Question about Belkin Computers & Internet
I have a belkin G Wireless router F5D7234-4. When I try to commect with Intel (R) Proset/Wireless, I do not get prompted to type my encryption key instead I get sent to a set-up wizard eventually being prompted fo a owner password. When I try connecting to other available wireless networks, I immediately am asked for the Encyyption Key. What can I do to get connected?
    President:
  • 1,768 Answers
1.Your encryption for the security for the router you are trying to access need the WEP password. if this is your router you should have set up a profile with your password encryption. If you are trying to access another router in the area wirelessly you will have to have permission to access.
Posted on Aug 07, 2010
What is the security key of a belkin wireless router model f7d402?
Wireless routers can change the type of security key such as WEP, WPA and WPA2. WEP is the weakest type of encryption, and WPA2 is the strongest. To see what kind of key you are using, log into the routers ip address (Defualt gateway address in ipconfig command) then find the area for wireless security. The type of key and the key should be displayed.
Mar 02, 2011 | Belkin Wireless Play Router (F7D4302)
When i try to connect my sons laptop i am prompted for the security key . i then recieve this message. wireless authentication failed because of a timeout
First of all make sure you are typing the correct security keys. If you are then just disconnect the power from the router for 15 seconds and plug it back in. This should work.
Hope this helped.
Jan 29, 2011 | Belkin Computers & Internet
DELL E6400 Connect to wireless Modem problem
I have the EXACT same problem on the same computer.
I'm not an expert so I searched online but didn't really find a lot of responses to this Dell issue. One suggestion was to turn off Intel PROset and let Windows manage the wireless connection.
That worked for me.
When in the Intel PROset menu, click on Advanced, then click on "Let windows manage your wireless set-up."
Alternatively, you can toggle between the two software by pressing F10.
This solution worked for me.
Jun 08, 2010 | Dell Latitude E6400 Laptop
My Intel ProSet/Wireless device manager keeps asking me for a password that is on my router. What do I need to do. The router has been doing fine and all at once I can't connect. Please help
Connect Router - Computer (Wired)
Open RSP By typing the Address 192.168.2.1 in the Address Bar of Internet Explorer
On the Left Hand Side Underneath Wireless Click WiFi Protected Setup
Leave the Password blank and click submit
Disable it and apply the Changes
Restart the router and try connecting wireless
IT Will work for sure
Jan 07, 2010 | Belkin (F5D7230-4) Router (587009)
Wlan key for belkinF5D9230-4 modem
Do you mean the encryption settings to allow computers and laptops to connect to the wireless router?
If so open the IE browser and type in the Belkin's configuration IP address (http://192.168.2.1) and login to the router. If you diddn't change the default admin login then the password is blank, just press enter.
Then go to the wireless settings and note the SSID and encryption settings.
Then configure the wireless cards in the computer/laptop with these wireless settings.
Nov 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Intel Proset wireless just drops connection
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 02, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Have lost the key to my belkin FSD7633-4
Okay, follow these instructions for locating your wireless encryption key. If for some reason the instructions do not solve your problem, call Belkin Technical Support for assistance in resetting the Wireless Encryption Key.
You will need to gain access to your router's control panel. To do this wego to Start>Programs>Accessories>Command Prompt. From heretype in:ipconfig
Press ENTER to execute the command. A listshould be returned listing some IP Address. Look for the oneassociated with,"Default Gateway."
Here is a picture.
Afterward open your Internet Browser(Internet Explorer, Firefox, etc...) and type the IP Address associatedwith the default gateway into the address field of the browser. DO NOTadd www. or .com. Afterward press ENTER or click GO as if you wanted tovisit a website.
Here is a picture.
Once you're atthe control panel you will probably be asked to log in. If you donot know your login details you can always try the default. Tofind these you can either search your router's user manual or head tothe online search engines entering your router's manufacturer's name,the router's model #, and the words, "default password" into the samesearch request to bring up the default login credentials. For example:
Linksys WRT54G default password
Here is a picture.
If you still can't manage to log in to your router's control panel you will have to contact the technical support department of your router's manufacturer (In this case Belkin) asking them for assistance in resetting the login user ID and password of the router.
Onceyou manage to log in to your router's control panel. Look for anythinghinting Wireless security or Wireless settings. Once found, look for theregion which controls settings on wireless encryption. Once found look around in the region for Wireless Encryption settings. Once you find them you should also locate your Wireless Encryption Key or a passphrase which can be used in place of the Wireless Encryption Key. Make sure to writedown the pass-phrase and/or the password for future reference.
Just make sure to try out the passphrase/password before exiting the control panel. Otherwise you'll have to follow these directions all back over again.
Let me know how it turns out and if I can help you out any further.
Feb 19, 2009 | Belkin (F5D7230-4) Router (587009)
I need to know how to make my wireless secure can someone help?
ok
first access this 2 link 1 is right for your router.
http://192.168.0.1
or
http://192.168.1.1
then it promptd for password
type username:"admin"
password aslo "admin"or
password is blank
then u enter in rotuer setup.
then go to advanced security option then set connection type as "wep:
then go to encryption key then enter key which is prompt when anybody trying to connect network.
then save settings and restrt.
also u can add mac addresses in allow list .
Dec 30, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin 54 encryption
1. Log into your Wireless Router or Access Point.
Open your web browser and type in the IP address of the Wireless
Router or Access Point. (The Router’s default is 192.168.2.1, the
Access Point’s default is 192.168.2.254.) Log into your Router by
clicking on the “Login” button in the top, right-hand corner of the
screen. You will be asked to enter your password. If you never set
a password, leave the password field blank and click “Submit”.
Click the “Wireless” tab on the left of your screen. Select
the “Encryption” or “Security” tab to get to the security
settings page.
2. Select “128-bit WEP” from the drop-down menu.
3. After selecting your WEP encryption mode, you can type in
your hex WEP key manually, or you can type in a passphrase
in the “Passphrase” field and click “Generate” to create a WEP
key from the passphrase. Click “Apply Changes” to finish. You
must now set all of your clients to match these settings. A hex
(hexadecimal) key is a combination of numbers and letters from
A—F and 0—9. For 128-bit WEP, you need to enter 26 hex keys.
For example:
C3 03 0F AF 4B B2 C3 D4 4B C3 D4 E7 E4 = 128-bit key
4. Click “Apply Changes” to finish. Encryption in the Wireless
Router is now set. Each of your computers on your wireless
network will now need to be configured with the same
security settings.
May 09, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
