Question about Ryobi Garden
We bought a new ryobi from home depot 5/23/10 with a 1 year warenty now the thing will not start my husband changed the spark plugs still nothing the fule bulb will fill still nothing starter fluid still nothing. what do we do next?
    Brigadier General:
  • 4,088 Answers
If you have followed all of the instructions in the owner's manual for starting, then take the saw back to Home Depot for warranty exchange or service. Good luck!
Posted on Aug 07, 2010
What spark plug is used in an unidentified trimmer/edger?
Ryobi 4-Cycle Spark Plug-AC00164A - The Home Depot
www.homedepot.com/p/...4...Spark-Plug.../203222932
The Home Depot
Rating: 4.3 - ‎3 reviews - ‎$4.97
6 days ago - Keep your engine running smoothly with the Ryobi 4-Cycle Spark Plug forTrimmers. ... Use the replacement spark plug with any of Ryobi 4-Cycle engines. ... Replaces champion RY4C and torch CMR7A.
2-Cycle OEM Spark Plug (RDJ8J) - Sears Outlet
www.searsoutlet.com/2-Cycle...Spark-Plug.../product_details.jsp?pid...
Shop for a 2-Cycle OEM Spark Plug (RDJ8J) (49M0311P953) at Sears Outlet today! We offer low prices and great service.
Nov 28, 2015 | Garden
Is there a recall for ryobi 18v charger or batteries
I had similar problems with my 18V Ryobi batteries. Called Ryobi customer service, gave them the serial numbers and was told there was a 2 year warranty on them, in my case the warranty was in effect until July 2012. Took the batteries to Home Depot today and they replaced my batteries with two brand new ones. I can't complain about Ryobi customer service
Jan 07, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
I have the Ryobi RY09050 gas blower/ vacuum brand new bought from Home Depot. I try to start it cold as said in the manual. I pull, and pull, and pull, and pull on a flat surface and it does not even...
i would check for spark, if it has spark, then I would pour a little mixed gas down the into the cylinder, reinsert spark plug and then try starting it again, if it starts then dies. Then it is not getting gas for some reason. Hope this helped Tim
Nov 14, 2010 | Garden
I have a brand new Ryobi C430 trimmer that will not start or even attempt to start. Have followed all instructions. Bought from Home Depot. Need help. Ed
for any engine to start and run it must have correct mixture fron carb,,a spark at plug at the right timing,=so many degrees before tdc, which depends on what the engine is,, adiquitt compression to promote combustion, diesels use ultra high compression ratio for the diesel which is injected at aperciffic timing and the diesel detonates due to high compression which is why some knock badly
Jun 21, 2010 | Garden
I bought a Ryobi RY34420 yesterday from home depot
Sounds as tho it needs a minor carburetor adjustment. It's not getting enough fuel when you pull the throttle. Don't know if the owners manual addresses this issue or not, may want to check.
Dec 23, 2009 | Ryobi Garden
Hello I have a Ryobi HT26 hedge trimmer that is one year old. It starts fine but dies after I try to release the choke and pull the throttle. I cleaned the air intake that was semi plugged, replaced the...
Sorry but I have the same problem, did everything you did plus bought a new carb. I think these are just a bunch a ****. I have Ryobi electric tools which are okay but I am NEVER going to buy a buy Ryobi gas product again>
Nov 22, 2009 | Garden
Have a Ryobi CS30 Weedeater, will not start, it is about a year old, did not see a spark, just bought new plug.
If you still don't have a spark with the new plug, then you may have a kill switch wire grounding the motor, keeping it from starting. If it's not that, then you have a bad ignition module (coil).
Jim
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
136 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
