I need a battery for the pyramid 105 amp - the specs state that it can run on a 12 volt - 4 amp battery. i need one that is both compact and rechargeable & will plug into the socket on the DC input jack on the back of the amp.
thanks
Hi prah
you can get one from here. But you will need to create a connection to the battery that suits existing sockets. Can you transfer the connecting lead from the old battery the new battery? The battery I have linked you to is a sealed lead acid battery I am sure is the type you need. They have spade connectors on them, that you can also solder to if you wanted to transfer the existing connector to.
regards
robotek
Oh... and here is the link to Farnell electronics... Jump to the home page to find the nearest one to you. They are in most countries of the world and do a great mail order service
How did you get on with sourcing your battery. Would be great if you could close this ticket off with a FixYa... still hanging around in my to do list. Cheers
There are many many possible batteries you can use for this application, from lead acid to Lithium polymer. You will need to determine what type of power connector that will fit your unit's jack then make sure the polarity is correct. You can then wire connector
accordingly to battery you select. Make sure battery exceeds current requirements but voltage. If unit has internal charger, make sure the battery you choose is compatible or use dedicated charger
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Balance Shaft Carrier to Block-Bolts
54
40
Balance Shaft Gear Cover-Double Ended Fastener
12
105
Balance Shaft Sprocket- Bolt
28
250
Balance Shaft Chain Tensioner-Bolts
12
105
Balance Shaft Carrier Cover-Bolts
12
105
Camshaft Sprocket-Bolt
101
75
Connecting Rod Cap-Bolts
54 +1/4 turn
40 +1/4 turn
Crankshaft Main Bearing Cap/Bedplate - M8 Bolts
34
250
M11 Bolts
41 +1/4 Turn
30 +1/4 Turn
Crankshaft Damper
136
100
Cylinder Head Cover- Bolts
12
105
Flex Plate to Crankshaft
95
70
Flywheel Mounting Bolts
81
60
Engine Mount Bracket Right-Bolts
61
45
Exhaust Manifold to Cylinder Head-Bolts
23
200
Exhaust Manifold Heat Shield-Bolts
12
105
Intake Manifold - Lower -Bolts
28
250
Oil Filter
20
15
Oil Pan-Bolts
12
105
Oil Pan Drain-Plug
27
20
Oil Pump to Block-Bolts
28
250
Oil Pump Cover Plate-Bolts
12
105
Oil Pump Pick-up Tube-Bolt
28
20
Oil Pump Relief Valve-Cap
41
30
Spark Plugs
28
Timing Belt Covers - Front Covers to Rear Cover-Bolts
12
105
- Rear Cover-Bolts
12
105
Timing Belt Tensioner Assembly-Bolts
61
45
