Question about Dell Vostro 200 Desktop Computer Intel Pentium Dual-Core E2160 1.80GHz, 1MB L2 Cache, 8
The mouse keeps hanging up for several seconds at a time. It is connected older type to the computer directly.
    Master:
    Sergeant:
  • 447 Answers
Depending on the make, try their website and see if there are any updated drivers!
Posted on Dec 24, 2012
I have optiplex 780, On stsrt up the diagonistic lights 2,3 and 4 keep on blinking and no display comes on the monitor. According to Dell 780 manuals, a possible USB error may have occured and re...
Shut down the computer, disconnect ALL USB connections front and back.
  1. Plug in just the keyboard USB cable and start the computer. If it does not work, try moving the USB plug for the keyboard and trying again. If you can't find ANY USB port that works, then your motherboard is probably fried.
  2. Once the computer comes up with just the keyboard, plug in the mouse and wait for it to work (should be almost immediately). If it does not work in one USB port,try another until it works... wait several seconds after plugging it in before deciding whether it works or not.
  3. Once you have a working keyboard and mouse, begin plugging in any other USB devices, one at a time and verifying that each device works. As with the keyboard and mouse, if it does not work in one port, try another.
    1. Note that some devices may take several seconds or up to a minute to fully be discovered and set up and you may have to respond to something on the screen.
Oct 18, 2017 | Dell Computers & Internet
Mouse stops after a while
Check the battery connections for corrosion.
Try the mouse on another computer. If it still is having issues it might be time for a new mouse.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matt_6e6d4bf9698ea65b
Aug 13, 2017 | Microsoft Wireless Mobile Mouse 3000
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
Keyboard does not type
If all the keys on the keyboard have stopped functioning follow the instructions below to reconnect the keyboard.
This problem is likely to be a lost connection. The connection between the mouse and the USB mini-receiver or the keyboard and the USB mini-receiver can be lost due to several reasons such as:
  • Low batteries
  • Moving the USB mini-receiver from one USB port to another
  • Moving the USB mini-receiver to another computer
  • Plugging the USB mini-receiver into a USB hub or other unsupported device such as a KVM switch (your USB mini-receiver must be plugged directly into your computer)
  • Using your cordless mouse/keyboard on metal surfaces
  • Radio frequency (RF) interference of more powerful wireless devices such as:
    • Wireless speakers
    • Computer power supplies
    • Monitors
    • Cellular telephones
    • Garage door openers
Eliminate any problem sources mentioned above that might be affecting your devices.
Follow the procedures below to reconnect your mouse and keyboard.
  1. Make sure the USB mini-receiver is directly and securely plugged into a working USB port on your computer.
  2. Make sure the mouse is turned on. The on/off indicator on the bottom of the mouse should be green. If the on/off indicator is not illuminated, press and hold the red connect button on the bottom of the mouse until the on/off indicator is green.
    On / Off Indicator
  3. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your mouse. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  4. Quickly press the red connect button on the bottom of the mouse for 1 second, then release it. The power indicator will flash briefly and then turn green. The mouse is now connected to the receiver.
    Red Connect Button NOTE: Holding down the red button on the mouse for more than 2 seconds may cause your mouse to turn off instead of connecting. If this occurs, start again at step number 2.
  5. Move your mouse to see if the cursor moves. If the cursor follows the mouse movements, your mouse is now connected.
  6. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your keyboard. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  7. Quickly press and release the red connect button on the underside of the keyboard.
    Keyboard Connect Button
  8. You will hear a short beep. The keyboard is now connected to the receiver.
  9. Test your keyboard to see if it is working. If the mouse now works but the keyboard still does not, see Knowledge Base article 9144.
Dec 14, 2010 | Logitech Cordless Desktop MX3200 Laser...
Microsoft wireless laser keyboard 6000 v2.0 keyboard not working
You have to press the button on the receiver that is directly connected to the computer. While doing this, press the connect button both the mouse and the keyboard. I did this and now my keyboard is working, despite the battery indicator turning itself off a few seconds after I install it.
Hope this solves your problem.
Mar 20, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Problem with the receiver on my wireless keyboard & mouse KB985W
If you still have the software that came with your keyboard and mouse then i suggest you reload it, it appears that some of your keys have functions to them and they are misbehaving.
If you do not have the software then remove the reciever from the computer and then replace it again. press the connect button on the reciever then the connect button on the keyboard, wait for it to register the keyboard then press the connect button on the reciever then the connect button on the mouse and wait for it to register.
Hopefully this will help.
Nov 16, 2008 | Micro Innovations PD7250LSR Wireless RF...
Connectivity problem with Logitech Cordless Desktop Wave Keyboard and Mouse
if the mouse is a Bluetooth wireless mouse, which by the way you describe the instructions for reconnecting it sounds like it could be the case, you press the buton on the corded reciever unit first, wait a few seconds and press the button on the mouse. This should synchronize your mouse and your PC.
in order to give you more details than that, i would need to know the model of mouse you're using.
Jul 01, 2008 | Logitech Cordless Mouse
My Iogear mouse wont work
In order for you to make the mouse work with your computer, please try the steps below:
1. Make sure that you're using fresh batteries.
2. Make sure that the mouse is turned on.
3. Hold down the connect button on the receiver (the mouse cradle) and hold down the connect button under neath the mouse at the same time for five seconds and then release the buttons.
4. Try moving the mouse around and that should work.
Apr 15, 2008 | IOGear (GKM521R) Keyboard
Wireless mouse quits working after a few seconds
Did you replace the batteries? This sounds like it may be the problem. A year is a lomg time for batteries depending on how often you use the computer.
After changing the batteries, you may have to do this:
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Sep 03, 2006 | Dell Wireless Keyboard Optical Mouse w0147
Dell Vostro 200 Desktop Computer Intel Pentium Dual-Core E2160 1.80GHz, 1MB L2 Cache, 8 Logo
51 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
