Question about Vehicle Parts & Accessories
I have a ungo pro security s100 installed in my toyota avensis and had the air condition evaporator removed until I obtain one. However when I try to start the vehicle it wiil not.
SOURCE: montana air conditioning leaks at evaporator core
Most likely the condensor...not the evap. Get a good AC&R auto shop to install ClipLight sealant...problem solved.
Posted on May 14, 2009
arauzvictor1
  • 466 Answers
SOURCE: air conditioning bad smell
Richard you have to check if your car uses to filter the air-conditioning closed the lid of the engine and where the breeze is a clean-clean grill before you turn off your air off the compressor and that was only working to remove the blower evaporator at all moisture-check that you have good drainage evaporator vote you all that water. Thanks and good luck
Posted on Aug 02, 2009
SOURCE: Toyota Avensis T99
replace the thermostat its stuck open
Posted on Nov 28, 2010
woodysmechan
  • 26 Answers
SOURCE: Toyota avensis 2007 heat not
check heater tap under bonnet and make sure it opens when controls set to hot and engine running
Posted on Mar 10, 2011
ercupa190
  • 12223 Answers
SOURCE: user manual for 2004 toyota avensis station wagon.
download from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Posted on May 25, 2012
How do I remove glove box in a right hand drive Toyota avensis 2008 d4d?
Try opening the glove box and press the two side until the two extensions that prevent it from falling move in enough to allow it to fall out. I hope this will be of help.
Feb 04, 2015 | 2007 Toyota Avensis 2.0
Needing information on removing a heater core from a 2012 Chrysler 200
how to? that it the full steps, out and in,,>????
there is lots of information on this....
not in warranty? huh?
and how could IT be bad so soon?? no way/ ,huh?
why not post the symptoms and not guess. the below HORROR
posted to show 2 days lost work (life)
buy the FSM and read the HVAC chapter. every word
or alldata.com , same deal. look, read and decide,
oops I cant to this.....?
parcial excerpts. to prove case.
quote:
The HVAC housing assembly must be removed from vehicle for service of the heater core.
housing out: 101:
Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in an accidental airbag deployment and possible serious or fatal injury.
WARNING
Refer to the applicable Warnings and Cautions for this system before performing the following operation and . Failure to follow these instructions may result in possible serious or fatal injury.
NOTE
The HVAC housing must be removed from the vehicle and disassembled for service of the heater core, A/C evaporator, air intake housing and the mode-air and blend-air doors.
NOTE
LHD model shown in illustrations. RHD model similar.
Heat Shield - Unified Line 08 JC
Disconnect and isolate the negative battery cable.
Recover the refrigerant from the refrigerant system (Refer to Heating and Air Conditioning/Plumbing - Standard Procedure).
Partially drain the engine cooling system (Refer to Cooling - Standard Procedure).
Remove the top nut (2) that secures the heat shield (3) to the stud (1) located on the dash panel.
NOTE
Two slots are provided at the bottom of the heat shield to aid in heat shield removal. Complete removal of the two bottom heat shield retaining nuts is not required.
Reach behind the engine and remove the two bottom nuts the that secure the heat shield to the studs located on the dash panel and remove the heat shield. Rotate and tilt the heat shield as required.
(capture the FREON as required by USA LAWS, Illegal for DIY person to do. so...)
Unified Liquid and Suction Line to Evaporator 08 JS
Remove the bolt (1) that secures the A/C liquid and suction line assembly (2) to the A/C evaporator (3).
Disconnect the A/C liquid and suction line assembly from the A/C evaporator and remove and discard the dual-plane seals.
Install plugs in, or tape over the opened refrigerant line fittings and the evaporator ports.
Disconnect the heater hoses (4) from the heater core tubes. Install plugs in, or tape over the opened heater core tubes to prevent coolant spillage during housing removal.
HVAC Housing to Dash Panel Nut
NOTE
Make sure to remove the five bolts that secure the HVAC housing to the instrument panel support prior to removing the instrument panel from the vehicle.
