Question about Black & Decker String Trimmer Cordless 12" 18V
How do i replace the spool & take it off the b&d 18v edger/trimmer
  • Black & Decker Master
  • 43,501 Answers
Pineapple leaf jammed under spool housing. How to remove housing to clean out?
Usually the cutting heads have a couple of plastic tabs you push in to release the spool from the head
Mar 06, 2016 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How to restring cordless weed trimmer
Make a sharp bend in the line and insert it into the hole in the spool hub. Start wrapping the replacement line in the direction shown on the spool.
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Need instructions on changing the spool on electric grass trimmer/edger
Turn the trimmer over, I put it in my lap.Remove the orange spool cap by squeezing with thumb & forefinger. It will come right off. Remove & discard(there has got to be something they can be recycled as?) If you are right handed, hold the new spool firmly with left hand with flat side with the arrows up, keep a firm grasp & use small needle nosed pliers(I use hemostats) etc. to free the loose end of the line where it is looped thru the 2 slots. Keeping hold of the spool so it doesn't all unwind, let enough out to feed thru the hole on the side of the compartment where the old spool was. 2-3" will be enough. Then, place the spool into it's compartment with the flat arrow side up.Keep a good grip on the spool until you get it into place. Replace the spool cap by aligning it in the 2 slots that it came from & gently squeezing again until it locks into place & you are set to go. Don't worry about feeding the line out to proper length, it will do that all by it's self.
Aug 03, 2013 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
I have a used b and d electric trimmer. Is there supposed to be a spool for the line???
Yes. A black plastic spool sits inside the housing. It will come with the replacement line when making a purchase.
Apr 06, 2010 | Black & Decker String Trimmer Cordless 12"...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Replacing the string on trimmer
I don't think you have to get the housing off for replacing the spool purpose. Usually, take the spool cover first, and then you will be able to take the spool out of spool housing.
Aug 09, 2008 | Black & Decker String Trimmer Cordless 12"...
How do I insert sring into trimmer
1. take spool cap off;
2. take your spool out of spool housing;
3. reload line on the groove of your spool;
4. final, get it back.
Aug 04, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
330 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
