Question about Yamaha RX-Z1 Receiver
Yamaha rx-z1 shuts off as soon as I turn it on
4 Suggested Answers
  • 85 Answers
SOURCE: My RX-z1 yamaha receiver shuts off right when I
Check and make sure that you dont have any wires shorted out. Also make sure that its not in a tight enclosed space because it can overheat quickly. It also wouldnt hurt to hard-reboot the unit. Simply turn it on, then unplug power from it for about 15 seconds. If non of these options shed some light, than you might need to get it serviced.
Good Luck
Posted on Jan 08, 2011
dunnbiker
  • 8546 Answers
SOURCE: Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Posted on Feb 13, 2010
  • 127 Answers
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Posted on Mar 02, 2010
Yamaha RX-V3300 Receiver shuts off on it's own.
A capacitor problem or overheat problem.
Feb 06, 2014 | Yamaha RX-V3300 Receiver
My RX-z1 yamaha receiver shuts off right when I turn it on, what do I do?
Good Luck
Jan 08, 2011 | Yamaha RX-Z1 Receiver
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
Rxz1 receiver clicks when turned on
disconnect, try again, check for bad speaker
Nov 02, 2009 | Yamaha RX-Z1 Receiver
Receiver turns on and clicks off when volume is raised over 8 or 9 on the dial
I had the same problem with my Yamaha amp. It turned out to be a shorting speaker wire. When I resoldered the speaker wall outlet connection it worked fine!
Feb 27, 2008 | Yamaha RX-V659 Receiver
Unit shut off after 15-20 minutes
The problem is IC 451, (Yamaha Part # XU814A00) (Number on part PQ05RD11 Made by Sharp). It's a + 5V 1A Voltage Regulator.
It's located at the bottom of the power supply board mounted to the front heat sink. It's a four legged TO220 Package outline. So don't try to slip a three legged 5 volt regulator in it's place. This can cause serious damage and headaches. Change this part and everything should be good.
Nov 15, 2007 | Yamaha RX-Z1 Receiver
Rx-V2400 Shut Down
Hi Seems like you have a shorted output channel, remove all your speaker connections and try again, if the problem persist, good chances are that you need to replace a couple of power transistors, let me know if you need more help, I've fixed some Yamaha amplifiers with this problem Good Luck Miguel
Oct 06, 2007 | Yamaha RX-V2400 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-Z1 Receiver Logo
258 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
