Question about HP PSC 500 All-In-One Printer
I need a replacement cord for the scanner plug into the HP PSC 500. HP said they do not carry the cord., anymore.
  • HP Master
  • 6,826 Answers
I would try Ebay.com or your local Goodwill computer store, if you have one.
Posted on Aug 07, 2010
I installed the Hp 1410 all in one but there is no scanner and hp image zone displayed
For your HP PSC 1410 AIO Printer DRIVERS (Select your correct OS your PC),there are 2 drivers files for installation.
1. "HP Officejet and PSC Basic Driver" - Install only printer drivers without any softwares!!
2. "HP Officejet and PSC Full Feature Software and Drivers " - Install only printer drivers with any softwares. You should install this package is you want to use the scanner software.
Hope it helps.
"Courtesy is free but it will carry you forward a long way in a lifetime!"
Nov 07, 2010 | Computers & Internet
I need to know if an hp scanjet 5470c carries a power cord if not then what gives it power
You need a power cord for this scanner. If you have lost the power cord, you will need to replace it. I'm not sure of the specs for this (whether HP uses a special end like on their laptops).
I hope this helps.
Feb 03, 2010 | HP ScanJet 2200C Color USB Scanner
My hp psc 750 the dont scan but the printer work
hi
Clean the upper part of the scanner glass with soft cotton cloth. Ensure their are no visible marks on the glass.
If the printer power cable is connected to the surge protector, connect it directly to the wall jack and then perform power cycle on it.
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
After performing power cycle, you need to perform semi-full reset.
Press and hold Cancel and the Left Arrow key on the front panel keypad, while plugging in the power cord.
Put the printer as stand alone and try copying any normal document by placing it on the scanner glass.
Issue persists check if the scanner bulb is glowing and also able to move. If the scanner bulb is either not moving or glowing, the problem is related with hardware and needs to be serviced.
cheers
Jul 26, 2009 | HP PSC 750 All-In-One InkJet Printer
HP PSC 500 All-in-one will not scan.
Try this, it worked for me.
Turn off the computer.
Then turn on the printer/scanner.
Then turn on the computer.
Start/Control Panel/Camera and Scanners
Double click PSC500
Follow prompts
Good Luck
Jul 02, 2009 | HP PSC 500 All-In-One Printer
Hp 2175 all in one displays scanner failed mesage
Performing a partial reset
Follow the steps below to perform a partial reset of the all-in-one:
  1. Unplug the power cord from the all-in-one.
  2. In the table below, locate the button combination for your model.
NOTE:
If your all-in-one model is not listed in the table, your model does not have a partial reset option.
  1. Press and hold the button combination for your all-in-one.
  2. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one starts up.
  3. (FROM THE TABLE) HP PSC 2170 series --Press and hold Cancel and the Left Arrow while plugging in the power cord.
Jun 17, 2009 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 500 Printer/Scanner will not scan with MS XP Professional
according to hp you can't install the microsoft drivers you have to use the hp site driver for this printer . first go to hp and look up this model . then look under specialtions then look for how to install windows xp driver for this model
Apr 15, 2009 | HP PSC 500 All-In-One Printer
HELP ME
If you're running XP, you don't need an installation CD. I have that printer/scanner/copier and XP includes the driver. As well you can use XP's All Programs, Accessories, Scanner and Camera Wizard to scan. Unless your laptop has a parallel port or you have a Docking Station or Port Replicator, you'll need a Parallel to USB Adapter (see http://www.usb-ware.com/expresscard-parallel-port-sy-expc34-1p.htm). The cable my printer came with is part number C6680-80003 (see http://www.partshere.com/online/detail.asp?partno=C6680-80003). Hope this helps.
Oct 30, 2008 | HP PSC 500 All-In-One Printer
mukhtar21 shaikh
mukhtar21 shaikh
