new cartridge is empty
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 08, 2010 | HP Photosmart Pro B9180 InkJet Printer
Cartridge error:remove cartridge and reinsert cartridge on left, already cleaned, still happening, when put in new black ink, printed the alignment page out and then error showed, cannot print, fax, etc,...
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 12, 2009 | HP Officejet J5780 All-In-One InkJet...
All faces come out too dark. photosmart 526 I have had it for over a year and always worked ok until now.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 21, 2009 | HP Office Equipment & Supplies
Printing with double lines and blurry on left side of the page
Print cartridge
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
HP PSC 1500 xi Cartridge Error Problem
You do need both cartridges installed in order to use the printer. Even if one is near empty it will print (although your quality may suffer).
Jan 16, 2009 | HP PSC 1510 All-In-One InkJet Printer
Cyan Not working
Use the printers maintanance software to clean the cartridges ( start--settings--printer & faxes, right click your printer icon, choose properties, go to maintanance, click clean in cartidges. Max cleaning attemps is 3 times.
If that does not work, you need to clean the head manually.
Note that this procedure may destroy totaly the head.
Take a small tray and put some water inside (fill the tray to 3mm deep) Add few drops of white spiris in (2-3% max). Put the head inside (the solution must just cover the print nozzles on the head. Leave it there for few hours, then take it out, allow to dry, put it back in the printer, put the inks in, make one cleaning and try again.
If does not work.......you need a new head.
Feb 12, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Change all ink message
Your Lexmark cartridges may be like my HP ones--they have a chip that the machine reads so they cannot be reused without doing some tricks to fool the printer.
My HP remembers the last 2 or 3 cartridges and also will not use ones that have passed the expiration date that is stamped on the cartridge. I'll tell you what worked for my HP.
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Oct 25, 2007 | Lexmark X63 InkJet Printer
HP DeskJet 340 InkJet Printer Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
