Question about Echo CS400 18" Chain Saw
Engine dies at full throttle, manual says to clean fuel filter and vent but no clue where they are.. only ran 4 tanks of fuel through it before this started all of a sudden, not gradual loss of power, one day after sitting a month it started
  • 5,603 Answers
Fuel filter is usually on the end of the "fuel finder" hose inside the tank. The tank vent is USUALLY a small hole in the tank cap.
OFTEN these problems are caused by the diaphram in the fuel pump going bad, or the check valves if it has sat with fuel in it. The diaphram is in the carbureator and works from the vacuum pulses . The check valves are tiny flappers. If you have the problem, a carb rebuild kit is the fix.
Posted on Aug 07, 2010
Testimonial: "Thanks guys for fast response, now i know so will check.."
2000 Yamaha V Star 1100 Classic dies when throttle applied
Hi, Gardner and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump or internal fuel line has pinholes.
17. Fuel injectors clogged or faulty.
18. Faulty throttle position sensor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.starbikeforums.com/forums/49-v-star/68346-650-starts-but-dies-throttle.html
Yamaha Star 1100 Throttle problems
Yamaha XVS1100 Service Manual
https://www.partsfish.com/page/oem-parts-for-yamaha
YAMAHA XVS1100 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 09, 2018 | 2000 Yamaha V Star 1100 Classic
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
Vf750 honda idles but dies when throttle opened
Hi, Anonymous and the usual suspects are:
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starts choke but dies with little throttle
1984 VF700 Magna starts but won take throttle
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
Jun 14, 2014 | 1995 Honda VF 750 C Magna
2004 Kawasaki Ninja 250R dies with throttle
Hi, Ixitjbixi and the usual suspects are:
Engine Issues Bike Dies when given throttle ninjette org
Ninja starts but dies when open the throttle
Kawasaki Ninja 250R Service Manual
OEM Parts for Kawasaki
2004 Kawasaki NINJA 250R Owner Manual
Mar 15, 2013 | 2004 kawasaki Ninja 250R
1987 Kawasaki GPz 1000 RX dies with throttle
Hi, Steven and the usual suspects are:
96 Ninja 250 Dies once Throttle given Sportbikes net
http://www.kawasakimotorcycle.org/forum/vintage-motorcyle-info/146804-1986-gpz600-ninja-wont-rev-past-5000-dies-when-giving-full-throttle-please-help.html
Kawasaki GPZ1100 KZ1100R 1988 Service Repair Manual Download Manuals... $15
http://mybikemanuals.com/kawasaki
Mar 06, 2013 | 1987 kawasaki GPz 1000 RX
Bike runs rich, rough, idles and starts fine but dies when you hit the throttle. allways ran great untill i parked it for 3 weeks.
Hi, Sandmanaz and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
2000 yzf600r stalls when give it gas motorcycles
YZF600R Forums View topic 97 thundercat dies when given throttle
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Feb 12, 2012 | 2002 Yamaha YZF 600 R thunder cat
I have a 2002 dtr125, recently i ran the tank dry i refueled and it ran straight away. left the bike over night and started it the following evening, i rode 50m down the road and it died! still has full...
Sounds as if you have all the variables to make it go but, I'd suspect that either the tank filter is plugged or there is an inline gas filter that is plugged to a point it's only allowing a small amount of fuel (gas) to enter the carb. It's not uncommon after running and engine bone dry to pick up a bunch af rusty sediment in the bottom of the tank. the filters do their job but end up starving the engine of gas. There is a bit that's running through and after sitting for a few minutes the carb floats fill up and the motorcycle operated normally till the gas in the float bowls runs out and the engine dies.
Dec 20, 2010 | Yamaha DT 360 Motorcycles
1992 Honda CB 750 Nighthawk will not idle without choke
Hi, Emeraldcp and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike won Run without Choke
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
Honda Nighthawk CB 750 1991 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Sep 26, 2010 | 1992 Honda CB 750 Nighthawk
GS400 engine dies at full throttle, manual says to clean fuel filter and vent but no clue where they are.. only ran 4 tanks of fuel through it before this started all of a sudden, not gradual loss of...
The fuel filter is in the tank, to get it out you need a pair of needle nose pliers to remove it also change the hose going into the tank and into the carburetor the filter costs $2.00 and the hose a Dollar. hope this helps.
Aug 07, 2010 | Echo CS400 18" Chain Saw
Echo CS400 18" Chain Saw Logo
716 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
