Question about Microwave Ovens
Samsung Fridge / Freezer ( Model: RS21WASM ) , the Fridge Temp is not cooling down stuck at 15C - the freezer is working fine
jerryg50
  • 1689 Answers
SOURCE: My refigerator and freezer are not cooling enough
You could call for service. It is commonly possible that there was a loss of gas, or the thermostat is defective, or the compressor is weak. The refridgeration service man should be able to check for all of this.
Jerry G.
Posted on Apr 14, 2008
heatman101
  • 43501 Answers
SOURCE: Hi. I have an Amana/Maytag
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 25, 2010
SOURCE: we have just taken delivery
I have the same problem. i think they spray some glue along the sealant to keep it close in addition to sellotapeing the door. It may even just be a vacuum I ran a piece of card board along the door sealant and it opens.
Posted on Jan 13, 2011
SOURCE: icing up in the freezer,
Pull the fridge our from the wall and vacuum the back wall of it very gently. Also, take the kick plate (just above the floor) off and vacuum that underneath as well. It might not correct the problem but it won't hurt.
Posted on Feb 09, 2011
heatman101
  • 43501 Answers
SOURCE: I have LG fridge freezer
Many times the problem is that because the freezer is already cold the fridge will take a LONG time to recover...give the fridge a day before getting concerned about it...
If it still is not getting cold enough then moisture from the outside air may have caused the coils to freeze up and you may have to manually defrost the coils in the freezer as they may not completely defrost on the normal defrost cycle..
heatman101
Posted on Mar 08, 2011
Fridge is not cooling. Freezer however is working totally fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 06, 2011 | Microwave Ovens
My samsung rsh1dbbp side by side fridge freezer is not cooling down both sides have stopped at the same time.everything else works fine
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Jul 25, 2011 | Microwave Ovens
Freezer is fine fridge will not stay cod
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jun 24, 2011 | Microwave Ovens
The fridge isn't cooling the freezer works fine
heatman101
Feb 23, 2011 | Microwave Ovens
Hi. I have an Amana/Maytag Fridge. Model ABD2233DES bottom freezer. The fridge was working fine, then it seemed like the compressor or motor started to make a funny noise. Like it was working hard or...
Refrigerator
heatman101
Dec 24, 2010 | Microwave Ovens
My westinghouse refrigerator has stoped working but my freezer is working fine help. Model Bj513V Serial Number 72656346
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 18, 2010 | Westinghouse Microwave Ovens
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
The freezer is working fine, I have removed the floor plate in the freezer to check if the drain was clogged and it was frozen but I removed it but the refrigerator is not cold. I checked the door switch...
Please reply with a model #, make, and what exactly is the problem?? the fridge part is warm?
do you hear the compressor running?
is the freezer the correct temp?
Thanks!!
Aug 14, 2009 | Microwave Ovens
Microwave Ovens Logo
323 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