Remove the instrument panel (Refer to Body/Instrument Panel/PANEL, Instrument - Removal).
Remove the rear floor ducts (Refer to Heating and Air Conditioning/Distribution/DUCT, Floor Distribution - Removal).
Remove the condensation drain tube (Refer to Heating and Air Conditioning/Plumbing/TUBE, Condensation Drain - Removal).
Remove the nut (1) that secures the passenger side of the HVAC housing (2) to the dash panel (3).
NOTE
Use care to ensure that the interior is covered in case of loss of residual fluids from the heater and evaporator cores.
Pull the HVAC housing rearward and remove the HVAC housing assembly from the passenger compartment.
at the least, and for sure , things will break, as you work.
get lost, or not figure out how to put it ALL BACK
Remove the HVAC housing assembly and place it on a workbench (Refer to Heating and Air Conditioning/Distribution/HOUSING, HVAC - Removal).
Remove the left side front floor duct (Refer to Heating and Air Conditioning/Distribution/DUCT, Floor Distribution - Removal).
NOTE
If the foam seal for the flange is deformed or damaged, it must be replaced.
Remove the foam seal (1) from the flange (2) located on the front of the HVAC housing (7).
Remove the screw (8) that secures the flange to the front of the HVAC housing and remove the flange.
Remove the screws (3) that secure the heater core tube retaining brackets (6) to the side of the air distribution housing (4).
On RHD models, remove the air distribution housing from the HVAC housing (Refer to Heating and Air Conditioning/Distribution/HOUSING, HVAC - Removal)
Carefully pull the heater core (5) out of the driver side of the air distribution housing.
end excerpt.
May 13, 2014 | Cars & Trucks
Idle to high
There is, most likely a vacuum leak somewhere that is causing the high idle. Or the idle air control valve is malfunctioning. Some can be removed and cleaned, others may need to be replaced.
Apr 22, 2014 | 2005 Toyota Avensis 2.0
How to remove a radiator form a 2000 jaguar
Removal
  1. Drain the cooling system.
  2. Reclaim the air conditioning refrigerant.
  3. Remove the motor and shroud.
  4. NOTE: Seal the line and the evaporator with plugs.
Detach the air conditioning line. Raise the vehicle.
  • Remove the lower radiator splash shield.
  • NOTE: The splash shield is equipped with hinges which should be treated with care on removal. Remove the radiator splash shield.
    Detach the securing clips.
    NOTE: Seal the line and the evaporator with plugs and Detach the air conditioning line.
    1. Detach the lower coolant hose.
    2. Remove the air conditioning condenser. Remove the securing screws.
    3. NOTE: Vehicles with manual transmission, cable tie the cooling radiator
    4. tach the automatic transmission/power steering cooler.
      Detach the automatic transmission/power steering cooler.
      1. Lower the vehicle. Remove the radiator foam trim.
      Remove the radiator.
    Sep 25, 2012 | 2000 Jaguar S-Type
    How to remove heater core on a 1994 isuzu pickup
    Removal & Installation
    Fig. 1: When installing the new heater core take great care not to bend or damage the fins or tubing
    [IMG]http://i665.photobucket.com/albums/vv17/technovative/Isuzu-Pickup-Heater-Core.gif[/IMG]
    Click here if image doesn't display.
    1. Disconnect the negative battery cable.
    2. Drain the engine coolant into a suitable container. CAUTION
      When draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
    3. Disconnect the heater hoses. Be careful not to damage the core by pulling on the hose to remove. Cut the hoses if they will not come off easily.
    4. Remove the instrument panel.
    5. Disconnect the resistor assembly.
    6. If possible, disconnect and move the duct (non air conditioning) or the evaporator housing (air conditioning) to the right to gain clearance for the heater unit. If equipped with air conditioning, do not disconnect air conditioning system until absolutely necessary. Refer to Section 1 for discharging, evacuating and recharging the system.
