Question about Whirlpool Refrigerators
My Whirlpool refrigerator is leaking from the bottom. The defrost pan is full and I can't reach it due to its location. Wonder why the defrost is apparently not working
  • judij09 Aug 07, 2010
    My Whirlpool frig is leaking from the back. The pan under it is filled with water. I am unable to get the pan due to how it is in this weekend. Don't believe hose to pan is clogged since pan is full of h20. Thanks
    This sounds like a reasonable solution. The first one I got was not correct because the person answering did not really read the entire problem. This one did. Thanks
  • 2,841 Answers
If the defrost pan is full and is overflowing, you are not getting the proper air flow. The pan is located directly in front of the fan. If that fan is not working it will overflow because it is not evaporating. You can access the fan from the rear. The pan is normally accessed from the front after removing the lower cover. Pull the unit out from the wall and remove the cardboard cover. See if the fan is running. If not the blades may be stuck or the motor is bad. If the blades are stuck, unplug the unit and give the blades a good clean alone with the coils. If it turns freely then the motor is more than likely bad.
Posted on Aug 07, 2010
  • 11,896 Answers
Check the back bottom of the unit. There should be a drain hose that drips water into the evaporator tray. The line is likely plugged and that is why you have water on the floor. Unblock the tube so water drains into the drip tray.
If a defroster is not working, then the defrost timer, heater or thermostat may be faulty
    why would the drip tray be filled with water? thx
  • Nate Stansfield
    Nate Stansfield Aug 07, 2010
    the tray is supposed to have water in it. When there is water in it, the compressor heat evaporates the water. If there is no water in the drip tray, then water from the defrost system is not dripping down like it is supposed to.
Why does my whirlpool ET25DQ refrigerator leak water?
If your refrigerator has automatic defrost, the defrost water should drain from the bottom rear of the interior into a drain pan underneath. The pan may be missing or damaged or something could be preventing the defrost water from draining into the pan
Aug 05, 2013 | Whirlpool Refrigerators
Water leaks on floor, where isthe defrost drain pan? the manual indicates that water might build up in drain pan, the connections with the ice maker are all dry.
The drain pan is usually located closest to the floor - behind the kick space or toe space grill at the bottom of the fridge. Most often the water that collects in it is evaporated by the heat generated by the compressor and airflow from condenser fan located close to the pan.
Make sure the water is coming from the defrost drain hose - not from water sources elsewhere in the fridge (leaking water / melting ice into the fresh food compartment, etc.). If found, take action to correct.
Oct 19, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Auto defrost works fine except for water accumlating in the bottom of unit under the bottom trays instead of in the water tray by the compressor. graywolf7499@yahoo.com
There is a leak or damage of the pipe leading from the evaporator downwards.The defrosted water is leaking out of the tubing to the bottom,replace this tubing or check the leak on the collecting tray under the evaporator.
Sep 30, 2010 | Whirlpool Refrigerators
GE Profile with water leaking. Does not seem to be a slow leak. More like an intermittant "dump." Water on floor and refrigerator shelves. Thanks!
Look under the refrigerator and locate the defroster water drain pan. There should be a tube running down the back of the refrigerator which drains water into this pan.
If this tube or other parts of the defroster drain system gets blocked, water can get diverted before it reaches the drain pan.
Oct 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water in the bottom.4 years old,upper freezer
You probably have a defrost condensate blockage somewhere between the freezer and the condensate pan under your refrigerator. here is a link to a page full of different reasons for leaks. Just choose the part that most resembles your situation, Thanks, Sea breeze
click below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Whirlpool Refrigerators
Water leaking from bottom
Hi, during the defrost cycle the water runs down a pipe to a pan by the compresser where it evaporates back in the house. Ck to see if water is prevented from reaching this pan
Aug 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is leaking under my refrigerator
1)--In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. 2)--If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn?t out of place, broken or cracked.
Jun 12, 2009 | Whirlpool Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Water leaking into the drain pan
if the pan on the compressor on plug unit get a rag and sock up the water i beleave you doors staying open to long
Mar 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water pan inder freezer is full & leaking water
it may be that your defrost drain hole is blocked at the back. check it out but runnin a flexi band down it. if its the freezer drain hole you will need to do a full defrost to unblock ice.
Mar 16, 2009 | Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
