Question about Sony Walkman NWZ-S616F MP3 Player
The volume (UP) button does not work. When I hit the UP arrow to raise the volume, the MP3 player actually goes to the next song instead of raising the volume. Is there anything I can do to fix this? The DOWN arrow for volume actually lowers the volume as it should.
    New Friend:
Me too! :\
Posted on Mar 29, 2013
Same here.
Posted on Aug 22, 2010
I started having the exact same problem with mine today and am hoping someone has an answer!
Thanks.
Posted on Aug 18, 2010
Volume will not change on my trio v2 plus
In the playing music mode, press the center button one time and then hit either the button to the right to raise the volume or the button to the left to lower the volume.If you hold down the center button it gives you other options.
May 09, 2012 | Mach Speed Audio Players & Recorders
Mp3 song not plying why
make sure your sound is turned up, be sure if you have external speakers be sure they are plugged in and they are on and turn the volume half way up. Next open the speaker on the lower right side on the task bar double click on it and raise the volume up next be sure the speaker does not have a red x in it, if thats OK then update your windows media player and try again, also be sure that windows medial player does not have the volume turned down and be sure the speaker is not x'ed out in media player. hope this helps. Thanks for using fix-ya.
Jun 08, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
How do you turn up or down the volume on a Craig MP3 player?
press the vol button then press next song button to increase volume and the previous song button to decrease volume. Then, press vol again to exit volume setting mode.
See page 17, diagram 4
http://www.craigelectronics.com/manuals/CMP168C-IB-E001.pdf
Dec 26, 2009 | Craig CMP168C MP3 Player
Volume too low
Chances are there a limit on the volume to keep it from going to loud. If the MP3 has a screen, use it to navigate to a menu and go into it's sound settings. From there, you should be able to raise the max volume to the REAL max.
Jul 07, 2009 | Samsung YP-U3JQB MP3 Player
Problem with MP3 player-Stops after one song
On closer look (after my long road trip to test this out), I realize when you hit Browse, there's a button on the bottom titled Play All. If you select this button, the buttons mentioned above work as intended, and the Forward, Backward buttons bring you to the next or previous songs in the list.
Sep 27, 2008 | Garmin Nuvi 660 GPS Receiver
GPX MW3837 Malfunction
Let it recharge for a few hours - when an mp3 player won't turn off, use the reset button instead of letting the power drain down. Actually, i take it back - this is the worst most godawful manual I have ever seen - this is the first Mp3 player I have ever seen without a reset button.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 18, 2008 | GPX MW3837 MP3 Player
Sandisk keeps skipping/freezing songs!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Can't increase volume
Hold the Menu button until u see: Search.
Then go down to AVLS: then it will say "on" next to it. hit vol. up, then the down button, play/stop.
Finally hit "Menu" again to go back to music
Nov 02, 2007 | Sony Walkman Bean NW-E305 MP3 Player
The record voice is stuck on and I can't get it to switch back to the mp3 songs.
Actually there are 5 buttons (6 counting the reset inside) and the
ROCKER button for volume also is a MENU button (M) if you hold in for several seconds rather than rocking up down for volume. WIth menu up you can switch from fm radio , music , voice , navigate or setup functions. These are all in the book but
Samsung is never to clear in translating their instructions to english.
Feb 10, 2007 | Samsung Yepp YP-F1Z MP3 Player
Sony Walkman NWZ-S616F MP3 Player Logo
477 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