    7. Remove the instrument panel stay and heater unit.
    8. Disassemble the heater unit by removing the duct, mode control case, core assembly and heater core. To install:
    9. Assemble the heater unit by installing the duct, mode control case, core assembly and heater core.
    10. Install the heater unit and instrument panel stay.
    11. Connect the duct (non air conditioning) or the evaporator housing (air conditioning) to the heater unit. Evacuate and recharge the air conditioning system if the system was discharged to remove the evaporator assembly.
    12. Connect the resistor assembly.
    13. Install the instrument panel as outlined in this section.
    14. Connect the heater hoses. Be careful not to damage the core by pulling on the hose.
    15. Refill the engine coolant into a suitable container.
    16. Connect the negative battery cable and check for leaks.
    Jan 30, 2011 | 1994 Isuzu Pickup
    Anything special to do when changing the battery in a 2005 toyota avalon
    the only problem you might have is you will lose all of your pre-set radio stations, if your radio has a security code it will not work until it is recoded, if it is coded there will be a red light blinking when the ignition is removed,if there is no light blinking it may not be coded, but it is best to connect another battery to your battery terminals before you remove them....hope this helps....cheers
    Jul 07, 2010 | 2005 Toyota Avalon
    Hearter core removal
    1. Disconnect the negative (-) battery cable.
    CAUTION When draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
    1. Disconnect the heater hoses. Be careful not to damage the core by pulling on the hose to remove. Cut the hoses if they will not come off easily.
    2. Remove the instrument panel.
    3. Disconnect the resistor assembly.
    4. If possible, disconnect and move the duct (non air conditioning) or the evaporator housing (air conditioning) to the right to gain clearance for the heater unit. If equipped with air conditioning, do not disconnect air conditioning system until absolutely necessary. Refer to for discharging, evacuating and recharging the system.
    5. Remove the instrument panel stay and heater unit.
    6. Disassemble the heater unit by removing the duct, mode control case, core assembly and heater core.
    To install:
    1. Assemble the heater unit by installing the duct, mode control case, core assembly and heater core.
    2. Install the heater unit and instrument panel stay.
    3. Connect the duct (non air conditioning) or the evaporator housing (air conditioning) to the heater unit. Evacuate and recharge the air conditioning system if the system was discharged to remove the evaporator assembly.
    4. Connect the resistor assembly.
    5. Install the instrument panel as outlined in this section.
    6. Connect the heater hoses. Be careful not to damage the core by pulling on the hose.
    7. Refill the engine coolant into a suitable container.
    8. Connect the negative (-) battery cable and check for leaks.
    Jan 20, 2010 | 1996 Isuzu Trooper
    Problem with the Air conditioning unit 2005 toyota avensis
    if its cold at 1 location all the time its probably got its gas maybe theres a vent not opening or a duct that has come adrift under dash,if its not cold in general you may need to get an AC guy to look at the fault but keep looking if you think something is simple to fix
    Aug 16, 2009 | 2005 Toyota Avalon
    How do i change the radiator in a 2002 jaguar x type
    As detailed as I can :
    Drain the cooling system. Detach the air conditioning line .Raise the vehicle. Remove the lower radiator splash shield. The splash shield is equipped with hinges which should be treated with care on removal. Remove the radiator splash shield. Detach the securing clips. Remove the radiator splash shield. Seal the line and the evaporator with plugsDetach the air conditioning line. Detach the lower coolant hose. Remove the air conditioning condenser. Remove the securing screws. Vehicles with manual transmission, cable tie the cooling radiator. Detach the automatic transmission/power steering cooler. Remove the securing screws. Detach the automatic transmission/power steering cooler. Lower the vehicle. Remove the radiator foam trim. Remove the radiator. To install, reverse the removal procedure.
    Aug 11, 2009 | 2002 Jaguar X-Type
    Air conditioning bad smell
    Aug 01, 2009 | 1998 Toyota Sienna
    Vehicle Parts & Accessories Logo
    155 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Marvin
    Marvin
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
