Question about Mitsubishi WD-52525 52" Rear Projection HDTV
First t v had blue screen no sound and on t v said on signal. Directv people were here and checked their equepment and everything was working O K. And now the t v will not come on at all. Three days ago it turned on . Now it will not do anything. Is their any hope to fix it.
  • Mitsubishi Master
  • 11,800 Answers
Most likely the power source has failed - initially just the low voltages output, now the failure has progressed and the entire source is dead. Yes, the tv is fixable but finding a replacement board for it will be difficult and expensive. It will be cheaper in  the end if you take the tv to a repair shop, they will be able to fix it for less than $150. Get a quote before that, maybe the guys in your region charge more.
Posted on Aug 07, 2010
Directv, no signal Directv box on, screen "no signal", checked all connections, held red button in box door - blue light on right moved r a while - nothing changed
possibly the port you're using on the TV is bad, try another port, if still same "no signal" try different cable, also, try testing another device connected to TV without using DirecTV box, if the test device works, Call DirecTV support to report your issue with box, if the test device doesn't work the motherboard of the TV needs replaced.
Oct 30, 2017 | Directv Televison & Video
Need the codes to program the remote to operate the sound bar
[PDF]Remote User Guide - MyDISH
https://www.mydish.com/filestream.ashx?ID=3037
remote. The standard setting for TV2 operation is UHF. If you wish to use. IR signals ... The on-screen bar ..... a remote-controllable audio receiver or amplifier.
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVLearn how to program your DIRECTV remote control in just a few short steps and ...control up to four devices, such as your TV, HD DVR, DVD player, and audio ...
Is it possible to have DirecTV remote control sound bar volu
Dec 21, 2015 | Televison & Video
Could you please tell me how to reset my tv? I have a blue screen
What should I do if my TV screen turned black, blue, or gray? print.png Print try this.
Proceed with the troubleshooting steps below only if you're seeing:
  • Black, blue, or gray screen
  • "No Signal" message without the DIRECTV logo
Note: If your TV screen appears "frozen" or you're seeing wavy lines or overlapping images, try this.
Solution 1: Check that your TV is set on the right input
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">Turn your TV and receiver off and back on.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number2_icon.png">Using your DIRECTV remote control, press the TV Input button to cycle through TV inputs (Component, HDMI, etc) until you see a picture. If nothing happens when you press the button, try programming your DIRECTV remote to control your TV Input and try again.
Note: You can also try changing the TV Input using your TV remote.
[img border="0" alt="Image" src="http://www.directv.com/cms2/global/icons/sm_cl_blu__number3_icon.png">If you're still having issues, check the cable used to connect your receiver to your TV.
Still not seeing a clear picture?
Continue to Solution 2.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/support/answer_center/tech_faq_images/img_screen_off_4.jpg">
Solution 2: Reset Your Receiver
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">On some DIRECTV receivers there is a red reset button located inside the access card door on the front panel. Press it, then wait for your receiver to reboot.
Note: If you cannot locate the red reset button or your receiver does not have one, unplug the receiver's power cord from the electrical outlet, wait 15 seconds, and plug it back in. Then press the Power button on the front panel of your receiver and wait for your receiver to reboot.
could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-0.jpg could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-1.gif
May 12, 2014 | Vizio L37 Television
What could be wrong if i have everything hooked up right i have it connected to the back of my directv box with audio coming out and going into input 1 on zvox box and is the blue light suppose to always...
1. Make sure it's connect to "Audio Out" on your DirecTV box.
2. Yes, the blue light should be on while unit is on an received a signal.
3. Check a second set of audio cables, just to be sure.
4. Toggle the Auto On/Off button on the ZVOX remote.
5. Make sure you've turned up the volume via the ZVOX remote.
If all these fail, contact us at zvoxaudio.com.
Tom
Jan 30, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
I have a Mitsubishi VS-50604. The sound is working but the screen is blue. No picture. What is the problem?
andychen993,
Depending on how you have your unit hooked up you may have a switch in the wrong position or not have a signal to the TV. Blue screen is the option if no video signal is present. Is your audio going through an amplifier? If so check all the signal feeds to verify that you have a signal going to the TV.
The easiest way to check this would be to hook a DVD up directly to the TV using a separate audio and video cable. If you still have a blue screen I would go into the menus and see if the settings are correct for blue screen.
If everything checks out ok then you probably have a bad small signal board and will need to replace it.
I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which could be helpful to troubleshoot your unit. It explains how to troubleshoot a dead TV but the procedure is the same to isolate a defective board.
Thanks for using FixYa and for the generous rating. We supply these answers for free.
hardrocko
Aug 21, 2010 | Mitsubishi VS-50604 50" Rear Projection...
I'm trying to connect my Polaroid 15" LCD TV (model FLM-1514B) to my Directv box and only get a blue screen on the tv.
Turn off blue screen in the menu of the TV if you can or cycle through the input sources on the remote to find the directv signal. Check cable setup in back of TV if it still does not work. Has the directv box been working with any other TV?
Apr 13, 2010 | Polaroid FLM-1514B LCD TV
No digital signal
You don't have anything to worry about. I have Directv too.
Just leave everything normal. The Directv box does all the work and puts the programs on the TV. The Directv System is not affected by the DTV Deadline.
Here's info from Directv web site on the subject.
http://www.directv.com/DTVAPP/global/contentPageNR.jsp?assetId=3460059
Jun 12, 2009 | iLO 3200 32 in. LCD Television
TOSHIBA FLAT SCREEN TV has black screen but power light is on!?
Try resetting the TV by leaving it unplugged for an hour.
Plug it back in and check to see if it works normally.
If that doesn't work, rule out the Directv box by pressing the reset button near the access card. The box could be putting out a signal that doesn't have video or audio.
If everything fails, have the tech man come back to check everything that he did before you use the warranty on the TV.
Feb 20, 2009 | Toshiba 40RV525U 40 in. LCD TV
White monitor
You can degouse it.I think you placed your monitor in any magnetic field or near fan ac or any electric equepment.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | Xerox XA7-172i 17" LCD Monitor
I have picture and sound when I watch a dvd/video but not through cable.
Try turning off the dvd/vcr and put your tv on the output channel of your DirectTv receiver. If this doesn't work it may not be hooked up correctly.
Oct 20, 2007 | Durabrand DU1301 TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
13 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
