Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
After a few hours of usage (just bought the modem) I cannot switch on the modem...even tried multiple plug points, still no power to the modem...help..
    Scholar:
  • 104 Answers
Could check the mains cable, fuse,There maybe a fuse inside the modem like a miniture fusible resister gone open circuit.
I would send it back to the server you got it from.
Posted on Aug 07, 2010
  • 1 more comment
  • natiays Aug 08, 2010
    Check inside the modem?? would that void the warranty??
I bought a 32 inch flat screen around 2013 it was a guest room TV has not had at least 1000 hours on it. . ..what should I do.
Check up power supply plug point ,whether OK.Try TV from some other plug point .Even this does not work call technician .
Sep 22, 2017 | Televison & Video
My Coby LEDTV-2426 24 No Power
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 19, 2012 | Coby LEDTV2426 TV
I have a rocketfish 1025 va which has worke well and i have been happpy with. but i now have a very strange problem. today i moved it into another room to power my cable modem and router, nothing more....
Well, first let address the lack of power usage from your router and cable modem. The router, depending on model, may only use less than 5 amps of of power, depending on the load it is using at any one time, the cable modem is using maybe 2 amps, at peak load, since the line is already powered from the cable company, there is no real load. Since the usage is much less than 1 watt, it would not register on your meter. The reason why unplugging your devices from the wall, for it to not provide backup power to all of the devices is the battery(ies) may not be providing enough juice to maintain the power required for ll of the devices plugged in. Also, UPS are generally not compatible with power strips and therefore do not tend to function properly with a devices powered on the strip. They generally won't complete the power connection due to the strip carrying a much higher load than the UPS can support. This should explain all of your power issues. If you require additional information, please do not hesitate to ask.
Aug 18, 2011 | Rocketfish RF-1025VA UPS System
I just bought a PS3 and it basically does not allow me to connect to the internet. When I go into the menu it keeps loading forever, I waited like one hour and nothing happened. I can reboot it and the...
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
When the modem is hooked directly to a computer, internet service is available. However, when linked through a wireless router (we have tried multiple routers) there is no way to get online. The...
Tyr to power cycle the router and modem. First, make sure router is plugged into modem. Unplug power cord from both devices. Plug in the modem first, let it boot all the way up first. Then Plug in router and wait for it to boot up. Check your internet connection. If there is still an error message, make sure on the back of the router you have the Ethernet cord from the modem plugged into the input port of the router.
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_50dc26066e33d587
Aug 08, 2017 | Arris Touchstone 450a (CM450) Modem
Battery doesn't charge
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced. This can happen if the power chair has not been charged in a while or has been stored. Having the chair on or off while charging will not affect the charging process, but you ususally want it to be OFF.
Mar 11, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
The on-off switch on Speedstream 5100 modem keeps turning itself off, every few hours for few days. Finally modem has no power, what could the problem be? already tried replacing the power cord but still...
1: unplug all the cords to the modem
2: press the reset button from the back of it
3: leave it for about 5 minutes to drain off the static charge
4: plug it only to power source to see if the power lights up
5: if does'nt don't waste your time on it, its bad and if it was provided to you by your internet service provider get it replaced for free.
6: if you bought it yourself check for warranty generally modems have lifetime warranty
Dec 12, 2009 | Efficient Networks SpeedStream 5100 Modem
DSL modem no power in house, OK at shop, same cables.
Well, by process of elimination, it sounds like it may be a problem in the wiring in the house. Your best bet may be to test your outlets for proper wiring (ie. hot/netural faults), and for cycle rate (in hz, 60hz is nomal). I would also look into a surge bar that is built for normalizing power (Often called Power Cleaners). If you have older electrical service into your house (fed from a pole) or if you are in an apartment or condo type building, there may be line problems with the power supply. Basic outlet testers are under $10 and really handy to have around if you do any sort of electrical work, but the surge bars can be quite pricy. I would look at other outlets in the house that have similar AC/DC converters attached (like cordless phones, laptop computers) and see if it works in those outlets. Really a very strange problem, and may go deeper then just the modem itself.
Jul 12, 2009 | 2wire (1000-000057-000) Modem
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
56 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
