Question about Whirlpool 24 in. DU1050SS Built-in Dishwasher
Whirlpool dishwasher, model DU1050XTPQ1, type 575-0; problem: showing no sign of power to unit and bottom of dishwasher is full of water---it apparently stopped during cycle. Is there a reset button? I have tried depressing the front panel "lock" button for five to ten seconds to unlock the system with no luck. The washer is hard wired to the home electrical system. What should be my next course of action? Thanks
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
  • 3 Answers
SOURCE: Whirlpool Dishwasher Not Working
Did you check the fuse in the plug (or fused spur) for the dishwasher?
Posted on May 17, 2008
  • 171 Answers
SOURCE: no power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
SOURCE: Whirlpl Dshwshr Control Lock light went on/Reg Cycle won't work
Hold the air dry button for 4 seconds. My son just fixed mine with the same problem.
Posted on Oct 06, 2009
  • 572 Answers
SOURCE: whirlpool dishwasher stopped in mid cycle
check your chopper inside ur unit.
Posted on Feb 11, 2010
Whirlpool dishwasher DU1015XTXBO Stopped working during cycle, acts like don't getting any power. Checked the plugin and it works. No lights or anything coming on the dishwasher. Its like it just
You may have power, however if a circuit board fails, all the power in the world won't start the washer. You need a technician to test the circuit for internal damage.
Feb 17, 2018 | Whirlpool Dishwashers
How to clean out pump drain on DU1050XTPQ1
Hello.
HERE ARE TOOLS NEEDED AND INSTRUCTIONS ON HOW TO SOLVE THE DRAINING PROBLEM BELOW.
(A) Wrench (if necessary) (B) Clean cloth(s)
Whirlpool brand dishwashers come in black, brown, stainless steel or white finishes and a variety of sizes as well. Most Whirlpool dishwashers are energy efficient, and many have features such as a sanitizing rinse, enhanced sound effects, large capacity tubs and adjustable shelves and racks. However, none of these features will help users much if the dishwasher is not draining. While this issue may require professional repair, some troubleshooting steps may help determine if there is a relatively simple cause for the problem.
1 Verify that the Whirlpool dishwasher has not lost power due to a power failure or motor overload. Wait a few minutes to see if the motor automatically resets and resumes operation. Reset the circuit breaker or fuse if necessary.
2 Press or select "Start" to resume the cycle if the dishwasher was stopped mid-cycle. Choose a new drain cycle if necessary to remove excess water from the unit.
3 Turn off the dishwasher and unplug it from power. Examine the connection between the dishwasher and the garbage disposer, usually located underneath the kitchen sink. Make sure the disposer knockout plug was taken out between the two.
4 Run the garbage disposer in the kitchen sink to remove potential blockages.
5 Remove objects that may be blocking the drain on the dishwasher. Clean out the drain hose at the rear of the dishwasher.
Thanks.
Nov 05, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My water heater error code 1 model ee3250rd055v what does this mean
Water heater is not 100% identified.
Unknown if this is gas or electric heater.
Problem posted under Whirlpool water heaters typically made by American water heater company.
Call Whirlpool 877-817-6750.
They will ask for model number and serial number located on label on side of tank.
Call is answered in USA by trained person who can answer specifics about that model, including warranty, age, regular maintenance, error codes, and possible solution for that specific model and serial number.
I have found these folks to be helpful.
Whirlpool manuals do not show that specific model:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
If you have the energy smart electric water heater with electronic control board, then error code explanation shows on the control board. Error 1 or a single flash, is start-up failure and requires tank to be full of water. Read page 10 of manual. Make sure water heater is full of water and water is coming full stream out of tub spout before turning on power. Also disconnect power from unit, make sure water heater is full, and then reconnect power to see if unit resets.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
http://www.whirlpoolwaterheaters.com/downloads/6510306.pdf
Sep 12, 2011 | Whirlpool Water Heaters
I have no power to my dishwasher. it is not the breaker and the dishwasher is hard wired. the bottom is full of water. is this a pump issue, or is there other electric parts that could have gone bad?
To answer your question directly the pump is the heart of the unit. With the stagnant water on the bottom your conclusion is correct. I don't know how old the unit is so you will have to out weigh whether it is more economical to purchase a new machine or repair it. My opinion, unless you are going to work on your own unit to replace it.. Good Luck
Jan 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Ive got a flashing clean light and the dishwasher won't run. Is there a reset button or a common part that causes this problem?
Flashing clean light on a Whirlpool dishwasher is a heater malfunction (sorta) this failure code is generated when the unit does not sense a 5 degree rise in water temperature with in 15 seconds (give or take depending on model) some of the earlier models could show code under certain circumstances such as incoming water to cold.
With control off alternately press high temp scrub and heated dry till all the lights flash on and it will go into a diagnostic mode hit cancel/drain button twice and retry using the dishwasher if the code persists try running Your kitchen sink until water is hot then running the dishwasher if the code comes up again begin inspecting the heater in bottom of wash tub for damage or signs of shorting also pull out from under the counter to inpect wiring to the heater, if these look good test the safety cutoff towards the front bottom of the unit small black and silver button sized componant with two wires to it for continuity.
Still ok remove the thermistor from bottom of pump and clean it and test the ohms according to the tech sheet on the back of the toe panel on front of dishwasher, if this is ok test run the dishwasher with a high temp scrub option selected and test voltage to the heater at the two connectors directly at the heater if there is no voltage and You have properly checked the previous items the control has a bad heater relay and will require replacement.
Mar 28, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Water intake valve in "open" position. No control. Model GU1500XTLT3, Type 575-0
IF YOU ARE TALKING ABOUT THE WATER INLET VALVE THEN IT SHOULD ONLY LET WATER IN WHEN ENERGIZED (115V) IF OPEN WITHOUT POWER THEN IT IS DEFECTIVE. WATER WOULD RUN CONTINUOUS.
Mar 08, 2010 | Whirlpool Dishwashers
My whirlpool dishwasher is not getting any water to it. it goes thru the cycles,but no water.it is about 6yrs old..model#GU1200XTKQO serial#FL3716278 type 575-0
sounds like a bad water valve you can disconnect wires ohms it out with a meter and see if its good or not . your looking for continuity. go to searspartsdirect .ocm to see price for part and they will ship
Mar 03, 2010 | Whirlpool Dishwashers
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
No power
Hi lushman001
Thank you,
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool 24 in. DU1050SS Built-in Dishwasher Logo
539 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
