Question about Samsung LE40B650T2 40 in. Full HD Crystal LCD TV
Can I set the default input to hdmi2 on samsung le40a655. On power up I have to use the source button to change through 3 or 4 inputs to set it to HDMI2 from the FreeSat box.
tvtek
  • 1284 Answers
SOURCE: no picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Posted on Dec 06, 2007
  • 98 Answers
SOURCE: Samsung Source Options Are Missing
Is there any connection with S-Video?
If yes, you need to unplug S-Video first.
If not, better to check the Main Board.
Posted on Feb 24, 2009
  • 53 Answers
SOURCE: source in samsung 42 lcd keeps changing
it has something to do with the key pad assembly, i guess the source button may be sticking in. Has the key pad board been disconnected?
Posted on Mar 18, 2009
  • 72 Answers
SOURCE: Pink and Red Dots
try removing and reseating the LVDS cable connected to the LCD panel
Posted on Jun 07, 2009
  • 120 Answers
SOURCE: Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Posted on Jul 24, 2009
My panasonic viera TC-55DX700C has 3 HDMI inputs. But, when I press the input button on my remote control, I can only select HDMI 1 or 2 or a component, not HDMI 3. Why?
Usually when you have more than one HDMI port you always should connect to the 1st and any other component extra to 2 then 3. In your set HDMI1 is best for viewing for 4K or default, HDMI2 is for a stereo that supports ARC and HDMI3 is for extra components. In most TV now the set will not let you connect to an input source unless you physically have a component with a cable in that source port first. I'm figuring that might be the case of your TV set.or else it wants you to use HDMI1 first If you do have a cable in HDMI3 with a component and it's not letting you connect to it, then the other thought could be that the plug has gone bad,
Apr 02, 2017 | Panasonic Televison & Video
How can I change source on Goodmansld3266d tv with out remote?,stuck on pal1??? Thank you in advance for any advise
On your TV should be buttons on the bottom or the side. Hit setup menu should have a icon for inputs, cable, hdmi1 hdmi2, selected which input you want.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/reuben_09f18ea112b9b936
Mar 04, 2016 | Televison & Video
No sound no picture on new LG 49uf6400 tv. Have used remote on all buttons, am on HDMI2, using both LG & universal remote. Power on in house...
Set should be turned on to antenna input from cable or whatever.
If you are using a cable box then the output does go to HDMI 1 input with the source control on set set accordingly. If still no operation either the box is defective or it is the tv not working properly.
Nov 18, 2015 | LG Televison & Video
How to change the input on samsung 50inch
On the remote there should be a button that say INPUT or SOURCE. That will change your input on your TV. There should also be a button next to the power button that says the same thing.
Feb 14, 2015 | Samsung Televison & Video
How do I change to 4:3 aspect setting on sony kdl40ex500
If the WIDE button on the remote control isn't changing the aspect ratios here is what I can tell you:
Normal is not available when you are watching a 720p, 1080i or 1080p source.
If 4:3 Default is set to anything but Off, the Wide Mode setting changes only for the current channel. When you change channels (or inputs), Wide Mode is automatically replaced with the 4:3 Default setting for 4:3 sources. To retain the current Wide Mode setting as channels and inputs are changed, set 4:3 Default to Off.
4:3 Default is not available if Auto Wide is set to Off.
The owner's manual can be found here: https://docs.sony.com/release/KDL32FA600-EX301-EX400-EX401-EX500-EX501.pdf
If you still can't get the aspect ratio to properly work you may need to do a power reset or perform a factory reset: https://us.en.kb.sony.com/app/answers/detail/a_id/38403/c/65,66/p/61659,62766,63066/ Just make sure to note any special picture or sound settings you may have made.
Aug 22, 2014 | Sony BRAVIA KDL40EX500 40-inch Class...
I turn on the cable and power button then the TV and poweer on and only balck screen and AV appears in the right hand corner. Can't get my TV to wrok. Yet the one in the living room works
Make sure that the source input is set correctly. You can select the different "source inputs" using your TV remote. For example, if the cables from the cable box going to your TV are going into AV1 port on your TV then you need to select AV1 as the "source input" on your TV settings. This works the same with HDMI1, HDMI2, ect.
Jul 17, 2011 | Televison & Video
How do you set up the tv for dvd use? Under the menu the setup options for dvd says N/A.
When you connect a device to a newer model flat panel, it assumes a source input witch in your case it may be video1 video2 hdmi1 hdmi2 or component 1 or 2 and so on. Hit the source button on your remote and toggle it until your reach the input source your are plugged into.
May 29, 2011 | RCA Televison & Video
Samsung UN46D6300 TV not in Logitec Harmony 700 remote database. Need IR code/s to enable controls (especially TV input source selection). Learning mode was only partially successful for power, volume...
When i went into the Harmony software, your TV did come up. If these codes aren't working try a different model Samsung (like UN46D6000). All new Samsungs use the same code set. If this still doesn't help, go to "Devices"->"Settings"->"Adjust Inputs"->"Method 3". Follow the directions from there. Something else that may help is Samsung calls it the "Source" button, Logitech calls it "Input x".
Apr 28, 2011 | Samsung Televison & Video
Put my ps3 on hdmi cable and now cant get it back to av . tryed holding the on/off button on for the first and second dong but still not back to av HELP
Welcome to Fixya. If you're using a HDMI cable to connect your Ps3 to your TV you need to set the input to HDMI. Use the remote of the TV look for Source or Input Button then change the Input to HDMI1 or HDMI2.
Thanks for using Fixya.
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Samsung LE40B650T2 40 in. Full HD Crystal LCD TV Logo
314 people viewed this question
Jerry Greenberg
Jerry Greenberg
