Question about Pool & Spa
How do i install a WATERWAY SEAL KIT - PS1000 319-3100?
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
After you remove the old parts and the remaining silicon, apply a new bead of silicon and then seal the stationary portion using a piece of 1" pvc as a driver with a mallet; once seated give the part about a day for the silicon to fully cure. Press the rotating assembly around the impeller sleeve. Be sure NOT TO TOUCH the seal faces as you install them and that they are clean once you are finished or the new seal will leak right away.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 17, 2010
Need to change seal on pf-40 waterway pump
can change but water leaking into motor it will start to squeal bad bearing just change whole pump
Dec 26, 2012 | Waterway 5HP Executive 56 Frame Spa Pump...
Hi , my executive 48 pump is leaking water at the shaft ...... is this some sort of bearing or seal problem ? thanks in advance for any help , andy dic
The pump seal is the problem and it can lead to bearing damage if not caught soon enough. The seal used in the waterway pump is not as easy as most seals to replace. You are better off to have it done at a pump repair shop or pool store than to tackle it yourself unless you are familiar with this seal and have the tools to fix it. A repair bill would likely be under $75 for a seal replacement at a shop and they can replace the bearings if necessary.
John
Oct 07, 2010 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
How do I remove the shaft seal from my Waterway pump? I've disassembled the pump down to the seal, but I cant get it out.
use a smal self tapping screw.screw 1 in each end off seal ,wen in use 2 pairs of pliers and pull out seal
Aug 14, 2010 | Waterway Above Ground Hi Flo Pump
Installing seal kit on hot tub waterway pump and can not get impeller off it broke I got shaft locked down so it will not spin even bought a strap wrench damm thing will not budge it is part number 310...
I can't say for sure if it is on your model and I don't rember where it is located. But some of these had impellors that had a allen screw that locked it to the shaft. I know this is not much help but I hope it helps.
May 10, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
Waterway hi-flo above ground pool pump just started running very loud. Turned it on and off several times but still runs louder than before.
If it's rattely clean the impeller, If it's screechie bad bearing probally caused by a bad seal and it will need a new motor and seal.
Jun 20, 2009 | Waterway Above Ground Hi Flo Pump
Witch way does the teflon side of the seal face the impeller side or motor on a waterway spa pump
the rubber seals around the housing. the teflon goes against the graphite fitting so there is a seal, but it is a mechanical seal.
David
May 16, 2009 | Waterway Pump Part Seal Set Ps1000 Cd 319...
PS-1000 Seal
The seal replacement on most pumps requires the capacity to separate the motor from the pump and to dismantle the wet end. Upon dismantling, it will become clear as to where the seal components are to be replaced. The spring half is found in the seal plate and must be knocked out and reinstalled with a properly sized driver and the ceramic seat is attached to impeller. Be careful not to damage the polished surfaces of seal. A light coating of a silicone or teflon based lubricant is most helpful ..
Apr 12, 2009 | Waterway Pump Part Seal Set Ps1000 Cd 319...
REASSEMBLED WET END OF WATERWAY PF401A22C-LEAKS- NEED DIAGRAM
I've never seen a reassembly diagram for this particular pump but I'm guessing that you've installed the mechanical seal incorrectly.
Where is it leaking from exactly?
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Apr 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Pool & Spa Logo
349 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
