Question about Jeep 10 x 20
Serial numbers? I have a '76 CJ-7 w/replaced AMC 360 V8 & Quadratrac trans. I need to know where are serial #s located so I can buy correct parts. Also, I need the front axle piece on the right side that attaches to the wheel and I don't know what part "exactly" that is!
May I call you? or you can call me at 314-691-0812; Bob.
The spindle,(I believe) is what I need,but can't find exact part to buy in catalogs. I need the part #, or something to be able to buy trans. filter and gasket. If that helps.
Posted on Apr 27, 2008
1978 CJ-7 304 V8 runs until warmed up then dies, restarts after cooling down-fuel filters & fuel OK, timing OK, bad EGR Valve?
im surprised you 78 cj has an egr it must be modded out i would gess that your using an ecm for ignition check grounds fuel pressure pressure regulator if its egr your worried about its for emissions exaust gass recerculation it takes unused fuel frome your exaust recerculates it to the intake helps keep the intake cool and aplies the unused fuel to the intake better econamy but you have to have a cat to make it work if you do it may be pluged try taking the forward o2 sensor out and see if it stays running if it dose change the catalitic converter
Jul 22, 2012 | Jeep Cars & Trucks
Jeep CJ 7 problems Dana 30 and AMC 20
gear ratio on 4 wheel drives are matched up together so that one does not push or drag the other if you change one it will affect the other
Feb 25, 2010 | 1983 Jeep CJ7
Model MAH4000AWW door leaks. Has hole worn in it.
You will need to go back to your madel number. Look you a series or rev number. 10, 42 or 53. It will have one of these numbers there. This will tell you which part your looking for.
model-number-tag.jpg Please rate solution if helpful. Thanks
Aug 24, 2009 | Washing Machines
Noise in front axle when turning.
Likely the viscous coupling and/or chain. Parts are quite expensive.
Jun 25, 2009 | Jeep CJ7 Cars & Trucks
Cj7 rear
Jeep Axle: AMC 20
Front Axles
Dana 44
Dana 30
Dana 27
Dana 25
Rear Axles
Chrysler 8.25"
Dana 35c
AMC 20
Dana 30
Dana 60
Dana 53
Dana 44
Timken
Dana 41
Dana 23
Jeep Axles
Upgrades
Factory Options
General
-->All AMC 20s have a 8 7/8" R&P and use a 29 spline shafts. The AMC 20 R&P is 3/8" bigger than the Dana 44, but it uses smaller shafts, smaller axle tubes, and the CJ version comes with weaker two piece shafts. The AMC20 uses a 29 spline shaft where as the later Dana 44 uses a 30 spline shaft. The AMC 20 housing tends to flex a lot which can cause breakage. This can be remedied by welding the tubes and/or adding gussets. The reason the AMC 20 flexes more than the Dana 44 is the shorter differential housing and smaller axle tubes. It's other flaw is the CJ version uses the two piece axle made up of a hub and a shaft. The hub end tends to break off under load which has created the market for one piece AMC 20 axle shafts. Unfortunately, the shafts are expensive ($350+ USD) and in some cases a special bearing must be used.
amc20co_.gif -->Identifying the gear ratio of an AMC 20 is a bit tricky. Dana axles normally have a tag on the left of the diff cover with the gear ratio at the time of build. The AMC axles have a code that has to be looked up in a table. The code is stamped on the housing boss to the left of the diff cover right near the axle tube. Good part about the stamp is it tends to stay readable longer than the tag, but you have to know the code. Since there are conflicts between what a code means for a narrow track and what it means for a wide track, don't count solely on the code to identify an axle. Bring a tape measure or know the source of the part. Specs Narrow Track AMC 20 Code Gear Ratio Diff Type AA 2.73 Open DD 2.73 Trac-Lok BB 3.31 Open CC 3.31 Trac-Lok A 3.54 Open N 3.54 Trac-Lok GG 3.73 Open Q 3.73 Trac-Lok L 4.10 Open M 4.10 Trac-Lok Wide Track AMC 20 Code Gear Ratio Diff Type D 2.73 Open DD 2.73 Trac-Lok B 3.31 Open BB 3.31 Trac-Lok A 3.54 Open AA 3.54 Trac-Lok H 3.73 Open HH 3.73 Trac-Lok C 4.10 Open CC 4.10 Trac-LokThe Trac-Lok is a limited slip differential. You may have to scrape away a lot of mud, paint, and rust to uncover the code. If you can't find the code on the rear, check the tag on the front axle. Both axles should be geared the same. The R&P ratio ranges supported by the carriers are 2.73 and 3.31-5.13. The 5.13 gear ratio is not available for the Dana 30 though, so it is rare to see it. 4.56s are the lowest common ratio between the Dana 30 and AMC 20. 5.13s are available for the Dana 44.
CJ AMC 20 The CJs used two versions of the AMC 20, the narrow track from '76-'81 and the wide track from '82-'86. Both versions use keyed, two piece shaft/hub design and 5 on 5.5" wheel bolt pattern. Supplies of AMC 20s were exhausted in 1986 and some Dana 44s were used instead in the last of the CJ-7s.
From 1976-1978 a larger 11x2" drum brakes was used on the AMC 20. After 1978, a 10x1.75" drum was used.
SJ AMC 20 The Wagoneer and full size Cherokee also used a narrow and wide track version of the AMC 20. Both SJ versions used once piece shafts and 6 on 5.5" wheel bolt pattern. Since the length and bolt pattern is different from the CJ version, the SJ shafts are not compatible without resplining and redrilling. I've never heard of anyone going to the trouble.
Model/Version Spring Pads Wheel to Wheel Years AMC 20/CJ Narrow Track 36" 50.5" '76-'81 AMC 20/CJ Wide Track 36" 54.5" '82-'86 AMC 20/SJ Narrow Track AMC 20/SJ Wide Track Last modified Friday, 03-Dec-1999 21:48:34 MST
[ Jeep Tech Main Page | Terry's Jeep Page ]
Copyright © 2001, 2000, 1999, 1998 JEEPTECH.COM
All Rights Reserved, All content with exception of private works and
corporate trademarked logos are property of Jeeptech.com
Jun 06, 2009 | 1985 Jeep CJ7
4.0 in to a 84 grand wagoneer
There shouldn't be any welding involved. The 4.0 is a detuned 4.2 due to fuel injection.
Feb 25, 2009 | 2006 AMC J10
'76 CJ-7 w/360 4b v8
My problem was solved by the assistance of Nitrotrike. Thank you.
Apr 27, 2008 | Baby Gear
Jeep 10 x 20 Logo
115 people viewed this question
Top Jeep Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Jeep Optic Expert? Answer questions, earn points and help others
