Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I have installed a Belkin wireless router $I have a new TV with wiifi capabilities. It is asking for Access point name, what is this.
    President:
  • 1,768 Answers
1. 1. Login to router first and verify that the router with the rj45 cable.
2. go to the "wireless setting" see what the broadcast name is.
Posted on Aug 07, 2010
Belkin access point connect to smart tv
Does the TV, you didn't supply the Make, Model, have a Wireless Adapter? Connect the Belkin, you didn't supply the Model, to the ISP modem, connect a Ethernet cable.
Mar 07, 2013 | Computers & Internet
Cant access belkin router w 191.168.2.1 or any combination
. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 27, 2011 | Belkin Wireless (F5D7130) 802.11g/b...
How do i change from having a wire to the modem to wireless
Thank you for using Fixya!
In order to go wireless you need to know if you model has wireless capability (ask your Internet provider or from who you purchase the modem). If the modem does not have that capability then get a wireless access point or wireless router (I suggest a wireless router so you can have multiple computer connected to the internet). There are lots of brands out there namely, Linksys, Netgear, D-link or Belkin.
Hope this helps.
Sincerely,
stif_nec
May 23, 2010 | 3Com OfficeConnect Wireless Router
Installation of belkin router failed
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
May 08, 2010 | Belkin (F5D5231-4) Router
How to look in to the router
You needn't use this router as an wireless access point. Because this router can transmit wireless by nature without setting it up.
But if at all you need to know about WAP on this router:
1. Open the router page by typing 192.168.2.1 in the address bar of your browser
2. It should now open the Belkin Router Setup page.
3. On this page, on the far-left, you will see a column, in that search for a bold heading WIRELESS.
4. Under WIRELESS, you will find an option named "Use as an Access Point"
5. If you click on it, it will ask you for a Login password, leave that blank and click on submit.
This feature will in other words disable DHCP on the router. You can use this router only with any DHCP enabled device. Use this feature carefully.
Ask if you need any elaboration on this. Thanks!
Mar 03, 2010 | Belkin F5D8236-4 Router
I just bougt a laptop
by default the router password is user name is admin or blank
and password is password or admin or blank or 1234 there some combitaion is there just try it
Apr 01, 2009 | Belkin Wireless-G Plus MIMO Router with...
Hi  I have 2 Belkin G Plus MIMO routers seperated by 80 yards.  Can these two devices communicate directly - via wireless?  If so how?
Hi i checked with ur issue .....sorry to inform u that its not possible to connect both the routers wireless as they dont have the wireless bridging capability
thanks
Priya
Dec 17, 2008 | Belkin Wireless-G Plus MIMO Router with...
Belikin adapters and a wireless gateway
If your router is not wireless capable you need to add "wireless access point" on your network so that your wireless computers will be able to connect wirelessly to your network. You can buy WAP54G of Linksys or other brand of WAP(wireless access point).
Jul 08, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Access point
That Belkin IS a Wireless Access Point. Wireless routers are, by definition, an Access Point.. you will have to have access to the configuration page on the Belkin, and enable Wireless...
If you received this ADSL router from your ISP, then the best bet is to call them and ask for the proper way to access this utility... If you purchased this router, then perhaps I can find the proper way to configure it for you.. let me know.
Dec 04, 2007 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
