My hard is not detecting in my pc and produce some noise and after some time it goes hot.
  • 85 Answers
Scan your system for virus infection and check your processor fan speed through bios. processor temp. can abnormaly go high due to change in processor fan speed due to virus infection.
Posted on Aug 07, 2010
Oil furnace only produces cool water intermittedly and only when heat is actively on
For clarity, a Furnace produces HOT AIR for heat while a boiler produces HOT WATER for heat. Just remember...boil = water. You said your "furnace" does not produce hot water for a shower and because furnaces do not product hot water unless they have some model that do???? Usually people with a furnace have a seperate hot water heater. People with boilers though can produce hot water for use as both their sinks/showers hot water and their heat (by heating water that goes through baseboards) in their house. I don't believe any furnaces produce hot water most of the time a furnace just produces hot air for heating. So figure out what you first have.
Having said that, I'll assume you have a boiler like I do and my Weil McClean(sp?) stopped working a while back and wasn't turning on to "boil" any water. I took apart the burner and there is a light sensing photo resistor as part of the controls. If this phto resistor goes bad, the boiler will not start. The resister is cheap, I think it was $8 but you have to know what you're doing to change it. So you may be better to call someone who can work on such equipment.
Boiler's themselves are not overly complex. Home heating oil is the same diesel fuel that you can buy in a gas station only the government has "oil" companies put a RED die in home heating fuel which is usually cheaper then Diesel fuel because diesel fuel is taxed to death. The reason they do that is so that if you try putting RED tinted home heating fuel in your truck and you get pulled over (because you're a trucker with and 18 wheeler and they typically do inspections of these trucks) you will be a huge fine if they see you're running home heating fuel and NOT paying your taxed by purchasing Diesel fuel. A little bit of background so you know the fuel you are dealing with here. So it's dieslel fuel without the tax you run in your boiler. Gasoline on the other hand is VERY explosive as you know, but diesel fuel (if you're ever tried to light it) takes some coaxing to get lit. When it's cold out, diesel fuel is very hard to light and that's why trucks use glow plugs. You don't need those in your home though.
But because diesel fuel/home heating oil is hard to light, it's sprayed as a msit into your boiler, so that it can light more easily.
But because it is a fuel, you should know what you're doing when messing with it. FInd out what you have, and then have someone work on the issue if you haven't already. I'm guessing you have had it fixed by now?
Mar 21, 2014 | Water Heaters
Clicking noises from unit and computer failure to start up
The clicking noise is commonly known as the "click of death" on a hard drive. The hard drive is faulty and the clicking noise is the read/write heads clicking back and forth.
The hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 07, 2012 | Hitachi Travelstar 80GN 60 GB Hard Drive
My laptop makes a weird noise evry 5 minutes
The only moving parts are the hard drive and the dvd drive when a disc is inserted. If the noise only occurs when using the dvd drive, then thats where the noise is coming from and probably means that the drive is past its best and may need replacing. It could be the dvd drive thats causing the blue screen also, if windows detects an error with the drive.
Make sure that the Pc is not running too hot as this can also cause problems with hardware function and bsod issues.
Mar 27, 2012 | Dell Computers & Internet
Computer does not see hard drive. ran diagnostic test Testing booth path Error code biohd-2 no drive detected
reset the bios then check the power connector and the IDE or SATA cable for loose contact or change them see whether the hard disk is spinning or making any noise if you hear noise the hard dis is need ed to be changed if the hard disk is not spinning check the power connector and also check whether the circuit board below the hard disk is getting hot if its getting hot you need to change the circuit board of the hard disk with same company and number
Apr 25, 2011 | HP TouchSmart IQ506 PC Desktop
The hdd does spin but is not detected
it is phyisically damage and will not work it is bettre just replace the hard dirve.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
May 10, 2010 | Western Digital Caviar WD800BB 80 GB Hard...
A clicking noise from a hard drive typically indicates that the drive is about to fail or has failed completely. If the drive is still under warranty, contact Western Digital for a replacement drive. If not, you will need to purchase a new hard drive. There are services to recover some of the data off of a failed hard drive, but the rates can be quite high.
Mar 16, 2010 | Western Digital Caviar WD800BB 80 GB Hard...
Blank screen
Any hard disk that makes clicking or metallic noises is faulty, especially when POST error message no bootable devices detected.
To confirm go into the BIOS setting and see if the hard drive is detected, if it cannot detect the hard drive then it is definitely faulty.
Replace the hard drive and install Windows on the new hard drive to get the computer working again.
Aug 01, 2009 | Toshiba PSAFGU-058002 Notebook
Internal Hard Drive noise
it only means that your hard drive is experiencing bad sectors and it might become a mechanical problem which eventually the device should be replaced once the hard drive cannot be read or detected anymore. there is no solution to it.. all you have to do is wait.
Aug 25, 2008 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
74 people viewed this question
Alun Cox
David Payne
David Payne
