I have edesa dinamic 4l-94 how do I drain excess water
I have a small 5000 btu window unit air conditioner made by arctic king does not have a hole for the excess water to drain.
I've repaired a lot of window units because someone has drilled a hole in the pan, to drain water, and hit the coil. Please do not drill any holes in anything! These units utilize condensate water to help reject the heat in the outdoor coil. If water is reaching the outdoor fan, it either does not have the proper "lean" or slope, or it's designed to allow water to reach the fan, and not much you can do. If it is designed to allow water to cool the outdoor coil, and you were to drain that water so that no condensate water cools the outdoor coil, this will allow the unit to operate with an excessive outdoor coil temp, and shorten the life of the compressor, or cause the unit to operate poorly/warm supply air temp. Try to give it just a little more "lean". Hope this helps!
Aug 18, 2017 | Heating & Cooling
How do I get excess soap out of my washer so that it will drain?
Take the hose from the back of the washer and find something to drain the excess water in. Be careful, the water comes out fast so, let the hose release some of the water and then quickly raise the hose so it does not get water everywhere. Do this until there is no water in the machine.
Then try using it again.
May 15, 2017 | Kenmore Washing Machines
I have Kenmore110 digital washer,it won't drain or
Plug off the mains from the wall. Take out the exit hose from behind washer to floor level to drain out excess water. Raise up your washer slightly or feel for 3 screws right under the front, bottom. Unscrew these and pull down - you will find the lint trap and filter. (You may find a hose capped here for excess water, if not -as above for excess water) Be prepared for water. Clean out and refit. See that the exit hose is fitted at correct level after the job. Your filter and pump shd be checked according to your usage.
If helped pl click so.
Apr 22, 2013 | Washing Machines
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
Need new cutlery basket for edesa le15p
The brand Edesa is somewhere from Europe; thus you would not be able to find the basket anywhere in the U.S.
http://www.appliancepartspros.com/
Feb 14, 2011 | Dishwashers
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
Everstar MPM1-10CR-BB6
Press and hold the turbo button while plugging in the unit. The AC will cycle through a few tests and mine showed that it had excess water. I have long vinyl tubing so the unit could drain outside the window but it thought whenever it would start or stop there was excess water (thus stopping the flow). I drained the excess water out of the line and voila
Jul 08, 2008 | Danby DPAC8020 Air Conditioner
Washing Machines Logo
362 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
